09-15-2010, 02:31 PM | #751 |
Grandpa in the rustmobile...
Re: "Rice Rocket'
The bolts are all tight, should I loosen/retighten em all?
#1 was at tdc idk what stroke, it seemed to start idle good and rotor was at #1. Compression stroke is when it pushes your finger off sparkplug hole right? And do I NEED an adj. vac. adv.?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-15-2010, 05:11 PM | #752 | |
Re: "Rice Rocket'
yes, when it pops you finger off. you are plugging your vacuum advance line going to your dist. when setting the timing right?
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
09-15-2010, 06:07 PM | #753 |
Re: "Rice Rocket'
Yes pluggin the vac.line going to dizzy and I was supposed to have been plugging the vacumn port on the carberator too (which i wasnt doing, so i hope thats why I was getting a false reading?..)
They are new dounuts, but I didnt tighten it up all evenly, I ran 1 nut down, then the next, then next then tightened em all up good my mom is picking up a msd cap/rotor for me THANK YOU MOMMY lol
09-15-2010, 08:02 PM | #754 |
Re: "Rice Rocket'
New cap/rotor
Carberator after rebuild (still need to put the side linkage on, anyone got a pic of edelbrock 600 left side pic) Still need to do some adjustments on the outside of it. And I need to get my motor back at TDC #1 Compression stroke Can i bump the motor over with no dizzy? (No oil pumping oil) Thanks
09-15-2010, 08:05 PM | #755 |
Re: "Rice Rocket'
nice work
09-15-2010, 08:12 PM | #756 |
Re: "Rice Rocket'
How big is your cam? This is gonna sound like a silly question but are you positive that both of your marks are lined up exactly right on your timing chain set?
71 Cheyenne 55 Chevy hardtop 53 Farmall Super A 92 Chevy Silverado daily driver (284k on the original clutch and still counting) |
09-15-2010, 08:44 PM | #757 |
Re: "Rice Rocket'
the dots, yes i was paying attention still at that point (drove 1 hr north of me to assemble my bottom end with the machinest who was an older guy maybe 50s/.60s)
The top sprocket dot was at the bottom, the lil sprocket at the bottom the dot was at the top Anyone know if I can bump the motor over with no dizzy, is that ok/safe?
09-15-2010, 10:22 PM | #758 |
Re: "Rice Rocket'
i hope that thing gets runnin good!
09-15-2010, 11:24 PM | #759 |
Re: "Rice Rocket'
Yep, you can bump it over with the distributor out
09-16-2010, 08:36 PM | #760 |
Re: "Rice Rocket'
So far not so good, anyhow ima get it sometime, ive got a 3 day weekend...
09-16-2010, 10:03 PM | #761 |
Re: "Rice Rocket'
once you get it runnin right (which i have faith that you will) youll hafta post a video. i wanna hear that thing idle!!!!!
09-16-2010, 10:14 PM | #762 |
Re: "Rice Rocket'
im glad you have faith in me lol!
it sounds WICKED at idle
09-16-2010, 10:17 PM | #763 |
Re: "Rice Rocket'
thumpr cam right?
09-16-2010, 10:45 PM | #764 |
Re: "Rice Rocket'
yessir!
ill try to get a vid. morrow for ya if u tell me how to make it get on here
09-16-2010, 10:52 PM | #765 |
Re: "Rice Rocket'
hahah welll someone else will hafta help ya with that one
09-17-2010, 05:06 PM | #766 |
Re: "Rice Rocket'
ok the shaft in the dizzy was stuck with grease dirt and the springs wernt flingin lol
tomorow: pull bed and work on gas filler/vent springs/check timing new plug wires/looms finish carberator/install tune i got a bad burn on my finger from exhaust...owch oh i did a few small burnouts....this thing doesnt have the power it should have still though..it does run much berrer though
09-17-2010, 05:07 PM | #767 |
Re: "Rice Rocket'
09-17-2010, 06:57 PM | #768 |
Cruzin
Re: "Rice Rocket'
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
09-18-2010, 08:11 PM | #769 |
Cruzin
Re: "Rice Rocket'
Well im eating cracker barrel n manchester if your truck was runnin good i could buy ur dinner
09-19-2010, 12:05 AM | #770 |
Re: "Rice Rocket'
hey cool can i join
09-19-2010, 12:10 AM | #771 |
Re: "Rice Rocket'
awww gee, not this weekend, maybe next, ya take a raincheck lol?
I had to pull the bed to cut some more off the braces, i couldnt fill the truck up caused it leaked and it was a bad design, so i spent 2.5 hrs cutting with pliers, hammer chizel grinder sawsall cutoff wheel (my gf dad did it the 1st time with torch, SO much easier lol) i'll try to get pictures after church morrow... u drive your truck to manchester this evening? i think they have a cruise in pretty soon or maybe tonite it was idk lol
09-19-2010, 09:03 AM | #772 |
Cruzin
Re: "Rice Rocket'
^no i drove my daily driver we was just cruisin around
09-19-2010, 05:29 PM | #773 |
C10 Junkie
Re: "Rice Rocket'
you make me miss my projects
your project has come a long ways! I'm very impressed. Sad about the accident but then again, things happen for a reason.......helped with the funding of the restore will continue to watch your thread, as I now head out in search of another project lol.
09 Chevrolet HHR --- Cruck --- cross between a Car and a Truck Former rides: 1967 C10 LWB 1972 C10 LWB 1969 C10 LWB (parts truck) |
09-19-2010, 05:50 PM | #774 |
Re: "Rice Rocket'
Yeah, I cant wait till its back on the road im really gettin tired to working on it constantly..
Ive still gotta get the timing crap set right, get my 600 edelbrock on (finished, anyone have a side pic of edelbrock manual choke carbertor?). And do a gas filler for my blazer tank, ive got one in the floor now but it leaks etc and is a crappy idea..ugh. I pulled the 69-72 trim off today i guess i'll throw it in the barn and save it for another truck if i ever finish this one..Im thinkin bout spray bombin my orange bed blue to match the truck lol...idk I may roll it out and wash it and get pics idk..im searchin for blazer tank fillers now, thinkin thru the backup light..but will have to somehow trim inside stakepocker
09-19-2010, 06:23 PM | #775 | |
67-72 parts collector,…
Re: "Rice Rocket'
Thread Tools | |
Display Modes | |
