Closed Thread
Old 11-09-2013, 07:12 PM   #1
BugzC10
BugzC10's Avatar
Re: What did you do to your truck today!
Originally Posted by Mike_The_Grad View Post
Bugz,
Those are some nice looking rims. Good job.
Thanks...lots a elbow grease!! When I get some meats on them I'll post some new pics.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 11-09-2013, 09:52 PM   #2
SuperCtruck
SuperCtruck's Avatar
Stripped all the limo tint off my 71 c10 swb put on by the PO it looks alot cleaner and I'm able to see at night while driving
SuperCtruck is offline
Old 11-09-2013, 11:05 PM   #3
BruthaMan
US Army Veteran
BruthaMan's Avatar
Sometimes I wonder if we should have a "What did your truck do to you today?" thread.
Having recently setup a one piece oil pan gasket in my '78, I picked up a one piece fel pro oil pan gasket for my '72. It was either that, or start putting a mini-pad under my truck, as it was getting progressively worse.
Thought it would be a simple process. Jacked the front end up, jack stands, remove the oil pan bolts and slide the pan out, right? Heh!
After an hour of fighting with the oil pan, it won. Came inside and did a search on the forum to learn it's not as straight forward as on my '78.
Back out to remove the engine mount bolts. First one was out after fifteen minutes of one-to-two clicks at a time on the ratchet. Move to the other side only to encounter a fuel pump with no other way. Three fuel pump bolts later, I was educated on that top bolt under the AC compressor that was next to impossible to get. Thirty minutes later, I had a fuel pump free and started on the passenger side motor mount.
Jacked the engine up a few inches at most, and the oil pan fell free on it's own. Quickly discovered I had picked up the wrong fel pro kit. Wife is out of town, so my truck was only transportation. Son stopped by and I used his truck to go back up to AutoZone with oil pan in hand (GM Crate motor).
By that time, it was dark. Truck still on stands, brought everything else inside. Get to reverse it all for even more fun in the morning!
Would have never imagined something that *should* be so simple, would require a partial frame off restoration to just to accomplish.
BruthaMan is offline
Old 11-10-2013, 03:15 AM   #4
R.L.
R.L.'s Avatar
I live in one of the wettest places in the country and I finally got rid of that wore out sloppy wind shield wiper linkage today!!!
R.L. is offline
Old 11-10-2013, 12:03 PM   #5
jgb7038
jgb7038's Avatar
Finally got my new tires friday,so went and had them mounted on the wheels saturday. 335/30/18 on 11" rims for the rear,and 225/45/18 on 8" rims for the front. Still need to finish the hubcaps and get the rims painted.
jgb7038 is offline
Old 11-10-2013, 01:28 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Those wheels and tires are sweet.. I let my truck see daylight for the 1st time in months...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 11-10-2013, 03:37 PM   #7
Vova
I spy a Toyota rock crawler in that pic...
Vova is offline
Old 11-10-2013, 03:40 PM   #8
In The Ten Ring
Today I took pics of my spare tire mount and went on and installed the "hinge shields" to my side garage door (EZ Armor). Whatever I can do to better secure my truck.
In The Ten Ring is offline
Old 11-10-2013, 03:42 PM   #9
BugzC10
BugzC10's Avatar
Damn...those are nice. who's steelies are those? Makes me think twice about mounting my rallys. Definitely post some pics when you put them on your truck
BugzC10 is offline
Old 11-10-2013, 05:42 PM   #10
In The Ten Ring
Ya I like those wheels too. If I come across some "dog dish" hubcaps I like I'll get 'em and put me together a combo like that. I think such was probably how my truck was first sold anyway.
Old 11-10-2013, 05:51 PM   #11
ksshane
ksshane's Avatar
trying to finish up my drop, but ran out of wire so I couldn't finish welding in my c notches... Hopefully get them finished tomorrow.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline
Old 11-10-2013, 11:27 PM   #12
jgb7038
jgb7038's Avatar
Thanks,they are from Detroit Steel Wheel. Will have a build thread on the truck when I get a little further along.
jgb7038 is offline
Old 11-11-2013, 08:30 AM   #13
elf w/capital T
Got a new ujoint THAT FITS correctly!, mounted 5" drop springs, u bolts,aligned the new rearend up, now gettting the bed ready to be put on so i can get my rear angled right, first timme the truck has been on the ground in a year!!!! I forgot how low it was
elf w/capital T is offline
Old 11-11-2013, 03:53 PM   #14
ekgguy
ekgguy's Avatar
Where did you get the hubcaps? I have also been looking for the same hubcaps. I want to do exactly that with the rims matching the truck although a little wider in the back and trim rings.
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline
Old 11-11-2013, 02:43 AM   #15
Gor77
Gor77's Avatar
___________________________________
Dima
1970 Chevrolet C10 stepside
http://67-72chevytrucks.com/vboard/s...d.php?t=569197
Gor77 is offline
Old 11-11-2013, 04:21 PM   #16
bbcmudtruck
This weekend was a looooong one! I was out in the shop till 3am every day from friday through last night.. Got my front control arms stripped, painted, new bushings, ball joints intalled. Then put new drop spindles on with new drop springs. New calipers and brake pads went on next. The rotors were fairly new and didn't need any work. Next I pulled the motor, put it on the stand and went to work! I pulled everything but the heads. Found out I have a 4bolt main and it has alot of nice pieces in it. Everything was arp and all torque specs were dead on. Also found out my heads were from a 1970 corvette and have been ported extensively. The port work on these heads are beautiful! I didn't pull the heads off to check the bowl work, or even measure the valves. I simply didn't have a good set of head gaskets here or I would have. Anyway, I got the motor reassembled with new intake and carb. Eddy rpm airgap topped off with a new holley 670 avenger. Got myself new wires, hotter coil and new gaskets on everything. Once I got the motor done, I went out to the engine bay and went to work. I found out that the cross member in the frame was barely held in place! When I say barely, I mean bare minimum. This truck was a grenade with the pin pulled. I got lucky to say the least. I got all six of the lower cross member bolts with nuts. (ya, they were all missing!) Torqued them down to spec. Then I tightened all of the other bolts that go through the side of the frame rail. They were hand tight! Plus, it was missing one on the driver side and missing two on passenger! Got a little painting work done to clean up the areas that were bare. Next I got the motor dropped back in and buttoned up to the trans, stall converter and motor mounts. The trans was previously held in place with 2 bolts! I had to drill out a bad hole in the block where the previous owner snapped one of the trans bolts off. I got lucky as I was able to drill it out and easy out the busted bolt. Ran a chaser through every single bolt in the engine and frame as well. I still have to put the alternator on as well as the power steering pump. Wire up the starter and put new fluids in. I dang near got it done inside of a weekend, but I fell just about 3 hours short. I know its a long post, but figured you guys would get a kick out how this truck was put together, or the lack there of! I didn't get any pictures, I was hauling ass through this. However once I get the rest of the stuff done, I will get it off the jack stands and get some pics up.
bbcmudtruck is offline
Old 11-11-2013, 04:35 PM   #17
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today!
No ;
Posts like this are very good indeed because they remind folks to never take anything for granted and to not trust the DPO/DPM's work ! .
THANK YOU .
-Nate
VWNate1 is offline
Old 11-11-2013, 06:25 PM   #18
vidman
vidman's Avatar
A little bit of paint on Friday and some wet sanding today
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 11-15-2013, 11:38 AM   #19
Tri0315
Installed the new Ridler 645s 18x8, 18x9.5 with 255/55R18, 275/55R18.
Tri0315 is offline
Old 11-15-2013, 10:00 PM   #20
ole dollor
ole dollor's Avatar
WOW....that's a very nice truck....and welcome to the forum from Texas
ole dollor is offline
Old 11-12-2013, 10:45 PM   #21
iceship
New fuel pump. ...
Waiting for builder to put electric in garage and it is going down ...
iceship is offline
Old 11-13-2013, 12:03 AM   #22
68LambrechtC10
68LambrechtC10's Avatar
Went into storage unit and made a list of a few items to order from LMC Truck. Moving Lambrecht to a workshop a few doors away to start transformation into a driver...
68LambrechtC10 is offline
Old 11-13-2013, 02:20 PM   #23
724x4LB
724x4LB's Avatar
Stripped the interior and repainted. Finally all one color.
72 Chevy 4x4
Gifted 383
Function over Form
724x4LB is offline
Old 11-14-2013, 09:28 AM   #24
quick60
quick60's Avatar
Finally got the intake/exhaust installed only to find I have a exhaust leak around the mating surface between the manifolds. tightened bolts as much I could still leaking. Might try to take it apart again and fill in inperfections in the casting with JB Weld.
quick60 is offline
Old 11-14-2013, 09:56 AM   #25
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE= Might try to take it apart again and fill in inperfections in the casting with JB Weld.[/QUOTE]
Would it not be better to take the maifolds to the machine shop and get them milled flat? You are going to have to remove the at any rate,..so.
Tom Vogel is offline
Closed Thread
Thread Tools
Display Modes
