09-14-2010, 12:45 AM | #51 |
Re: parting out a 68 lwb 4wd 4 speed truck.
harold here is a pic of the fuse block. not sure yet if buyer of cab wants it with cab or not.
i have 67/72 chevy truck parts f/s. |
09-14-2010, 12:46 AM | #52 |
09-14-2010, 12:47 AM | #53 |
heres a pic. of the dash
09-14-2010, 12:54 AM | #54 |
truck came from ca it's been in tn sence 95 it's been stored inside most of that time,
cab looks to me like it still has orig inner & outer rockers & cab corners these all need a little att. as useal in these olaces but not bad. worst rust i saw is where rocker meets the floor ft toward kick panel very fixable both ft cab suports are just starting to show rust not bad & i saw 1 spot on drivers side firewall about a couple "'s in size. around windshield still has shiney white paint on it no rust.
09-14-2010, 08:35 AM | #55 |
I think I am out on this stuff because I found most of it locally.. Thanks for looking into it though.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
09-14-2010, 03:03 PM | #56 |
do you have ac compresser
09-14-2010, 03:38 PM | #57 |
69step350 i have at least 1 for $25.00 but shipping would be at least $30.00 because its so heavy. i am not sure its good or not. i sale them for $25.00 to people to use for cores . core charges most places are $100.00.
09-15-2010, 11:31 AM | #58 |
don these plates & bolts are a little larger than your measurements they must be 3/4 ton stuff.
09-15-2010, 11:43 AM | #59 |
Darn, are the plate holes wider then 2.5 inchs Bill?
Would you have the cooling fan available from this parts truck? Last edited by 67gmcstepside; 09-15-2010 at 11:44 AM. |
09-15-2010, 11:21 PM | #60 |
plate holes are 3 1/4 ". i don't have a fan with this truck but i may have a 18" clutch fan i will check if that is what you are looking for. i have 1 elect. fan also.
11-10-2010, 12:17 PM | #61 |
bump ttt for you bill
someone is looking for a 4x4 frame. |
11-10-2010, 12:24 PM | #62 |
eric this truck has moved on. i am looking for a parts truck. i still have the burb for now.
Thread Tools | |
Display Modes | |
