Old 03-02-2016, 10:29 AM   #601
davischevy
davischevy's Avatar
Re: Do you have a 1972 Plaid Pickup?
Originally Posted by SS Tim View Post
Thank You!
Actually I have nothing suggesting there were promo package GMCs at this time.
Guessing this closes the book on GMC Highlanders having the fawn glovebox and cluster!
Tim, are you saying GMC Highlander's had the fawn dash?
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 03-02-2016, 10:35 AM   #602
davischevy
davischevy's Avatar
Nice truck! That replacement seat cover looks right at home even if it isn't highlander plaid anymore.
It was his dad's truck he inherited. He is getting ready to redo the seat. I am trying to get him to put the Highlander cover back on it, but he is too tight.
RE; the wood grain side molding.
Tim, could the plant of manufacture had something to do with the woodgrain molding. I had never seen a Highlander without woodgrain molding, that I know of, until I joined this site.
other Larry
Old 03-02-2016, 01:17 PM   #603
mrtoni
That fabric pattern in the gmc is late 70's dodge van/ram charger. Matt
mrtoni is offline   Reply With Quote
Old 03-02-2016, 03:22 PM   #604
SS Tim
SS Tim's Avatar
Yes, we touch on it often but everything points to all the original GMC trucks with the Highlander Plaid trim having the cluster face and glovebox door painted a fawn color. If you look at page forty down at #397 and follow the thread you can read a little more where we really looked at leh72super1500's truck.
Basically they used the same fawn color as they would have been painted on a parchment trim GMC truck.
Seems that "special combination" planning didn't catch the harsh glitch. Since Chevys used body color for these two parts it isn't an issue on Chevy trucks.
http://67-72chevytrucks.com/vboard/s...635040&page=40
...RE; the wood grain side molding.
Well that is a much harder question to give a blanket answer to.
Both black and woodgrain were used on Highlanders optioned with the lower bodyside molding. Of the few buildsheets I have had access to both are seen coded to the truck at the same plant. So it isn't an assembly error. To get much deeper will require a lot more research and documentation that often isn't there for many assembly plants (IE Highlander build sheets).
At this point my stock answer still remains to use what you feel the truck had originally. If it is missing, post up the vehicle and we will try and match a close truck or two for a good guess on what to use.
SS Tim is offline   Reply With Quote
Old 03-02-2016, 08:57 PM   #605
Ed F
Ed F's Avatar
I pulled the seat out of the truck to take the Fingerhut seat covers off so I could clean the grime that has collected for 44 years. The plaid is pretty weak but the vinyl is amazing and cleaned up really well. There are a few small holes from springs poking through that will need repair. I intend to keep the original vinyl and replace the plaid.
Ed F is offline   Reply With Quote
Old 03-02-2016, 09:23 PM   #606
SS Tim
SS Tim's Avatar
I'd suggest a few local repairs (in place) and another clear cover to protect it.
Old 03-02-2016, 10:51 PM   #607
kehstr
kehstr's Avatar
Does anyone have a paint code for this "fawn color"?
kehstr is offline   Reply With Quote
Old 03-04-2016, 05:53 PM   #608
SS Tim
SS Tim's Avatar
Sorry I missed your earleir post with this question too.
Ditzler 23374 "Dark Sandalwood" for the door and the flat for the cluster should be 23375. If you have an original door I'd suggest trying for a color match on the inside at your paint supplier.
Old 03-04-2016, 07:43 PM   #609
Cali72K20
Cali72K20's Avatar
This is not mine but it does have the correct seat cover and it's a big block with A/C.
https://slo.craigslist.org/cto/5474939242.html
Cali72K20 is online now   Reply With Quote
Old 03-05-2016, 09:07 PM   #610
Chevyland
Chevyland's Avatar
This truck was post #343 in this thread. I had been looking for a Highlander for a while and when I showed it to my wife she instantly said "Buy It". The color combo is so different than what you usually see these days. It has original everything on it and everything works. One question I have? When I park it and accidentally leave the lights on, it has a buzzer that sounds like you would hear in a 1973 and later truck. I have owned many 72 trucks and none of them had this option. Was this ever an option on our trucks or is it aftermarket. Thanks. And thanks to this thread for connecting me to this truck
Chevyland is offline   Reply With Quote
Old 03-05-2016, 10:08 PM   #611
72 Super
72 Super's Avatar
Glad it found a good home. I just went back and looked at the earlier posts about it. Nice truck and congrats!!
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 03-05-2016, 10:23 PM   #612
SS Tim
SS Tim's Avatar
Sounds like a great wife to have!
Congratulations on your "new" truck and I am glad it has an appreciative home. The P01s and whitewalls look great back on the truck.
The buzzer could be a GM accessory or aftermarket but they existed. Either way they can be nice to have.
Old 03-05-2016, 11:36 PM   #613
kehstr
kehstr's Avatar
Originally Posted by ss tim View Post
sorry i missed your earleir post with this question too.
Ditzler 23374 "dark sandalwood" for the door and the flat for the cluster should be 23375. If you have an original door i'd suggest trying for a color match on the inside at your paint supplier.
thank you so much that is exactly what i wanted!!!
Old 03-08-2016, 07:22 PM   #614
Cali72K20
Cali72K20's Avatar
Here is a possible Highlander, it looks hammered:
https://orangecounty.craigslist.org/cto/5481930230.html
Old 03-08-2016, 07:45 PM   #615
Chulisohombre
Chulisohombre's Avatar
I've seen a lot worse. Without seeing the spid it's hard to Tell if it could be a real Highlander or just a promo packaged truck. 2 grand ain't bad if you got the other ten to restore it to its former glory. Looks to have the colorectal door panels and dash cap and seat pattern though
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 03-08-2016, 07:46 PM   #616
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Door panels are right color but steering column should be black if its a Highlander but it could have been changed over the years especially if it had tilt. The seat is right and the dash pad should ben black also but it has cloth cover over it.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-08-2016, 07:53 PM   #617
Chulisohombre
On my phone the dash pad looked black. Couldn't tell It was cloth. The column could have been changed like you said.
Old 03-11-2016, 06:53 PM   #618
SS Tim
SS Tim's Avatar
Depending on how much this truck has been futzed with it MIGHT be a Hidden Highlander. Black trim bits, carpet and painted white door panel are a strong suggestion. In any event it would be interesting to see the SPID, more so if it is a 519 Dark Yellow as well.
https://boise.craigslist.org/cto/5474613361.html
Old 03-12-2016, 08:26 AM   #619
Chulisohombre
Too bad it's missing some of the dogdish caps.
Old 03-15-2016, 12:38 PM   #620
Cali72K20
Cali72K20's Avatar
Not mine but another possible Highlander:
https://santamaria.craigslist.org/cto/5490072637.html
Old 03-15-2016, 02:02 PM   #621
Lanman1972
Lanman1972's Avatar
This one sold at Mecum Kansas City, SPID showed Orange Plaid, $6250 was the sold price. Very rusty.
Lanman1972 is offline   Reply With Quote
Old 03-15-2016, 03:08 PM   #622
SS Tim
SS Tim's Avatar
That has been up before or was it a private review? No matter! The painted weatherstrips give pause as to what other surprises are hiding under that paint.
Old 03-15-2016, 07:14 PM   #623
Brent in MO
Here's my recently purchased Highlander. Aside from one repaint, and one missing wheel cover, it is completely original and unmolested all the way down to the wood floor in the bed and the original AM radio. Bought from the original owners.
Brent in MO is offline   Reply With Quote
Old 03-15-2016, 07:18 PM   #624
jocko
jocko's Avatar
welcome Brent - thanks for sharing. Real nice highlander you have there, and a pkg c truck to boot! - dk green is not a common color for highlanders (because of the interior color options) - most seemed to go with one of the olive paint options with the avocado plaid. Yours looks great and the colors go together well. For the PA1 cap, I THINK they are common with a few early 70's cars, or perhaps they're just close. Anyone know if that is true? Again, welcome to the site.
Old 03-18-2016, 12:22 AM   #625
cheyenne shortstep
cheyenne shortstep's Avatar
Here's the SPID, which is all that's left of a well optioned Highlander.
cheyenne shortstep is offline   Reply With Quote
"ss tim", highlander, plaid
Thread Tools
Display Modes
