Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 06-20-2011, 07:30 PM   #51
thebeast61
thebeast61's Avatar
Re: Wiring for dummies
I dont get anything at the brown wire with the key on. I guess i am going to have to spend some time tomorrow tracing out my wires and see if i can figure out what is going on. ill post what i find and maybe we can get this gremlin. Thank you
thebeast61 is offline   Reply With Quote
Old 06-22-2011, 05:09 PM   #52
thebeast61
thebeast61's Avatar
ok i have looked at the wiring and im not really sure what im looking for but i traced the wires and they look ok. I still dont get anything at the brown wire on the alt. any suggestions?
Old 06-22-2011, 05:43 PM   #53
fixit-p
fixit-p's Avatar
Originally Posted by fixit-p View Post
It's pretty simple, off of the ignition switch there should be a pink wire which supplies the entire trucks ignition circuit (including fuel gauge, gen light, temp light etc..) just tap into this pink wire and and run it to terminal #1 on the alt then cut the wire where it's easy to work and install a resistor. You can solder or use butt connectors to attach the resistor (solder is best) but either way use some heat shrink tubing to protect it from short circuit. So you end up with one end of the wire attached to the pink wire the other end of that wire would be attached to one end of the resistor then a second wire is attached to the other end of the resistor with the other end of that wire connected to terminal 1 of the alt (that would make the resistor wired in series with the #1 terminal). The resistor will get hot (just like a light bulb will so tie it off loosely.
http://www.radioshack.com/product/in...ductId=2062291
Did you do the above? Just adding a resistor wont make power present, you either need to trace the existing wire in the cab or run a new one as outlined above. I prefer to fix the circuit rather than running a new circuit but you said ealier you didn't have time to trace the problem so I suggested tapping into the pink wire off of the ignition switch, below I highlighted the circuit in red.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 06-22-2011, 11:09 PM   #54
thebeast61
thebeast61's Avatar
Yea i did that. I finally found the problem. It was a loose wire. I tightend it and all is well. Thank you all so much for your help. I am glad there are smart people here that have the patience for the ignorant like me. Bless you all.
Old 06-23-2011, 12:23 AM   #55
fixit-p
fixit-p's Avatar
Cool, glad you got it going.
Old 02-18-2012, 06:06 PM   #56
Andyboy
Andyboy's Avatar
Do I really need the junction stud? I can't find one anywhere. I tried OSH, napa, autozone, o'reilieys and no one has one.
Andyboy is offline   Reply With Quote
Thread Tools
Display Modes
