Moderator
![]() ![]() Join Date: Aug 2011
Re: wierd cooling system problem noise ?
That engine is a 1965 model 327 (or 283?), using a bypass? Old style heads? Hello?
60-66 Nut
![]() ![]() Join Date: Mar 2007
That factory bypass was used on mostly medium duty trucks back in the day but some light duty trucks came with them also.
Moderator
Good info. That's something I never realized, so it's not new for small blocks. Interesting.
I looked at 5 different 60's small block cast steel intakes on eBay they all have the bypass nipple attached. I never noticed that before.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 02-01-2019 at 08:23 AM. |
60-66 Nut
The factory small block thermostat bypass you posted a pic of, actually uses a piece that installs under the thermostat housing which the bypass hoses attaches to, What you were seeing on those 5 cast iron intakes is likely the heater hose nipple.
Moderator
Good info there, thank you,
60-66 Nut
Post #3 in this thread shows what I am talking about.
http://www.67-72chevytrucks.com/vboa...d.php?t=780199
I am losing my MIND trying to read and learn all of this. So far Google has me deep down a rabbit hole haha. So, I think I can run a regular reverse flow long pump (Like from a TPI 3rd Gen camaro) and just run a nipple in the top of the water pump to the 3/8 NPT water bypass in the front of the Edelbrock Vortec intake that I have?
My mother is a recent cancer survivor and this truck build is for her |
That's it.
Thread Tools | |
Display Modes | |
