Old 08-30-2010, 09:53 PM   #701
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: "Rice Rocket'
Dad and my sis, her friend and dads bud went to DC thursday-sunday, here is a pic they took thought it was funny lol..
Anyhow, went to the college thing in town, picked up some papers for welding classes, machinest classes, and general auto classes..
then swung by the air force table on the way back, still undecided what I want to do, anyone have anything to say on this matter pm me or say something on here, im open to opionions advise..
Ok now, Got my new new fuel pump on, and put a THIN layer of pipe dope on threads just in case (was leaking, pita)
put new gasket on waterneck, with THIN layer of black rtv
got tach mounted and partially wired,
Does the red (hot) wire go to the ign. unfused? And does the green wire go to the tach or something? Im not sure, thanks!
John
1999 Toyota Tacoma 4x4
Old 08-30-2010, 11:11 PM   #702
Hubscrub
Cruzin
Hubscrub's Avatar
Re: "Rice Rocket'
yes the red goes to an ign. hot and the green goes to the tach. side of the dizzy
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 08-30-2010, 11:12 PM   #703
Hubscrub
Cruzin
Hubscrub's Avatar
Re: "Rice Rocket'
double post
Old 08-31-2010, 09:28 PM   #704
oldblue1968chevy
Re: "Rice Rocket'
Got some stuff done today:
Brakes bled!
Air filter stud shortened and re threaded!
carberator (edelbrock 600 man. choke) torn down and internal pieces soaking in cleaner!
I think thats pretty good for 3 hours of work! (for me at least lol)
John
Old 08-31-2010, 09:47 PM   #705
Hubscrub
Cruzin
Hubscrub's Avatar
Re: "Rice Rocket'
do you remember how it goes back? j/k
Proverbs 3:5,6
Old 08-31-2010, 10:01 PM   #706
oldblue1968chevy
Re: "Rice Rocket'
haha for the most part yeah..not as hard as it looks really..i did my 500 too..it has instructions..i just hope i didnt loose any parts, besides, ive got my 500 on truck to go by
John
Old 09-01-2010, 05:49 PM   #707
rustaddict
Re: "Rice Rocket'
Are you still running the 3 speed manual ? Are you still thinking about doing a 4 speed swap?
71 Cheyenne
55 Chevy hardtop
53 Farmall Super A
92 Chevy Silverado daily driver (284k on the original clutch and still counting)
rustaddict is offline   Reply With Quote
Old 09-01-2010, 06:53 PM   #708
oldblue1968chevy
Re: "Rice Rocket'
yeah, thinking, after i get the derne'd the on the road again!
ok guys, i was gonna adj. my vavles today, but its still leaking gas from fitting in carb for the hardline..soo
ps i gotta thread on it in the main section
John
Old 09-01-2010, 10:50 PM   #709
oldblue1968chevy
Re: "Rice Rocket'
ok got my carb cleaned and its in the kitchen waitin for re assembly lol too tired for it now though
I was gonna do my vavlves today but had gas leak again..idk what im doing wrong, apparently i cant install a fuel pump..im really lost here? its leaking at the fitting? idk i'll mess with it morrow!
heres a few pics
John
Old 09-01-2010, 11:36 PM   #710
rustaddict
Re: "Rice Rocket'
I love seeing you teenagers work with these old trucks because (1) It reminds me of my high school days with my 72 and more importantly you guys are the future of this hobby. Is that a factory fuel line and fitting or is it one you made up yourself?
71 Cheyenne
55 Chevy hardtop
53 Farmall Super A
Old 09-02-2010, 01:53 AM   #711
rustaddict
Re: "Rice Rocket'
Are you planning on adjusting your valves with the engine off or running?
71 Cheyenne
55 Chevy hardtop
53 Farmall Super A
Old 09-02-2010, 08:07 PM   #712
oldblue1968chevy
Re: "Rice Rocket'
Ok, FINALLY got the danged fuel line fixed!!!!
I adjusted the vavles with motor off, like ticker and the book said
"1. Set the engine to TDC compression #1. This is done by removing the #1 spark plug and the coil wire or HEI distributor connection, putting your finger over the hole and having someone "bump" the engine until you feel pressure..and then bumping it carefully so the timing mark is at '0' degrees. If you overshoot, you need to go all the way around until you feel pressure again. A remote starter switch for $15 makes this a bunch easier...
2. Adjust exhaust valve: 1, 3, 4, 8
3. Adjust intake valve: 1, 2, 5, 7
4. Set the engine to TDC compression #6. Same as above, but with the #6 plug.
5. Ajust exhaust valve: 2, 5, 6, 7
6. Adjust intake valve: 3, 4, 6, 8
They're set to zero lash plus 1/2 turn for a CompCams cam.
Adjusting them while running just makes a mess and ends up with way too much preload."
I did just as he said and I still have a slight tick...soo guess ima re do it or go back and listen with a hose or something to hear where it comming from...
EDIT: Truck sounds REALLY good btw, i love it! I pulled it off the patio of the shop and ive got the clutch way off, with the pedel completely depressed, it BARELY moves, so I need to tighten it up, right?
John
Old 09-02-2010, 09:01 PM   #713
VA72C10
VA72C10
VA72C10's Avatar
Re: "Rice Rocket'
Are you sure it's a valve tick and not a slight exhaust leak at the exhaust manifold? just a thought
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-02-2010, 09:36 PM   #714
bigguy69
dazed and confused
bigguy69's Avatar
Re: "Rice Rocket'
if you done like you said i bet there is a little exhaust leak. now we need the burnout video!!!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 09-02-2010, 10:07 PM   #715
oldblue1968chevy
Re: "Rice Rocket'
geez guys lol
no burnout video yet!!
i'll try the exhaust leak later..good idea
manifolds to head, or manifolds to tubing leak? or both?
and anyone have an idea on clutch adjustin?
John
Old 09-03-2010, 06:11 PM   #716
rustaddict
Re: "Rice Rocket'
Good Job on the valves! I agree with these other fellas a small exhaust leak will sound just like a loose valve. What did you use to seal your exhaust manifolds to your heads? That'd be the first place I'd look. Orange RTV works wonders if you let it sit overnight after you tighten it up. I think the clutch pedal is supposed to have like an inch of free play before it starts engaging the clutch. If you ever get a chance to order one of the GM reprints of the shop manual for your truck,you'll love it. It tells you about everything from the front bumper to the back bumper and sometimes they have details that the other manuals leave out.
71 Cheyenne
55 Chevy hardtop
53 Farmall Super A
Old 09-03-2010, 06:19 PM   #717
oldblue1968chevy
Re: "Rice Rocket'
I just used a gasket between manifolds and head..
Inch of free play huh, looks like it would fall off with that much? I know it must need alot of free play lol
John
Old 09-03-2010, 09:49 PM   #718
2manyprojects
2manyprojects's Avatar
Re: "Rice Rocket'
You need a inch of free play at the pedal not the clutch fork.
Look for black sooty spots at the manifold gaskets, the donuts, and on the manifolds themselves. They have been known to crack. That will be your leak if you have one.
You already fixed the fuel leak, but newbies to line flaring sometimes get off center or over tighten the tool and it causes the flare to crack and leak.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391
42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392
96 GMC K2500 Diesel Suburban
89 GTA Trans Am Convertible.
2manyprojects is offline   Reply With Quote
Old 09-03-2010, 11:03 PM   #719
oldblue1968chevy
Re: "Rice Rocket'
no it was pre flared from parts store..
I got an inch or so at the pedel, i'll adj. some more morrow and see what happens, i doubt it''ll fix it but i dunno
my gf's dad was saying i could have the fork off the TB?..idk
John
Old 09-04-2010, 04:59 PM   #720
Hubscrub
Cruzin
Hubscrub's Avatar
Re: "Rice Rocket'
i don't use gaskets on my manifolds to head anymore, my 85 kept blowing them out and dad told me that most old chevy V8s don't need them so i haven't run any on my stuff since
Proverbs 3:5,6
Old 09-04-2010, 05:11 PM   #721
oldblue1968chevy
Re: "Rice Rocket'
yeah ive heard same thing, long as your manifolds are straight dont bother lol
hub where ya been lol havent heard ya post,im inside tired of fooling with my clutch problems in this NICE weather, missing a local cruise in
imma try to make the lynchburg whiskey run cruise in though!
John
Old 09-04-2010, 11:30 PM   #722
Hubscrub
Cruzin
Hubscrub's Avatar
Re: "Rice Rocket'
i've been around haven't been working on the trucks much, just driving ha, i've been dealing with some other things lately
Proverbs 3:5,6
Old 09-05-2010, 12:06 AM   #723
oldblue1968chevy
Re: "Rice Rocket'
lucky! lol
an old nice straight fErd up at my gf's grandmas in grundy co. lol straight body looks in GREAT shape...
Old LEAD gas pump, pretty cool
and my motor lol..
John
Old 09-05-2010, 12:11 AM   #724
Hubscrub
Cruzin
Hubscrub's Avatar
Re: "Rice Rocket'
i heard some storys about GRUNDY county haha, glad to here its going motor looks good by the way
Proverbs 3:5,6
Old 09-05-2010, 12:20 AM   #725
oldblue1968chevy
Re: "Rice Rocket'
haha yeah theres some stories, im at the warren grundy line...fyi, the fourwheeler pic was taken at beershebra springs lol we got there on wheelers somehow ended up at the craft fair ?
anyhow thought it'd be cool to take a pic by the sign saying Mcminnville this way monteagle that way...long ways from home on wheelers!
btw, there is a cruise in labor day at autozone in manchester
John
Thread Tools
Display Modes
