#6676 | |
RAT1968 '68 Cab/'71 Parts
Re: What did you do to your truck today!
But it's not easy to do ANYTHING if you don't have the time. For most folks, some things (for me, it's body work) just need to be done with a checkbook. Congrats on the Vintage Air.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#6677 |
i stole some skins to check out my new drop on the wood hauler
common sense isn't so common anymore |
#6678 |
![]() Join Date: Dec 2012
Nice truck ^^
1971 GMC Sierra 1959 GMC 100 |
#6679 |
it's a pretty nice driver. the drop and disk brakes are just temp on this truck. when it dries up and i can get back intheyard i will be giving this one a4 wheele 6 lug disk brake conversion and this setup will go on one of my 67 short box trucks. my lower balljoints were at the point i had to do somthing nd the brakes left alot to be desired. i had all these parts on hand. other than i got new calipers hoses and master cyl
#6680 |
I wish I could find a 1971 GMC like my Grandfathers
#6681 |
Got the cluster tore apart now to get some paint
72 GMC super custom. ![]() |
#6682 |
Drove it, but over the past few days I've changed the passenger door hinges, added new front shocks and cut 1 full coil off the front. What a rack on this thing now, rack should be gone a little this weekend, 2" rear blocks next.
#6683 |
Took the headers off the old engine, stripped them down and repainted. Also decided to pull the tranny out , cleaned it up and repainted it too, what a mess it was. Hopefully pulling the motor tomorrow.
68 ![]() My other ride ,,, 07 Streetglide.. |
#6684 |
heres your trannys twin
got my ps rocker an corner welded an finished up i had a pic with the door still on but dag i cant find it. i almost forgot too fit the door seal in this side but i got it. time too pull the doors back off the cab back off and finish up the firewall and do some fixin on the doors.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#6685 | |
Posted via Mobile Device |
#6686 |
Well I got the rear shocks relocated with my home made mounts.
![]() ![]() Gotta get some cutting wheels to mount my fronts. ![]()
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#6687 |
1977 Camaro 468 BBC - SOLD - 1972 Chevy SWB....in the works!! ![]() 2006 Crew Cab Dmax/Allison Summit White-SOLD- 2009 Toyota Tacoma V6 Pre Runner - daily driver - my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595 |
#6688 |
Repainting my rally's ! Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
#6689 |
5 Lugz Rims looks really nice
#6690 |
#6691 |
Picked up a new hood and heater controls, along with an ashtray and later model washer bottle set up from the local junkatorium.
'67 C20 LBW |
#6692 |
Junior Member
I took the '67 and '75 for a short drive out in the country to get them some exercise. Of course I took the '67 first since it has the 454 and wanted to have little fun.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
#6693 |
Old member
Well I did this a few weeks ago but just took the pictures today.
Got the on board compressor all hooked up with the pleasure lift gauge and push button switch to fill them up. Works great takes maybe 30 seconds to fill. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#6694 |
Seems like day just went by....
My truck is obviously a driver...not a show truck in any sense of the word. But I have a friend who is running a local show and I signed up. So, I spent a day under the hood doing what I could with what I had to work. Also, it seemed like I'd just clean up one area and another that I'd already cleaned was dirty...And she didn't move an inch! I can see the subtle changes from yesterday, but I'm sure I'm the only one. No matter. It was a good day. Nothing broke. And I didn't buy anything! ![]()
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 04-20-2013 at 11:28 PM. |
#6695 |
![]() Join Date: Feb 2013
I swapped out the old 6 lug axle shafts for new ones... the old ones had been sitting around my buddy's barn and had pitted races... I put those in last weekend... also installed my sway bar! 1-1/16" bar... OMG What A Difference!!!!
So sense last weekend my truck has new rear axles, bearings, new gear oil, a sway bar, new backup/safety switch, new dimmer switch pigtail, new to me chrome bumper, and turned drums. the truck is really starting to come into its own. |
#6696 |
Looks pretty showy to me, nice and clean, good job.
#6697 |
Thanks, MudMan. It's as good as it's gonna get.
#6698 |
Got the motor pulled last night
#6699 |
Grand PooBaa Member
Gave it a new stance. Added CPP 2 1/2" drop spindles. Now it sits 5 1/2" in the front and 5" in the back.
#6700 | |
Just follow this guide http://www.wideopen4x4.com/NP205RebuildGuide.html It should be quite easy since you just can unbolt it at the transfer case and then just pull the whole thing out. /Patrik
C20 4x4 1970 TBI350/TH350/NP205 Sweden |
Thread Tools | |
Display Modes | |
