#51 |
Re: Headers or manifolds
![]() Now that's some funny stuff right there! Actually the tool boxes get no warmer than the fenderwells, which is to say roughly room temperature or so. Heat rises, how hot does your hood get? And unlike modern car's, the whole underside of the engine bay is open, so plenty of air circulates in there. Check out my Rockford Fosgate 8" sub between the seats! ![]() In an enclosed cab, that is plenty of base to blow your ears off if you crank it up! ![]() These old trucks are COOL! ![]() ![]() |
#52 |
ok the boxes look much farther away in that pic....had a buddy returning from a rained out race...had a cooler full of food...wrapped the hot dogs in aluminum foil and stuck them between the valve cover and exhaust manifold ( think it was a lincoln)....pulled over under an overpass to eat....shoulda seen the look on the face of the guy who pulled over to see if they needed help....
1970 short step c10 leaf spring 454 |
#53 | |
I do, I just don't own the BMW anymore. My friends grandson rolled his Ford pickup, so I sold the BMW to him. Ain't about to part with with my '69 Stepside though! ![]() That stereo in there flippin' Rocks! ![]() ![]() Ford trucks are built TOUGH...but they don"t like to be rolled! Thank God that kid didn't even get a scratch! ![]() |
#54 |
Headers won't leak if you install them correctly. Use the ''Copper Plus" Permatex in place of collector gaskets. Can also be used in place of the header gasket. It won't leak then and is not a bit deal to get apart. The copper header manifold gaskets are really nice also. They have been really good to me so far. And the new Headers have a ball socket which really helps a lot also. The alow a little flex, which is especially great with a 4x4. and they don't leak.
#55 |
Judging by the attitudes and preferences in this thread along with my perception of everyone's age, I'm going to go out on a limb and say that headers are for the young guys and manifolds are for the farts...I doubt headers will ever go on one of my build ever again...here ,pull my finger!
Seriously, I'm old enough that my hearing has become a concern and the existence of cell phones (and easy listening music) makes me steer more towards a quiet ride with the power it needs to be fun, not squeeze every pony out of the drivetrain and turn heads for blocks. Stock manifolds are quiet compared to headers and, if you use the high performance ones and port match them, they are still quiet.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#56 | |
![]() Join Date: Feb 2002
Putting a cross-over pipe on your dual exhaust lines can cancel out a lot of noise. Also wrapping headers with 2'' hi-temp fibreglas header tape can really turn down the dBs. My Jimmy w/wrapped headers sounded like a Cadillac in underground garages. Car alarms would go off, and dogs would bark, but the sound vibes were below normal human hearing. Also both my trucks are floor shifters, I don't have a free extremity to answer the phone while driving. [CB would be another matter, if I had it installed.]
#57 |
I'm also in my '60s. If anything, I'd say it's the old farts from back when headers was about the first thing you did...back before the highly knowledgeable internet geniuses
#58 |
Yeah, Special-K.
Adding Headers and other Hi-Perf gear was a way of Just Saying NO to Mr Nixon's double nickel [55 MPH] national speed limit. And also thumbing your nose at the establishment's BS smog equipment that made no mechanical sense, but was some how politically reassuring to the uninformed masses. Living thru such times makes one a cynic.
#59 | ||
"I ain't nobody, dork."
Just turned 50... I have put headers on dang near every truck or car I have ever owned. Never noticed any extra noise from headers. Any noise gained came from the louder mufflers and larger pipes I would install.
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#60 |
Speedway has a nice set of ramshorns. ceramic coating seems to be holding up well, no leaks
#61 |
#62 |
So I've had em both on my daily drivers, meaning cheapo headers that got all rusty, and stock manifolds. Now Im installing a gen 5 L83 5.3 / 6L80e which has something like 385 ponies and 385 Ftlb...... More power than I've ever had in a c10. I want QUIET so I can chill with music and no drone. So this time it will be manifolds. Maybe it is because I have 3 teenagers and I'm turning 50 shortly?
#63 |
Mufflers and pipes are what make the noise. But if you still don't believe that fact then go with cast iron headers that some call manifolds. You say you've done "both" as if there are only cheap headers or stock manifolds when there is a whole spectrum of grey area between that black & white point of view.
#64 | |
Thread Tools | |
Display Modes | |
