#7851 |
Re: What did you do to your truck today?
I got the front of the rad support raised and was able to mount the first fender. I was also able to mount the Fender V-6emblem. I have literally waited 13 years to do this!!I need a hanky sniff, sniff.
http://s1299.photobucket.com/user/jb...23904108567829 |
#7852 |
Looks great Jake. How about a picture of the whole truck? I need to get by there and check it out.
#7853 |
Senior Enthusiast
Man that is really pretty. Nice panel alignment!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#7854 |
Looks AWESOME JB!
Ray and I put the 73 K10 308 posi in the 62 and got it back on the ground once again... We need to sort out rear shocks now. Monroe 59571's are too short. Then pinion angle, panhard, lines, etc. rg / ray~ray |
#7855 |
![]() Join Date: Aug 2008
Installed my alum grill and front plate today.
#7856 |
Your paint looks wicked in the sun, cool 66 plate.
#7857 |
Thanks- Originally from the buckeye state
#7858 |
Got the newly rebuilt radiator(thanks to C.R.S. $65 to seal tanks and rod out and repaint) filled it up with water and good thing after pressure built the weep hole in water pump wants show me it works. Got new pump in and he is running cool and no leaks. Next project cut the springs and open the pipes. Posted via Mobile Device opps I guess to it was to hot in Scottsdale today Last edited by 19666Trucker; 06-09-2013 at 08:03 PM. Reason: double picture snafu |
#7859 |
Post Whore
![]() Join Date: Mar 2013
Hauled some compost with mine to the other garden( ya gotta have two gardens cause ones never enough).
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#7860 |
Today I had intentions of upgrading to an HEI distributor. After much debate I dropped some cash on a Skip White dizzy. I went to Napa and picked up 65 vette 80mm plug wires. Checked current timing and it was set by the PO at 0 degree advance- no womder it ran like a dog (283). Verified the vacuum advance at different Rpms and determined it was all in at 16 degrees at around 2800 Rpms. Started to route the new plug wires and determtermined that wires 3&4 were way to short, back to nappy and same PN but correct lengths! but I had to raise the engine off the mounts to get clearance for the new fatter wires. I also spliced into the pink wire from the ignition to provide 12v to the new dizz. After hooking up the new skip white dizzy the truck had a hard time idling- even at 0 degrees and up to eight- it just wouldn't run. Acted retarded. Give it any vacuum FORGET ABOUT IT!!! It would die and usually ended in a poof of exhaust through the carb. Tried another coil(MSD) and it seemed to run worse... Verified plug wires to no avail. I eventually went back to the old points Delco Remey Dizzy and it purred like a kitten. Advanced timing to a total timing of 32- could advanced a more I think but for now it's much better. Gonna call skippy blanco tomorrow and have them send me a new dizzy cause I'm pretty sure something is a wry with this one. Eight hours later...
Posted via Mobile Device Last edited by punkrex; 06-10-2013 at 01:01 AM. Reason: Fat fingers |
#7861 |
After tons of scraping, wire brushing, power washing and repeating all steps several times, I got the front frame and suspension all painted.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
#7862 |
I decided to paint my truck myself--well maybe not the hood (that's all you can see while driving--right) grill and grill shell. will work my way to the big stuff.
1961 chevy K10 my build is------------61K10 build |
#7863 |
^^ Looks nice - like the color too ^^
I figured out my back shocks and put them on the 62. rg |
#7864 |
#7865 |
I did a parts trade for 61 hood grille ans support. Need the headlight bezels if any of ya have a set available, please let me know. Thanks!!
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
#7866 |
Senior Enthusiast
What a nice achievement. Looks great!
#7867 | |
Post Whore
#7868 |
Post Whore
Thinking of putting the tarp on mine today. It looks like its gonna rain in these parts......
#7869 |
"All anybody wants is a normal life and a cool car... most people settle for the car" - Christopher Titus 1966 Chevy C10 Pics Rust to Riding - Pictures of my build |
#7870 |
Thanks Mark!
#7871 |
64c20--there was a set on e-bay------
#7872 |
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#7873 |
Very nice! That seat cover and carpet would go perfect with my truck.
#7874 |
Started the notch.
![]() Posted via Mobile Device Posted via Mobile Device |
#7875 |
that is a Killer notch, wow I like it.
Thread Tools | |
Display Modes | |
