#751 |
Re: Dutch '59 Fleetside Longbed
Ok, cool
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#752 |
Now I'm asking questions....
Two more: First: What do you guys use/make when you're running electrical wires from inside the doors to the A-pillar? Ofcourse I saw what Ogre did with Truk, but I was looking for something a bit easier to make. Only have to wire the doorlocks. Any ideas with pics would be higly appreciated! Second, for our Fleetsiders: Can someone give me a straight on pic of the bed emblem "Fleetside"? Rightside and leftside are the same, I thought? And the measurements of the emblems, length and hight. As I can't buy them here, I will paint them in high gloss black paint on the semi gloss bedsides, until I can get a hold of a set. Painted black is hard to see, I know, I pinstriped these colors before and it should look great ![]() Thanks in advance!!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#753 |
![]() Join Date: Jul 2012
Kees,
For the door conduit here are two ideas. http://www.summitracing.com/parts/hfm-dloombl/overview/ Can you make use of a rubber bellows style on a newer vehicle? |
#754 |
Thanks Doug.
Yes, I probably could use the rubber bellow from a newer car. I was thinking somebody has done that already from a particular car, so why invent the wheel myself ![]() The Summit loom is a great idea! Maybe I can make such a thing....
#755 |
From the doors to A pillar the best one I saw was from a mini van sliding door.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#756 | |
I have a 5-wire doorlock, maybe those from Mercedes will fit, but I'm not happy with all the failures they had (I used to work at a MB dealership).
#757 |
Kees heres an easy idea for wiring thru firewalls, doors, panels etc that is used in race car type stuff all the time. Its mostly use to just keep the wires from chafing against any of the metal but the tubing can be used as a complete conduit.
First; DRILL HOLE the size you need for how many wires are running thru hole and fits the grommet size you'll be using. #2; install a grommet for that size hole ![]() #3; Find size and color and cut poly tubing to length from point A to point B ![]() #4 run wires and install thru grommets and then put an "o-ring" on the back side of the panel where poly tube runs thru to keep it from coming out. All this stuff should be available to you in NETHERWORLD.... ![]()
My Build: 57 Chevy Pro-Street |
#758 | |
One that's tight ofcourse, but at both ends? So inside the door and inside the A-pillar? It then can slide a bit until the o-rings, that's the purpose of it? If I understand this right, it's a really simple sollution! And yeah, we got this overhere, worked for years with that stuff in trucks ![]()
#759 |
Fast progress on a great build!
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
#760 | |
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
#761 | |
Thanks Dug224!!
I was following your build in the background also, very creative! Quote:
Last week I was trying to get the "Idiot light" to work, I use LEDs for that... So honey, I blew up the LEDs ![]() ![]() Came to the conclusion I first had the LED the wrong way 'round and then it was done with it. A bit of thinking wouldn't help. Thank God for G**gle ![]() Two minutes and I found my problem...You have to have a resistor parallel and a diode the right way in ![]() Solder everything together, try it...and....it works!!! The test set up: After soldering and testing, do the same with the dashlight: To be continued.....
#762 | |
#763 |
I've had it with the flu, so much!!
Two weeks couch hanging, little on the computer, doin' nothing... So tomorrow I go and try to do something on the truck. Hoping to get the doors in and try make PTC's sollution to work. By the way PTC, I personally know the guy who owned your avatar truck ![]() That is, if I see it right...I'm getting older also you know ![]() ![]() What I have done the last couple of weeks is polish the parklight bezels and bolt them onto the grill: It even has parklights Don't know if you can see it, but it works! I also put in the division bar felt in the ventwindow channel. Not the nicest thing to do, but it's in ![]() Those white things at the edges are the adhesive strips, those are gone now ![]() Until next time......
#764 |
Yeah
![]() ![]() Got both doors in today!! Driver side door has better gaps than the passenger side, but I can live with that. It's no show truck, it's a driver ![]()
#765 |
Coming along..... yeah i found that avatar pic online and just liked it as a "before" look for my build. Thats the color my truck was Im told before the rusty look started in on it...
Im sure it will be changing soon... ![]()
#766 |
Those parts look good Kees. Doors on, one step closer! Hope you are feeling better.
#767 |
![]() Join Date: Mar 2011
Looking good buddy...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#768 |
Superb work Kees, I'm starting to get ashamed of the state my truck is in.
the craftsmanship is amazing and I love the two-tone
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
#769 |
Looks good.
Kim |
#770 |
Inching closer and closer,good job Kees
Mark...
#771 | ||
Thanks a lot guys!!
I'm on my way back, as far as it goes ![]() Quote:
![]() This one has never seen a paintgun ![]() All is done with a roller, remember, I like 'm rough ![]() It's a driver (and I can't afford a $ 6000 paintjob...), if the blue paint wasn't so ugly I probably wouldn't have painted it afterall. Today I took the time to finally make the driveshaft loop: The loop is bolted down with four M10 bolts (3/8"). Only clean it up and put some paint on it. I also cleaned the right side of the Fleetside bed, the part under the bedwood. I must say, it's really clean, a bit rough but no rust at all ![]() After cleaning and inspection, I primered it with rust encapsulator/primer. This gets the same threathment as the cab: rust encapsulator - primer - paintable rubber undercoating and then 3 layers of shiny black paint ![]()
#772 |
Looks good.
Loop looks real close to drive shaft in pics. Kim |
#773 | |
Thanks Kim.
But keep in mind I have a Jag IRS in the back, solid mounted diff, so the only movement of the driveshaft is from the engine/transmounts. I also want to thank PTC for helping me out with some parts. Thanks a million times PTC!!! It feels great to have people around the world who are willing to help anytime! Today I got to the other bedside. There was a hole, made by the PO, that I had to close first. After welding and priming: Next I cleaned all the cross sills of the bed. That was a few hours to get all the 57 year old mess off ![]() Tomorrow it's time for the first layer of primer.....
#774 |
Bed repair looks good.
Forgot about the Jag rear end. Kim |
#775 |
Yeah, your bed is in great shape. I have a similar giant CB Antenna hole in my cab. Looking good.
Thread Tools | |
Display Modes | |
