#51 | |
K5-2WD=C5
Re: my 1970 blazer build=4wd to 2wd
IM IN THE 909 ALSO Quote:
THANKS, I APRETIATE THE FEEDBACK!!! ANYWHERE FROM MEDIUM TO DARK BLUE OF SOME SORT, WITH A WHITE TOP. IM KIND OF STUCK ON "M&M BLUE." IM THINKING TWO STAGE PAINT?! NOT SURE I WANT METALLLIC PAINT THOUGH.. ALTHOUGH A BLUE SIMILAR TO MY AVATAR'S COLOR WOOULD BE NICE TOO! |
#52 |
"1972 C5"
Looks great, excellent work on it. Keep the pics coming too!
#53 |
![]() Join Date: Dec 2004
looks good bro,keep it up
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
#54 |
K5-2WD=C5
yeah, it sorta looks like a truck in some of these new pictures!
#55 |
2wd FTW!!!!
Any Updates?
#56 |
K5-2WD=C5
more progress! i pulled the frame out from under the truck for an intense restoration! man it was rusty!!! and i grinded off the rest of the 4wd components in the rear (leaf spring hangars and parking brake brackets). The trailing arm crossmember is already drilled out too! found my trailing arm rear end. hardest thing to do now is fabricate a shock crossmember? pictures are always greatly appretiated! does anyone know if E.C.E. sells the conversion coil spring brackets instead of airbag brackets?
![]() ![]() ![]() Last edited by toplesskayfiver; 05-10-2008 at 08:46 PM. |
#57 |
A guy with a truck
When I first did mine, I moved the crossmember from the front leaf hangers back to where the shock crossmember would be on a coil truck. For spring brackets, you will do the same as you would for bags, just use the stock coil spring retainers...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-25-2008 at 05:11 PM. |
#58 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Lookin good...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#59 |
K5-2WD=C5
i got to making some upper spring/airbag mount brackets.
![]() ![]() ![]() ![]() GRINGOLOCO.. im having second thoughts on moving the body mount crossmember further back because the frame tapers in smaller here, not allowing these bottom brackets to fit=lose quite a bit of strength without em?? lemme know.. ![]() ![]() just to give a glimpse of the quality work in my fam, my pops built this shortbed ![]() ![]() Last edited by toplesskayfiver; 05-10-2008 at 09:08 PM. |
#60 |
SKINNY TIRES RULE!
Lookin' good and your pops built a fine lookin' rig too. If you want to convert another one when you're done, let me know
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#61 | ||
A guy with a truck
Lookin good so far... ![]()
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#62 |
K5-2WD=C5
just about got the heavily coated rust off of my frame,there was a @#%*load of RUST. its coming out really nice! i had to purchase a special rust scrubbing wheel for the grinder tool. a little bit of sand blasting in the harder to get spots will clean the frame perfectly
#63 |
The LuvShack Garage
I like it, would be doing the same thing if I had not found a 2wd frame
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#64 |
Nice work, thanks.
#65 |
K5-2WD=C5
here are some pix of the frame after many hours of sandblasting
![]() ![]() ![]() ![]() ![]() Last edited by toplesskayfiver; 10-10-2008 at 12:25 AM. |
#66 |
K5-2WD=C5
painted my frame after hours of hard work! really coming together nicely! here are some pics, sorry for the dusty frame pics im sanding my belly
![]() let me know what yall think! ![]() ![]() ![]() ![]() ![]() |
#67 |
Post Whore
![]() Join Date: Feb 2000
Frame looks great!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#68 |
The LuvShack Garage
#70 |
Wide n'Low
![]() Join Date: Jan 2007
Great Build! subscribing..
I just acquired my first 70 Blazer, and will be converting it to 2wd with trailing arms and air bags very shortly. I will keep an eye on your progress as it is good inspiration to help me tackle mine.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#71 |
2wd FTW!!!!
Looks great!!! Its almost a shame you have to cover it up with the body.
#72 |
K5-2WD=C5
thanks to evryone who responded! here are some NON-dusty frame pics! enjoi!
question: do you all think i could flipp my blazer tub on one of its side quarter panels onto a matress without it getting damaged??? has anyone done this before? ![]() ![]() ![]() ![]() Last edited by toplesskayfiver; 02-04-2009 at 07:12 AM. |
#73 |
![]() Join Date: Apr 2004
I would not flip my tub on the side to lay it down, mattress or not. especially without welding some braces in there to keep it straight. What are you trying to do? If you are just worried about moving it back on to the body. you should just buy some beer and invite a few guys over.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#74 |
Its lookin' like a Blazer!
I wouldn't. Too much of a chance for damage. Take a look at the last few posts in my thread. The engine crane picks it up just fine and you can go pretty high to get under if thats what your wanting to do.
#75 |
C10 Club Tennessee
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
Thread Tools | |
Display Modes | |
