Old 03-27-2017, 10:19 AM   #51
Gus350
68 C 10
Gus350's Avatar
Re: Project-Atlas
Truck is starting to look killer. What was the main issue when you were running the Carb on the LS? Thanks keep up the great work.
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 03-27-2017, 01:39 PM   #52
Eastonspeedworks
Eastonspeedworks's Avatar
Re: Project-Atlas
I had every problem imaginable with the carb, lean rich, diesling, flooding, ect you could set it up and it would run good for one day or one trip. It would hardly get me home from shows I absolutely hated it. I had 3 other people try to tune it too and they were lost and they were die hard Holley guys I won't buy another one but I would try a quadrajet I like Rochester carbs a lot
Eastonspeedworks is offline   Reply With Quote
Old 04-03-2017, 10:43 PM   #53
Eastonspeedworks
Re: Project-Atlas
Got some goodies tonight! Bought a take off tailgate from a board member and my wheels finally showed up so stoked to get them on!
Old 04-03-2017, 11:11 PM   #54
TXBoudy
TXBoudy's Avatar
Re: Project-Atlas
It's looking great, I like it.
TXBoudy is offline   Reply With Quote
Old 04-05-2017, 08:30 AM   #55
hewittca
hewittca's Avatar
Re: Project-Atlas
Very cool. It's going to look like a whole new truck with those wheels. Hurry up and get them on so we can see some pics!
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 04-05-2017, 08:48 AM   #56
Eastonspeedworks
Re: Project-Atlas
I got to find a good shop to mount them up first! I'm holding off until all this paint work is done I'd be the world's saddest guy if they got over spray. Any recommendations on getting them mounted? I saw they recommend touchless mounting but I'm not sure anyone around here has that equipment
Old 04-05-2017, 08:51 AM   #57
hewittca
hewittca's Avatar
Re: Project-Atlas
I'm not really sure, but I'd hate to ding up those wheels. I had my 22x9s mounted with the standard setup at Napa and they had to wrestle the tires to get them on. The machine also chewed up the paint some as well. If you can find that touchless mounting, I'd definitely go that route, and watch them get mounted if possible!
Old 04-08-2017, 09:10 PM   #58
Eastonspeedworks
Re: Project-Atlas
Well it was a real ordeal to get them mounted I had 5 shops turn me down altogether. The first place recommended a shop and they were pretty unpleasant on the phone so I tried everything else and finally went there. They didn't want to do them either since they only had an hour and a half before closing but finally agreed. They did a nice job but damn expensive!
Old 04-09-2017, 08:04 AM   #59
hewittca
hewittca's Avatar
Re: Project-Atlas
Those look great! Are you running the same specs front and rear?
Old 04-09-2017, 08:20 AM   #60
GR8-68
GR8-68's Avatar
Re: Project-Atlas
That is awesome looking, love the new wheels
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 04-09-2017, 06:28 PM   #61
Eastonspeedworks
Re: Project-Atlas
Yes I'm running the same wheel front and rear 8.5 wide 5.25 backspace and 20" dia they fit perfectly not to pat myself on the back or anything lol
Old 04-10-2017, 10:11 AM   #62
hewittca
hewittca's Avatar
Re: Project-Atlas
haha, nice! I like the look. You don't see too many guys going with the same setup front and rear on big wheels these days. Even on my own truck, I modified the rear steelies to have a deeper lip than the front. I think it fits your truck and will make it stand out from the crowd too. Looking forward to seeing some more pics of it.
Old 04-10-2017, 01:06 PM   #63
Eastonspeedworks
Re: Project-Atlas
I didn't have a choice on mine I have about 1/2" on each side of the rear tires I couldn't have bigger ones if I wanted them lol
Old 04-10-2017, 01:27 PM   #64
hewittca
hewittca's Avatar
Re: Project-Atlas
Really? What's interfering? From the pics it looks like the rears are tucked pretty good.
Old 04-10-2017, 01:51 PM   #65
Eastonspeedworks
Re: Project-Atlas
They do fit very well but I'm tight on the inner bed panel and the inner fender I never cut the inner skin or widened the tubs since I planned on having white walls forever. But I screwed that up!
Old 04-14-2017, 01:12 AM   #66
Eastonspeedworks
Re: Project-Atlas
Since I have tomorrow off I figured I could fool around this evening. I modified a 67-68 hood latch to fit my truck (I like the shape better) and started doing my fauxtina on the tailgate. Still a lot left to do but its a good start
Old 05-14-2017, 03:38 PM   #67
Eastonspeedworks
Re: Project-Atlas
Finally back together I must say I couldn't be happier with the truck it's a blast to drive!
Old 05-14-2017, 07:00 PM   #68
hewittca
hewittca's Avatar
Re: Project-Atlas
Looks great! I love how your LS looks. I'd like to eventually do a swap similar to yours.
Old 05-14-2017, 07:18 PM   #69
Eastonspeedworks
Re: Project-Atlas
Thank you! I definitely recommend the ls. Wiring is a bit of a pain but they work so good especially if you have someone tune it I did mine and it's actually kind of hard to get everything right and it's still not 100%
Old 05-14-2017, 08:56 PM   #70
RRR18
RRR18's Avatar
Re: Project-Atlas
Read whole build. Great story. Great work. I'll be watchin for more posts.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 05-29-2017, 09:33 AM   #71
Eastonspeedworks
Re: Project-Atlas
Had a good weekend with the truck so far I took it out to the drag races but decided to only spectate thankfully. The next day I put it on the lift and found a failing weld on the clutch linkage I built so I fixed that up real nice this time hopefully that's the end of my linkage woes. Still have some odd issues to sort out with the tune. The truck stays on power when you push the clutch in and revves to about 2500 rpm and stays there for about 30 seconds before returning to idle. Hopefully I can figure that out today.
Thread Tools
Display Modes
