Old 04-13-2020, 09:28 AM   #726
kehstr
kehstr's Avatar
Re: 67 GMC super custom build
What did you use as a nut to hold the damper in place?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 04-13-2020, 12:45 PM   #727
chewychevy67
It actually a piece of 1/4" flat that I tapped and welded on the Inside of the gate. It fits perfectly with the spacing of the handle of the damper. I did File out and add a piece into the damper so when I tighten it up it gets sandwiched nice and tight.
chewychevy67 is offline   Reply With Quote
Old 04-13-2020, 05:42 PM   #728
chewychevy67
Started the other side. Made a bushing for the rod to ride on. Now to the other side where the rod goes into. That will be a little more of a challenge to make.
Old 04-13-2020, 09:16 PM   #729
Corts60
Just here to tinker
Corts60's Avatar
That is a sweet mod.
Old 04-14-2020, 12:27 PM   #730
TA_C10
TA_C10's Avatar
Very cool. Where are you getting the delrin bushings?
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 04-14-2020, 12:48 PM   #731
chewychevy67
I got them from member 1966chevy some time ago. It's unbelievable how much quieter it operates now.
Old 04-19-2020, 09:28 PM   #732
chewychevy67
This works just like crossbreed's video. I'm glad I did this mod. I have a few things to do to finish this up but for the next bit I'll be finally getting back to work for a couple of days. This is how my trunions ended up looking. Took more than a couple hours and about 200 bucks but we'll worth it.
Old 04-19-2020, 10:34 PM   #733
Getter-Done
Getter-Done's Avatar
Nice Addition.
Looks great
84 Chevy K-20
Old 04-20-2020, 10:50 PM   #734
chewychevy67
Got a bit further on the gate tonight. Got the bushing into the gate tight so it won't come out and started the piece that holds the rod inside the gate.
Old 04-22-2020, 09:58 PM   #735
chewychevy67
Got the piece made for the rod to stick into. Now to weld it in and see how it works.
Old 04-23-2020, 08:42 AM   #736
cornerstone
cornerstone's Avatar
This is such a great mod! Please post a video of it in action when you can.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-23-2020, 10:04 AM   #737
kehstr
kehstr's Avatar
Someone needs to do a step by step write up on this tailgate mod! I am loving watching it come together!
@Chad's Fab
Old 04-23-2020, 05:53 PM   #738
chewychevy67
Primed my engine yesterday getting it ready to install. While priming it I noticed my new oil pump sure is noisy. I may have to replace it. Not sure if this is normal or not. Had no problem with getting oil to the rocker arms though. Pressure seems good.
Watch "Distributor noise 327" on YouTube
https://youtu.be/yxYskCEgSHA
Got my new oil pump today. Same pump as before but with the shark teeth designation. Way quieter and less restriction. Looks like I'll be changing the pump in the next couple of days. Glad I cought this before I installed the engine.
Old 04-27-2020, 02:52 PM   #739
Racer2172
Just wow, came across you build and read from start to finish, so many well done add ons and details. Great job to this point.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 04-27-2020, 11:35 PM   #740
chewychevy67
Thanks. Hoping I can get you guys a video of the gate in the next couple of days. Just waiting for a part in the mail. It's taking extra long to get stuff these days.
Old 04-30-2020, 11:37 AM   #741
chewychevy67
Picked up an engine run stand last night I'm going to use to break my engine in. It supposedly doesn't need a radiator. It has adapters on eack end of the rad hoses st hook up to your water tap. Has anyone ever run an engine like this? Seems like pumping constant cold water into a warm engine would not be the best.
Old 04-30-2020, 12:55 PM   #742
67 Burb
67 Burb's Avatar
Although I have only run an engine with the garden hose trick once, I would suggest having a valve on the outlet end of hose coming out of the thermostat housing so you could monitor the engine temp and adjust the valve accordingly.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 04-30-2020, 01:15 PM   #743
chewychevy67
Yeah. It might be best to moch up a radiator for it as well. Not worth ruining a brand new engine.
Old 04-30-2020, 06:48 PM   #744
67 Burb
67 Burb's Avatar
Right. Better safe than sorry.
Bob
Old 05-01-2020, 09:26 PM   #745
chewychevy67
New oil pumps in. The shark tooth design is quite a bit less restrictive to rotate by hand and is much quieter. I'm really glad I changed it out. I also straightened out the pan. The longer bolts that come with the gasket aren't crowned like the factory ones were and they just pulled in where the holes are. I found longer ones that are crowned that fit properly and won't damage the pan hopefully.
Old 05-02-2020, 02:07 PM   #746
chewychevy67
Here's the tailgate video! Watch "Tailgate" on YouTube
https://youtu.be/nP6ysgoDLyE
Best part of this mod is there is no way to tell its there with the gate mounted.
Old 05-02-2020, 06:27 PM   #747
cornerstone
These old Chevy and GMC tailgates are heavy, and this mod stops the thing from slamming. Well done, now I have more work to do.
Brian
Old 05-02-2020, 09:31 PM   #748
Wide Open
Nice work!
Wide Open is offline   Reply With Quote
Old 05-08-2020, 06:40 PM   #749
chewychevy67
Got my original 4 row harrison rad back today. Had it re-cored. That was not cheap but it was worth it. Sure is heavy.
Old 05-08-2020, 07:21 PM   #750
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Looks great.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Thread Tools
Display Modes
