Old 07-22-2019, 09:02 PM   #51
Stephen717
Stephen717's Avatar
Re: No Limit 63-72 Rear Shock Kit
Ok so I know I probably missed it but what's the advantage (if any) of relocating the shocks? I mean it looks cool but do they function better? Also would a monromatic stock replacement work with this as if I do end up doing this I don't want to replace the shocks I just bought. And is it only for lowered trucks or does it work on stock ride height vehicles
Stephen717 is offline   Reply With Quote
Old 07-22-2019, 09:31 PM   #52
70blackfish
So. Does not work with porterbuilt rear trac bar.
I called and asked. Rob said it would.
70blackfish is offline   Reply With Quote
Old 07-23-2019, 09:06 AM   #53
robnolimit
robnolimit's Avatar
As you lower the OE truck, the shock length drops drastically. There are two remedies for this, low profile upper mounts and shorter shock. BUT, these are really just Band-Aids for the design shortfall. GM designed this to be a workhorse, to carry heavy loads on gravel roads. Not to be a good handling smooth riding cruiser (that was the Impala's job). So, any band-aid to 'fix' the workhorse design is a short-answer fix.
Re-designing the way the shocks mount and react, and allows for a longer shock even with a lowered truck. Mounting behind the axle (on a T.A. suspension) increases the wheel rate of shock, and therefore quickens the shocks reaction time to the suspension. Having the shocks wider apart helps to stabilize the axle motion as well as the roll rate of the truck.
Yes, you can use this with a stock height truck. And, yes, we have the correct part #'s for the monroe-matic shocks based on ride height of the truck.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 07-23-2019, 09:06 AM   #54
robnolimit
robnolimit's Avatar
We have had a few customers do this, no one has reported any fit issues.
Old 07-23-2019, 10:45 PM   #55
Stephen717
Stephen717's Avatar
Please pm me with a price to relocate with stock ride height and shocks
Old 02-23-2020, 02:37 PM   #56
hubba033
hubba033's Avatar
How does this setup work with gas tank being relocated?
72 C10 swb LS 5.3 LSA Blower/4l60 performabuilt
01 Pontiac Trans Am WS6
hubba033 is offline   Reply With Quote
Old 02-23-2020, 04:25 PM   #57
KMC3420
KMC3420's Avatar
With the gas tank being relocated as below, I would think the tank would need to be dropped to access the upper shock mount. This is not my truck, but one I had saved. I don’t think the tank would interfere with the brackets however. As you can see you still have access to swap shocks easily if the need should arise. The bracket would be more difficult to remove with the tank in the way.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 02-23-2020, 05:33 PM   #58
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: No Limit 63-72 Rear Shock Kit
These will not work with PB trailing arms though. I have called and even asked if they would custom make me a set that would and was told no!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-27-2020, 09:53 PM   #59
tim_mc
tim_mc's Avatar
I think I'll be doing this mod when I swap out my rear diff with a rebuilt posi unit, hopefully in the next few months. My fuel tank has been relocated, and I can't get a wrench or socket between the tank and the frame rail. I also don't want to drop the tank as getting the fuel filler hose onto the tank was a real chore. To gain access for the brackets, I may drill a couple of holes on the lower frame rail flange beneath the bracket location, and connect the holes with a cutoff wheel to make some slots for wrench access.
Thanks Andy, for the pics and info.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 06-13-2020, 03:04 PM   #60
STICKBNDER
can I use these with my ridetech rear shockwaves?
STICKBNDER is offline   Reply With Quote
Old 05-03-2021, 02:59 AM   #61
HeavyHauler
I wonder if this would improve the ride quality. My 68 Chevy C10 is lowered 6 inches in the rear.
HeavyHauler is offline   Reply With Quote
Thread Tools
Display Modes
