11-02-2011, 09:59 AM | #51 |
Re: copper lines with accuair setup ??
either do copper or the soft fuel cell alumiunum if you want to use the 3/8 ptc fitting pre fit on your valve block or you will have to change the fittings. pretty much block off the front ptc fittings and us the ones on the back of the valve block if you want to use SS. then you will need all the fittings and connections...(thats the more $$ way.) Im using polished copper ill put pics up when done(its goes with the theme of the truck)....and polished copper looks awesome also, there is a rouge that is perfect for copper I think the name of the company is called "master formula" I watched them polish a copper keg and it was incredible when done.
11-02-2011, 10:41 AM | #52 |
67cheby
cool, cant wait to see it ..GET TO WORK !!
11-02-2011, 11:11 AM | #53 |
i am at work...lol....i just got my compressors back from p.c and have to put them back together first but have the air filters installed on the frame rails as well as everything esle mounted....actually I had it all done but with DOT line but decided that the truck was going to be certain colors the copper lines were a must spend......some of the other lill acc. stuff will have to wait right now but it shall be done....ill make it all perty for ya. My wheels will be going out to have the centers of the spokes sandcasted so I can have them painted and flat cleared. but should be abel to throw up some updates on the chassis soon
11-02-2011, 11:26 AM | #54 |
67cheby
SWEET..cant wait
11-02-2011, 05:32 PM | #55 |
trust me, I cant wait either......just want to get this chassis done 100% so I can move on.....still have lots of little things to do, like all the brake line plumbing and have to get creattive do hide all wireing.....im treating this like its some super show sponsored truck but in fact its going to be drivin daily. thats why the chassis is all satin so touch up is easy peasy, and all the air ride components are closely located so it can be worked on at any time.....maybe Ill get a magazine article but definetly not in the plans....I also have no car club affiliation so this thing is all me.....lone wolf! my wife has been a huge help being I work full time and have little time...plus I get those days where i want to work on the truck but as soon as i change and go in the garage i change my mind....lol Im sure you understand. ......soon as the lines are plumbed I will get ya pics....the wheels I will email as I dont want many to know about them. Im not looking foward to the polishing part of the copper but its gotta be done.....just polish one of your line fittings and you will seee.....its sexy!
11-02-2011, 05:35 PM | #56 |
eventually Ill have some Tubz too
11-02-2011, 05:51 PM | #57 |
67cheby
my plans a very similiar ...mine will be a daily driver also !! cant wait !!
12-27-2011, 04:37 PM | #58 |
Tot Roddin'
Any concerns with then powdercoating the aluminum or steel lines? Fitting fitmen would be a concern I guess.
Anyone with experience doing this?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-27-2011, 04:59 PM | #59 |
67cheby
i am considering painting mine when i am done so they will just blend in to the frame and just leave the last 1/2 where the push in masked off
12-27-2011, 06:25 PM | #60 |
you could powdercoat the lines, but you wouldn't want them to move after or you could crack the pc.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
12-28-2011, 09:02 PM | #61 |
Doug Looking for a 67-72 short bed driver..... |
12-29-2011, 08:33 AM | #62 |
subscribed to for ideas for project "ODD BALL"
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
01-07-2012, 04:05 PM | #63 |
so I learned somehthing about using these copper and aluminum lines with PTC fittings.... make sure they are super secure so they do not move and also measure back about 1/4" back so the PTC fitting can bite into the material and not push back under pressure....so those whom are doing this just some advice as I did full copper on mine and each line was leaking at the fittings come to find out it was because the fittings were not completely biteing under pressure.
01-07-2012, 04:23 PM | #64 |
67cheby
are you saying they were leaking because they were bent to tight so then they wouldnt push in far enough ?
01-07-2012, 04:41 PM | #65 |
no, i pushed them in first and bent from there, then disconnected the ending fitting and inserted on the line and reinsalled to the bag....all my connections are swivels. my were leaking because there was no good "bite" on the metal....but when I scored them and installed the same way because I already have all my bends done i set up the rest in dot and tested the one aluminum line and at full pressure aird up it did not leak at all
01-07-2012, 04:57 PM | #66 |
67cheby
any pics of how you "scored" them ?
01-07-2012, 05:01 PM | #67 |
you can try it without scoring it first and see if you get better luck than I did, but in my situation that is what happen....Also I made a clamp out of wood, I drilled a 3/8 hold in it pice of spare wood and then cut it in half down the middle of the hole I drilled, clamp the coil to a vise(i used an old 3/8 ptc on the vice and put the line in that so I didnt smash any of the line) and then put the two pieces of wood around the line and pull...that will straighten it, I just did them in the lengths as needed but worked great and left not markings on the metal.
01-07-2012, 06:08 PM | #68 |
i scored them using a pipe cutter and very lightly, just enough to give it a small grove. i will try to get a pic to you on my next day off(tuesday)
01-10-2012, 10:35 PM | #69 | |
'69 Chevy SWB
We use copper lines for a lot of our pneumatic equipment at work. Some see over 140 PSI. We use stainless on all of the co2 lines and some of those are even higher than that. I can't see it being an issue.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
02-02-2012, 12:04 AM | #70 |
Woohoo I ordered 50 feet of the aluminum line!!! It will be here tomorrow.
Thanks mike for starting this thread!!! Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
02-02-2012, 10:45 AM | #71 |
67cheby
lol, no problem .....make sure you have extra..for practicing, ask me how i know !
02-02-2012, 11:41 AM | #72 |
Haha. I got 50 feet.... Enough you think?
02-02-2012, 11:42 AM | #73 |
67cheby
lol...prob not for me , i screw up ALOT !!
02-02-2012, 04:51 PM | #74 |
if anyone is interested snap on sells a tube straightner for like 100.00 if can get the part number if needed... when I did my copper I used it because i can only get up to ten feet of type L copper(thats the correct to use) and I did not want to flare them and make more connections so I ended up buying a roll of copper from mcfadden dales and got the straightner from snap-on.
02-02-2012, 04:55 PM | #75 |
takes just under 5 feet to do the rears from where I have the valve mounted and about 30 to do the fronts...but I would recomend to get 90ft if you are just starting out, you will use it like mike said....so Ill keep it for emergency. Im re doing my tank set up with the exo kit and dual 3 gallons so Ill be re doing some of the connections.. I also swithced over to an fittings and flared the copper for extra security but it wont leak if you use a parker or equivelint PTC fitting. just make it stable and secure so it does not move or you will need to run a braided line from the bag mounts to the hardline.
Thread Tools | |
Display Modes | |
