#51 | |
Urban Chop Shop
![]() Join Date: Dec 2006
Re: Poor mans drop
I apologize to Allen if it seems like I started an argument. This is your thread not mine. That is one thing I love about this site everyone is very passionate about there trucks and there opinions.. That is what makes our country great. Thanks to you guys that work here and take time out of your days to make this forum happen.
2003 Chevy Trailblazer LTZ, 2.5" Susp Lift, Tinted, HID's/LED interior/ Lot of upgrades and little mods 1965 Chevy 1/2T Longbox, soon to be a slammed shop truck Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=591266 Semper Fi Marines |
#52 | |
It'll buff out
Re: Poor mans drop
#53 |
Re: Poor mans drop
cutting the fronts is good,but soemtimes the tires tend to wanna lean in if you go too far(like slammin on the ground)
we've heated many springs,many times. our 1978 chevy c10 is riding on heated springs for about 4-5 years now,and we've even hauled a load in it.it didnt make a huge effect on the ride,you just feel a tad more here n there,but not bad. and it sure is cheap ![]() |
#54 |
Re: Poor mans drop
yeah it's cheap, but why take the chance of a broken spring when you can pop the lower ball joint, cut the spring and reinstall and KNOW the spring hasn't lost it's temper?
for that matter, cutting it is just as cheap |
#55 | |
and a few others
Re: Poor mans drop
All very easy and very cheap. It's not a 67-72, but it should give you an idea what it looks like. ![]()
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi Last edited by 63 & 64 Bowties; 03-12-2009 at 03:36 PM. Reason: felt like havin' a peanut butter & jelly sandwich |
#56 |
Re: Poor mans drop
What other springs will fit the rear of our trucks? Im lookin for around 5'' in the back. I'll probably end up buying drop springs but I just like knowing my options.
#57 |
Re: Poor mans drop
4 inch springs and a 1 inch block will get ya there.
#58 |
Re: Poor mans drop
i have 3 set of belltech spring for a chevy celeberty that look like the rear springs in our trucks, they are wound real tight top and bottom. i will try to get some pics today. mike
#59 |
Re: Poor mans drop
anyone happen to have a list of what will fit? You never know what one will come across in the yards.
#60 |
Re: Poor mans drop
Welcome to the board! You may not have realized it, but you have to be a subscribing member to post for sale messages. Check out the provided link for details on subscriptions.
#61 | |
Re: Poor mans drop
Anyone know of an original equipment spring that would provide more drop? |
#62 |
Re: Poor mans drop
<----- In need of the poor mans drop. I would really like to find out what is the least expensive way. Can't justify drop spindles and converting to discs right now.
anyone know where to get U-bolts made around northern IL? I am thinking of cutting one coil in the front and going to CJ springs with 2" blocks in the rear.
'69 LWB Stepside, 350 with mild mods, and 3 speed on the floor Intentions...383 sbc (in assembly stage), trans is still not a definate (3, 5, or 6 speed?), 3/5 drop, power disc brake conversion...then some body work. |
#63 | |
Sunburst C10!!!
Re: Poor mans drop
Gage 1967 C10 Shortbed Stepside |
#64 | |
Re: Poor mans drop
dont know exactly where your at but elgin spring in elgin might be able to help you out they are on larkin ave north of us20 about 6 blocks i think
69 chevy swb 2.5 in droped spindle with 1 coil cut--5 in dropped spring in rear 5 in dropped spring 307 repaced soon with 350 3sp on tree soon replaced with 350 tubo 06 monte carlo 94 chrysler town & country---198K 84 jag xj6 76 sportster---57 panhead |
#65 |
I've got grease on my mind.
Re: Poor mans drop
Here is a pic of the heated coils I pulled out of my truck from the last guy. Every spring was collapsed and it ended up riding on 3 of the four bump stops and ripping out the front shocks.
I have cut the coils many times. Worst part, if you cut too much you don't have a suspansion anymore, you have a brick. Second part to consider is that used springs have diffrent sag. Just because your truck sits level now, does not mean it will after the cut even if you remove the same amount from each spring. Put the springs back from the side you pulled them out of and a good thing about our trucks is that you don't have to remove a whole coil at a time. Which means, if one side is higher you can just pull it again and trim a little to level the truck out. Lastly, stick to the two coil rule. If you need more than that, you want to get it elsewhere. If you are like most and want a lot of drop, start with 1 to 1-1/2 coils. Do not build up too much heat during the cut or the tension will change which means the ride will change. Hacksaw, cutoff tool, or plasma. Stay away from the torch. Good luck and enjoy! |
#66 |
Sunburst C10!!!
Re: Poor mans drop
i cut 2 off and it was too much i had to put chains on the control arms to keep the springs from falling out when i jacked it up
#67 |
Loving the Jimmster
Re: Poor mans drop
Ok i know there is alot of controversy on doing this the old school or cheap way, but this is what some of us get to do. So with that said, if i cut my front springs (in small increments) and do the same for the rear springs, do i still need the rear blocks?? I am trying to lower the front about 1.5 and rear about 4.5. it is really raked at this time and i dont like the look.
#68 |
![]() Join Date: Dec 2008
Re: Poor mans drop
I would say no to both, but just a many would say yes to the front....The backs are not able to be cut, 2" lowering blocks are as big as you can go "Safely" ..... Neither should be heated.
#69 |
Loving the Jimmster
Re: Poor mans drop
ok thanks and i do understand your position, if you use blocks then you dont have to cut the rear springs or replace them with shorter springs?? i guess i dont understand.
#70 |
and a few others
Re: Poor mans drop
you can't cut rear springs, they're pigtailed on both ends. Get used Chevelle or Jeep springs, or new lowering springs from a vendor.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
#71 |
Loving the Jimmster
Re: Poor mans drop
Perfect!! i did not know they were pig tailed on both ends, ok so lets say i buy some drop springs for the rear, do i still need blocks??
#72 |
Re: Poor mans drop
"Perfect!! i did not know they were pig tailed on both ends, ok so lets say i buy some drop springs for the rear, do i still need blocks??"
If you need up to 2 more inches of drop? figure out where you want it and it will be easier to know how to get there? Last edited by Skirkpat; 04-15-2009 at 10:37 AM. |
#73 |
Loving the Jimmster
Re: Poor mans drop
I am wanting to drop my front 2 inchs and my rear somewhere between 4-5. I am looking for rear springs and have found a "Stepped A arm"? looks promising.
#74 |
Re: Poor mans drop
I took my springs to a suspension shop and they de-arched them for $25.
Got 2.5" lower. Easy cheap and safe. |
#75 | |
![]() Join Date: Aug 2005
Re: Poor mans drop
Shane is right; for 15" wheels. When you go bigger you can run a taller block accordingly. Rule of thumb is +0.5" in block for every +1" in wheel diameter. With that said, I run a 3" block with 22" wheels. I wouldn't want to run much taller blocks than that regardless of scrub line tolerance. |
Thread Tools | |
Display Modes | |
