#51 |
Re: Your Garage
28 x22 3 car,heated, sheet rocked, hot & cold water, 250 cable channels and a refrigerator full of adult beverages.
#52 |
Re: Your Garage
RW71 Is that an Ogilvie Track?
Jamie _______________________________ 72 Chevy Cheyenne 350/th350 LWB 03 Chevy Silverado Sporty Shorty 4.8L |
#53 |
Re: Your Garage
72 SIERRA LB 74 C10 SB 85 C10 SB 75 EL CAMINO SS ![]() Last edited by po_bird; 02-11-2010 at 11:44 PM. |
#54 |
Re: Your Garage
Mine's 32'x32', two 8'x10' overhead doors and a man door. I have lots of light and heat when it's needed
![]() These were taken before I had completed the sheet rock on the ceiling. Since I'm in construction, I have been slowly gathering up leftovers from work and when I get enough for a project, I do it. ![]() ![]() Like my main heating system-a propane-fired water heater, circulating pump and 2 unit heaters. It works pretty good, it'll keep it up in the 50's no matter how cold it is outside. All of it salvaged from re-model work. The other system, that I thought would be just a back-up, works good enough that often it's all that's needed. My shop has a single-slope roof, that is, it is 16' tall at the front and 8' tall at the rear, so over 1000 sq ft of southern facing black shingles. Even on cold days the attic space gets very warm, so I harvest that with a ceiling-mounted exhaust fan sucking air out of the shop space and dropping it back into the shop space at the front. For a little bit of cool-factor, the upper vents are fire-smoke dampers. Normally, F/S dampers are in ductwork, and are held open with current, and close when a fire alarm cuts the power. I wired these up to stay closed, and through an attic vent thermostat, they come open and the exhaust fan turns on. On a sunny day, if it's over about 25 or 30 degrees outside, it will stay running almost countinually. Except for the power to run the fan, it's free heat ![]()
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#55 |
Re: Your Garage
18x21 and I wished it was bigger about 2 days after it was built.
#56 |
Re: Your Garage
20x25. Haven't started working on anything yet. Just park the DD in there for now. Wanting to build a 36x40 on its spot but need more money first. I think this stupid little garage is only about 7 ft or 7'6 tall. I can reach up and touch the trusses with no problem and im 5'11.
1970 Chevy CST/10 1970 Chevy CST/10 1972 Chevy C/10 1972 Chevy Suburban K/10 2019 Silverado 2500 Duramax Kevin |
#57 |
English Chevy Owner
Re: Your Garage
Going to see a couple of houses at the weekend, one has a smallish (well by your standards anyway!) double garage and a small single but room to knock them all down and build a decent sized workshop, maybe a pole barn, the other has a massive 23' x 57' workshop, the roofs tall enough for a lift and maybe a mezzanine floor, with a pit already in and two full height doors. Who's bothered about the house.....
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
#58 |
![]() Join Date: Jan 2002
Re: Your Garage
Well I don't have any current pics(its sided and everything now) or a full picture for that matter. I will get some soon and post them up. You can see part of it in the back of the pic. It's a 32x48. Its heated. Also have a 24x24 attached(will get pics of it, too). Wish we woulda built the 32x48 to about 40x60 or even bigger.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
#59 |
Re: Your Garage
This is where my magic happens. 20x32.
![]() No heat. No ac. Running water when it rains (summer project) But it has a 3x6x4.5ft deep oil change pit in the center bay. Need to redo the electric, add a gutter, and fix some drainage and I'll be good. Blazer currently resides in the center bay.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
#60 |
Re: Your Garage
Here is mine, this is when I had emptied it to do the floor, I put an epoxy floor coating with HD paint colour chip in it,then a heavy coat of industrial clear over it. It has three garage doors. Two in front and one at back for a drive through to the yard.
Now the garage is in work mode with all my tools and truck back in it. It's going to need a good cleaning to make it look like it did. But that wont happen till the truck is done. ![]() |
#61 |
Re: Your Garage
i guess you werent kidding, ive got to make it over there someday
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#62 |
Re: Your Garage
Here is mine 2 cars garage. No room to do anything with 2 cars in it.
#63 |
Re: Your Garage
Here are pictures of mine when I finished it. Epoxy floor and all cleaned out. It's about 4.5 car garage.
#64 |
Re: Your Garage
last spring/summer I tore down the wood shed and built a 32x40 with 12ft ceiling, still got a bunch of work to do to finish the inside.
72 Chevy C20 Longhorn 72 Chevy, K20 Custom Camper 67 Chevy, LWB, C20, 350/350, PS, PB, 65 Jag MKII |
#65 |
Re: Your Garage
Mine, built myself, 6 inch thick insulated concrete walls to the gable peak. 24x28 inside dimension. Finished studio upstairs where my wife and I live. Downstairs is wide open with 6x12 i-beam holding up 2nd floor. Temporary frame wall covered with plastic so 1 side is storage of household stuff, laundry, Freezer. Other side is my workshop, motorcycle parking, hangglider storage, bike storage, spare parts..... Wished I had made it twice as large and wouldn't have to build house.
#66 |
Member
![]() Join Date: Sep 2009
Re: Your Garage
My Garage
69 C10 SWB 406 SBC 08 Silverado HD 2500 LWB Crew Cab Diesel. 06 Trail Blazer SS (Wife's Daily Driver) 67 RS/SS G-Machine http://www.hubgarage.com/mygarage/RBC67 |
#67 | |
Re: Your Garage
1990 Chevrolet RCSB●LS1/4L60E Scrimpin Ain't Easy
#68 |
New Member
Re: Your Garage
Here's mine.
#69 |
Re: Your Garage
#70 |
SWBs: 67 2x4, 67 4x4, 70 4x4
Re: Your Garage
Slick 67, we need to check out each other's stuff soon. I would like to see that color in person. How close are you to finished?
I will have my second done in March. let's meet halfway for beer in the trucks. A Hooters would work for me. We can park in front and sit right next to them.
FINISHED Project thread: 67 SWB 4x4 FINISHED Project thread: 67 SWB 6 cyl cruiser Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT 01 C5 convertable 08 Z06 |
#71 |
Re: Your Garage
here is a couple of shots of my shop in the back yard. We are always hanging out doing something...
1965 Chevy Suburban 2003 Chevrolet S10 2011 Harley Streetglide |
#72 |
Re: Your Garage
#73 |
Re: Your Garage
wow don't take this the wrong way but you need a hoist in there
a big sound system and a fridge and it would be perfect! ![]() ![]()
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
#74 |
New Member
Re: Your Garage
I'm in the process right now of building an apartment inside which will include the fridge and the sound system and then some.
#75 |
Re: Your Garage
That would make it perfect! Just live there year round.
Thread Tools | |
Display Modes | |
