07-03-2008, 04:25 PM | #51 |
Java Mechanic
Re: Heavy Chevy -- the penny pinchers rebuild
Oh well... I wanted shiny new ones anyway.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
07-04-2008, 10:20 AM | #52 |
Java Mechanic
Is ther a special school that previous owners go to in order to come up with ideas like, "It won't fit Earl, let's just tear a new hole until it does!
07-19-2008, 08:19 PM | #53 |
Java Mechanic
It's too hot to grind rivets off the frame today so I decided to clean up my tranny cover.
07-21-2008, 07:08 PM | #54 |
Java Mechanic
I hope these things are easier (I know it's more complex, but I'm thinking sweat a tude here!) to reassemble than to take apart!
I need to get that other x-member and some other bits off so I can get the frame stiffeners out and restore that area. Whuff.... "Rust Never Sleeps."
07-21-2008, 07:31 PM | #55 |
I had to replace that same "dogbone" looke crossmember. Mine was growing rust like yours. Once it came apart mine had a hole in the frame. I replaced it with a piece of steel and a board member in Arizona sent me a new crossmember.
Gotta love that living rust... Bet you're getting good with the cutoff wheel and air chisel.... by the way, I replaced all those rivets with grade 8 bolts with lock washers from Tractos Supply. Nice that they have them in bulk... I bet I did nearly 100 total
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 07-21-2008 at 07:33 PM. |
07-22-2008, 02:20 PM | #56 |
Java Mechanic
I think I'm going to end up needing about 30 or so. Is it worth melting a bead on the replacement bolts when it's back together, or is lock tight suffcient?
BTW: Are you planning on Carlisle in two weeks? I've been working on the better half about finding some seats... lol
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... Last edited by panhandler62; 07-22-2008 at 02:22 PM. |
07-22-2008, 03:36 PM | #57 |
I'll be there,,, what kind of seats are you looking for?
I just used bolts, washers, lock washers and nuts. I wish I would have bought nylock nuts but I can always replace some if needed. TSC is pretty cheap for the hardware though...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
07-22-2008, 05:24 PM | #58 |
Java Mechanic
I'm thinking some kind of high back buckets .. not actually an imediate priority though... the interior is at least a year away.
11-25-2008, 02:43 PM | #59 |
Java Mechanic
no money.. no sun.. may as well work on cleaning things up...
11-27-2008, 04:29 PM | #60 |
PROJECT 7DEUCE
Looking good keep up the good work.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-01-2009, 04:23 AM | #61 |
Any updates??
Is that the HAMMERED paint on the calipers?
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby |
10-21-2009, 04:15 PM | #62 |
Java Mechanic
Finally got to get back to the project...
Here is my first box of new toys to show up:
10-21-2009, 04:17 PM | #63 |
Java Mechanic
I'm doing a statis drop in front, so I am getting the rust off my springs. The bucket is full of viniger and softener salt, the battery is out of an old lawnmower and the charger is keeping the battery going.
10-21-2009, 04:57 PM | #64 |
Java Mechanic
Another delivery truck came by..
10-21-2009, 05:30 PM | #65 |
Java Mechanic
Yes, it is. I'll see how it works out. If it flakes off I can always pull 'em and redo them with real brake paint. I mostly wanted to get he patina off after spending so much time cleaning them up. lol
10-22-2009, 09:35 AM | #66 |
Java Mechanic
The rust removal system works so well that my anode disintegrated. lol... ate the alligator clip on the jumper cables... I had to rig something new up (and make sure that only my sacrificial wrench was in the solution this time) to continue.
Here is the first spring with the rust inhibiter setting. The second spring is in the vat. Also -- here are the rear springs for comparson purposes.
10-22-2009, 04:02 PM | #67 |
Java Mechanic
Springs are all cleaned up now... next step will be to remove a coil.
The rears are not going back in. A pair of Firestone 2600s are taking their place.
10-22-2009, 06:00 PM | #68 |
You have an air compressor but your getting springs ready?
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
10-22-2009, 06:30 PM | #69 |
Java Mechanic
The rear is going to sit on air but the front is going to be a static drop.
I'm using 3" drop spindles in the front and shortening the springs. The rear is getting bagged and a pair of Porterbuilt trailing arms to replace the rusty ones I pulled out.
10-23-2009, 12:29 PM | #70 |
Java Mechanic
Another part showed up today. I got this from a bracket racer from the other side of WV for $40.
It's a 750 with vacume secondarys (3310 carb) It's gonna need cleaned and kitted, but I still like the deal.
10-27-2009, 08:37 PM | #71 |
Java Mechanic
More boxes showed up today... Firestones and the 3" drop spindles. Just waiting on the intake manifold and the trailing arms and panhard from Nathan.
Oh, you can see I rebuilt and painted that carb too. The truck is going to be a black and orange theme throughout.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... Last edited by panhandler62; 10-27-2009 at 08:38 PM. |
10-27-2009, 08:40 PM | #72 |
those look like the firestones I put on my motorhome...
10-27-2009, 08:44 PM | #73 |
Thanks, after my hand gets better i plan on cleaning up my rear axle and front suspension and painting it that or satin black.
10-27-2009, 11:10 PM | #74 |
Java Mechanic
They are 2600s and, tell you the truth.. I *am* planning to get another pair of them for the RV later on.. keep it from wallowing around so much.. lol
10-28-2009, 12:45 AM | #75 |
VA72C10
Good work so far...I'll be following along.
Looking for a 67-72 swb or blazer project in or around VA. |
Thread Tools | |
Display Modes | |
