Old 08-19-2024, 02:14 AM   #51
kitsbeach
kitsbeach's Avatar
cut rear bed floor
Here's the cuts at the rear of the bed floor
Name:  Rear corner cuts-2.jpg
Name:  Rear corner cuts-4.jpg
Name:  Rear corner cuts-5.jpg
Name:  Rear corner cuts-6.jpg
Name:  Rear corner cuts-7.jpg
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 08-19-2024, 02:21 AM   #52
kitsbeach
kitsbeach's Avatar
rear bed floor corner pieces
This is left rear bed floor corner from the bottom
Notice the 1/2" extra bed floor sticking out that I am going to beat down later to look like the factory rear edge.
Name:  Tack in rear corner pieces-1.jpg
Name:  Tack in rear corner pieces-2.jpg
Kitsbeach (Ken)
Old 08-19-2024, 02:27 AM   #53
kitsbeach
kitsbeach's Avatar
This is right rear bed floor corner from the bottom.
Figures that the piece I needed was rusty and I needed to fix it up a bit.
Clamped it in with vice grips to take a look but would need to fix rust hole.
Name:  clamp in right rear corner pieces-3.jpg
found some other little scraps that sort of matched the detail needed.
Name:  right rear corner piece scraps-4.jpg
Tacked in place.
Name:  right rear corner piece tacked in-6.jpg
Kitsbeach (Ken)
Old 08-19-2024, 02:29 AM   #54
kitsbeach
kitsbeach's Avatar
bed floor rear
Here are the rear bed floor corners from the top before welding.
Name:  rear corner pieces from top pre welding-8.jpg
Name:  rear corner pieces from top pre welding-9.jpg
Kitsbeach (Ken)
Old 08-19-2024, 02:34 AM   #55
kitsbeach
kitsbeach's Avatar
bed floor rear
Tacked it slowly one little bit at a time then eventually was finished and ground it down.
This is left rear bed floor corner. I'd sometimes clamp some copper in behind it to make it easier to weld the gaps.
Name:  Weld and grind left corner-1.jpg
Getting smooth
Name:  Weld and grind left corner-2.jpg
Kitsbeach (Ken)
Old 08-19-2024, 02:38 AM   #56
kitsbeach
kitsbeach's Avatar
bed floor white boards
I probably put 40 hours into this bed floor but I didn't spend any money!
Seriously I enjoy building things without going out to the parts store or waiting for the UPS truck, but there were a lot of steps to this bed floor and more to come.
Name:  Bed floor whiteboard to-do lists-1.jpg
Kitsbeach (Ken)
Old 08-19-2024, 02:47 AM   #57
kitsbeach
kitsbeach's Avatar
rear bed support
Replaced rusty rear bed support with one of the long bed pieces that I patiently removed by grinding out the spot welds.
I just rosette welded through the old spot weld holes.
I wish I remembered all the measurements to put here in this thread.
Name:  Rosette weld rear bed supports -3.jpg
Name:  Rosette weld rear bed supports -5.jpg
Name:  Rosette weld rear bed supports -6.jpg
Kitsbeach (Ken)
Old 08-19-2024, 02:53 AM   #58
kitsbeach
kitsbeach's Avatar
rear bed support tail piece
The cool thing about doing the rear of the bed floor this way is the very rear bed support/tail piece can just be rosette welded on through the old drilled out spot welds. Check the coyote customs youtube for this.
Name:  Rosette weld rear bed tailpiece -4.jpg
See the 1/2" overhang that I am going to beat down later.
Name:  Rosette weld rear bed tailpiece -1.jpg
You can see the overhang here better (also my booger welds!).
Name:  Rosette weld rear bed tailpiece -2.jpg
Kitsbeach (Ken)
Old 08-19-2024, 02:58 AM   #59
kitsbeach
kitsbeach's Avatar
beat down rear bed floor lip
Here I just beat down the 1/2" overhang. It actually looks pretty good in person even though not every hammer blow was perfect.
Name:  Beat down rear lip-1.jpg
Name:  Beat down rear lip-2.jpg
Name:  Beat down rear lip-3.jpg
Name:  Beat down rear lip-4.jpg
Name:  Beat down rear lip-5.jpg
Kitsbeach (Ken)
Old 08-19-2024, 03:00 AM   #60
kitsbeach
kitsbeach's Avatar
Primed.
Name:  Rear lip primed-1.jpg
Name:  Rear lip primed-2.jpg
Name:  Rear lip primed-3.jpg
Name:  Rear lip primed-4.jpg
Kitsbeach (Ken)
Old 08-19-2024, 03:06 AM   #61
kitsbeach
kitsbeach's Avatar
rusty bed floor hole
One bed bolt hole was rusted away so I patched it with a piece from the scrap.
Name:  Patch rust in bed floor bolt hole-1.jpg
Name:  Patch rust in bed floor bolt hole-2.jpg
Name:  Patch rust in bed floor bolt hole-3.jpg
Name:  Patch rust in bed floor bolt hole-4.jpg
Name:  Patch rust in bed floor bolt hole-5.jpg
My 40 hour bed floor was finally done other than some seam sealer and a few details.
Kitsbeach (Ken)
Old 08-20-2024, 12:46 AM   #62
kitsbeach
kitsbeach's Avatar
right bedside rear cuts
Here are first cuts on rear of right bedside.
I took 14' out of the front and 5 3/4" out of the rear. The coyote customs guy likes 5 3/4" because the holes line up when you go to bolt your bed back together. I know most guys do 6" so it probably doesn't make a huge difference but I could reuse the imbedded nuts.
Name:  Bedside right rear cuts-1.jpg
Name:  Bedside right rear  cuts-2.jpg
Kitsbeach (Ken)
Old 08-20-2024, 12:53 AM   #63
kitsbeach
kitsbeach's Avatar
Drilled out spot welds of the inner bedside because mine was the kind where you can just cut it off and rosette weld the inner bedside back in (saves tons of welding).
Name:  Bedside cuts right rear need to remove inner piece-9.jpg
Then I finished cutting the outer bedside. I was a little tight to the corner stake here but it all worked out.
Name:  Bedside cuts-right rear shows pieces.jpg
Here are the pieces.
Name:  Bedside right rear  cuts-13.jpg
Kitsbeach (Ken)
Old 08-20-2024, 01:17 AM   #64
kitsbeach
kitsbeach's Avatar
right rear bedside tailgate hinge repair
I had to take a little time out to repair the tailgate hinge. The truck I had got the bed from had sat in a field with a canopy on but the door was open and water accumulated back there. Tailgate was junk too.
This was the best time to fix this because it was easier to work while the rear of the bedside was removed.
Big hunk missing where hinge is supposed to bolt on.
Name:  Tailgate right  hinge rust before.jpg
Made a little patch to just lap weld on. At this point I was just praying the tailgate would close properly after because this was the maximum of my fabrication capabilities.
Name:  Tailgate right hinge patch mockup.jpg
Welded a nut on the back of the patch before I welded the patch on.
Name:  Tailgate hinge rust and patch welded nut to inside of patch before putting patch on-8.jpg
Here is patch welded in before grinding.
Name:  Tailgate right  hinge patch welded in-9.jpg
And final patch with some primer on it.
Name:  right tailgate hinge fixed.jpg
Kitsbeach (Ken)
Old 08-20-2024, 01:35 AM   #65
kitsbeach
kitsbeach's Avatar
right rear bedside welds
Butt clamped it all together ready to weld
Name:  Bedside right rear clamps on ready to weld-24.jpg
First tacks. Some big gaps at this end made it a bit difficult to weld
Name:  right rear bedside first tacks.jpg
I tacked basically one tack at a time and really took my time to avoid warping. I'm actually going to leave a couple of the "scars" proud just for fun since this is somewhat of a patina/bruiser truck.
Name:  Right bedside after grinding welds-3.jpg
This is a pic after lots of welding and grinding.
Name:  Right bedside right rear after grinding welds-4.jpg
A couple of lessons:
The rear is easier to line up and weld because of all the structure.
It is important to have enough gap so that the pieces are actually welded. Sometimes the gap would shrink and I'd cut it open again with a thin cutting wheel (this happened more at the front than the rear).
It took a long time to fill all my pinholes. I suspect that the pinholes will be the first place this will rust later.
Also while welding it was sometimes hard to believe that the bottom would work out but it did. I just worked an inch at a time and it all lined up.
Kitsbeach (Ken)
Old 08-20-2024, 01:46 AM   #66
kitsbeach
kitsbeach's Avatar
front bedside cuts
This is a picture of the left front bedside. There's a lot of stuff on the internet about matching the shape of the top corner so it can match the other piece after the 14" is removed.
It made sense to me to just cut a nice 45 degree cut that would be easier to copy and that is what I did and it worked out well.
See my tape here on the corner just ignores the shape and makes it into an easy cut.
Name:  Left front bedside taped and ready to-2.jpg
Kitsbeach (Ken)
Old 08-20-2024, 02:05 AM   #67
kitsbeach
kitsbeach's Avatar
right front bedside cuts
Looks like I didn't take all the pictures I should have of the right front bedside cuts, but I've got a few.
Also notice where I cut along the top of my bedrail. I think Dave Welch cuts over the edge onto the side of the bed but, to me, it was easier to cut through the top. I could see what I was cutting and also preferred to have a scar on the top of the bedrail rather than on the side of the truck.
This is tape for the staggered cut but before I matched it to the edge cut with the template.
Name:  Bedside right front staggered tape-28.jpg
This is a template of the front edge that I used to transfer the shape to the back edge.
Name:  Right bedside front corner template.jpg
This picture shows how the shape of the cut was transferred.
Name:  Bedside right front first test fit-29.jpg
Name:  Bedside right first test fit-30.jpg
Name:  Bedside right front staggered cut-27.jpg
It took a bit of fitting and grinding before I was ready to weld.
Kitsbeach (Ken)
Old 08-20-2024, 02:26 AM   #68
kitsbeach
kitsbeach's Avatar
right front bedside welds
After a lot of test fitting I started to weld the right front bedside starting at the top stake pocket.
Name:  Bedside right front first tack welds-31.jpg
There were some big gaps in some places but I just tacked it the best I could to start.
Name:  big gaps in some places.jpg
Starting to make my way down from top to bottom.
Name:  Bedside right front starting to weld-34.jpg
This picture shows how the gap was starting to get too small as I welded my way down the side. I actually had some big wedges in the gap to prevent this but things were shrinking a lot as I welded.
Name:  Bedside right front tack welds 35.jpg
Sometimes I would cut the gap back open a bit with a thin cutting disc.
Name:  Bedside right front cut off tight weld-33.jpg
Kitsbeach (Ken)
Old 08-20-2024, 02:33 AM   #69
kitsbeach
kitsbeach's Avatar
As I made my way down the bedside it got pretty wonky but slowly but surely it all worked out.
Name:  Bedside right front lip wonky-36.jpg
Name:  Bedside right front wonky-37.jpg
Name:  Bedside right front lip all fixed-38.jpg
Kitsbeach (Ken)
Old 08-20-2024, 02:41 AM   #70
kitsbeach
kitsbeach's Avatar
After tons of patient tack welding it was starting to come together.
Booger welds.
Name:  Bedside right front stake pocket coming together-41.jpg
Patient grinding so not to cause too much heat.
Name:  Right bedside after grinding welds-2.jpg
Front edge basically ground smooth.
Name:  Right front bedside after grinding welds-1.jpg
Right bedside shortened.!
Name:  Right bedside shortened and ground.jpg
Kitsbeach (Ken)
Old 08-20-2024, 07:17 AM   #71
Android04
Android04's Avatar
Re: 3/4 Ton Long to Short & Static Drop Square One
Killer work man! Keep the motivation going.
Android04 is offline   Reply With Quote
Old 08-20-2024, 07:47 AM   #72
kitsbeach
kitsbeach's Avatar
Thanks man.! I'm probably forgetting about 100 important details but getting the main strokes posted here. If anyone has a question just ask I'll probably have a picture.
Kitsbeach (Ken)
Old 09-17-2024, 11:13 PM   #73
kitsbeach
kitsbeach's Avatar
Left bedside cuts taped and ready to go
Here is the front of the left bedside taped and ready to cut.
Name:  Left front bedside taped and ready to-1.jpg
Name:  Left front bedside taped and ready to-3.jpg
Name:  Left front bedside taped and ready to-4.jpg
Kitsbeach (Ken)
Old 09-17-2024, 11:15 PM   #74
kitsbeach
kitsbeach's Avatar
Mistakes were made
Here's me cutting on the wrong side of the tape..!! Ignored my own arrows..!!
Name:  Left bedside cuts-5 oops wrong side of the tape.jpg
Kitsbeach (Ken)
Old 09-17-2024, 11:19 PM   #75
kitsbeach
kitsbeach's Avatar
Left bedside front cut
Here is the front of the left bedside cut. Notice the hunk cut out of the very front I used as a template for the little angle you see where the little question mark is on my tape.
Name:  Left bedside cuts-6.jpg
Kitsbeach (Ken)
Thread Tools
Display Modes
