#6476 |
Re: What did you do to your truck today!
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
#6477 |
Took her out of hibernation and got the headlight relay mod completed. Just have to make the wiring look pretty and change the fuses to circuit breakers.
Realigning the headlights needs to get done now. Posted via Mobile Device Posted via Mobile Device
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
#6478 |
ran fuel lines and fuel pump wiring.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#6479 |
RAT1968 '68 Cab/'71 Parts
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#6480 |
![]() Join Date: Mar 2012
Finished up my new seam sealer on the drip rail and painted the roof white. It was baby blue before. I like how it looks. Classy AND waterproof!
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#6481 |
Finished my T-56 shifter reloaction to work in my 68 with a bench seat.
#6482 | |
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! ![]() 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
#6483 |
Simply bought a better drivers door
Posted via Mobile Device |
#6484 |
Just decided to buy rear sport bumper and brackets for the my baby.....going to put tailights in bumber to keep finished look of the bed. Should bli g a little chrome to the rear and tie in wheels plus hide mst of the new boyds under bed tank. Load pics when mounted and cleaned up
#6485 |
Took 10 hours but we just finished
Rear c-notches Rear bags mounted 2" lowering blocks CPP deluxe adjustable panhard bar CPP 5" drop shocks Connected the air lines and she works like a dream. Rides like a cadillac too. I'll post some pics tomorrow. Im dead tired and heading to my actual job now. Gunna be a long night. Front end is getting bagged on Saturday morning. 8" welded in dropped cups, upper plates and CPP drop shocks. Should be close to laying the arms on the ground with the 3" deep cups.
#6486 |
Grand PooBaa Member
Installed my grille.
#6487 |
![]() Join Date: Dec 2012
Love that Color Tone
1971 GMC Sierra 1959 GMC 100 |
#6488 |
That's nice!
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#6489 |
Started the mach setup 350/T-56 with shifter moved to forward location, still several parts to fit yet.
#6490 |
optomistic ah-so
Hmm...I predict "The Return of Teal" next...which isn't too bad of a thing to happen.
I slid mine around a few wet turns today...would have fixed the brakes if it was dry out or I had someplace dry to do it...my fronts stopped working on Saturday in a way that I would have sworn was a master cylinder, which is so routine to happen to me that I just made plans to buy one and finish swapping in the rest of the rubber brake parts that I already had (I swapped the rear parts a while back and forgot I never finished the fronts). Well, yesterday I found fluid leaking from the driver's front wheel cylinder...I just may have gotten lucky again and ended up only having parts I already bought replacements for, go out (we'll see tomorrow). btw, I do NOT under any circumstances recommend that anyone drive using the parking brakes alone...well, unless maybe you're driving a 2300 lb Valiant/Nova/Vega/Falcon etc...which our C-10s aren't...and especially never in the wet...and especially not if you see me doing it ![]()
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. ![]() |
#6491 |
put on the new adjustable pan hard bar, new monroe gas magnum shocks, pulled the inner fenders and painted orange. Putting them back in tomorrow. Going to put padded carpet on the bed sides and floor of the bed tomorrow.
#6492 |
Grand PooBaa Member
#6493 |
Is that a new repop or junkyard grille ? .
I'm in desperate need of one but I'm skittish about the " CHEVROLET " stamped repops.... Your rig is looking nice ! .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#6494 |
i finally got the last cab bolt drilled out. now i can remove the junk cab off my frame and start cleaning up my frame!!!
1968 Chevy C10 swb fleetside ![]() 2005 Chevy Silverado crew cab (SS) 1977 Goldwing cafe racer 1977 Chevy nova (first car/ first love) ![]() |
#6495 |
Dropped my leaking NP205.
![]() /Patrik
C20 4x4 1970 TBI350/TH350/NP205 Sweden |
#6496 |
Dad and I dragged the old girl out from hibernation today. I would have drove it out except for a drum being stuck. Now I just need to figure out where to start!!!
#6497 |
#6498 |
![]() Join Date: Mar 2010
got it detailed and went for a short cruise
#6499 |
Cruising is ALWAYS good!
![]() Posted via Mobile Device
#6500 |
Installed a fuel tank.
Thread Tools | |
Display Modes | |
