Old 04-08-2016, 08:18 AM   #1
Kim57
Kim57's Avatar
Re: Dutch '59 Fleetside Longbed
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-09-2016, 07:05 AM   #2
RockinKees
RockinKees's Avatar
Heel ff Sander 😂
You're not keeping an eye on me, are you??
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 04-09-2016, 03:56 PM   #3
63split
63split's Avatar
Originally Posted by RockinKees View Post
Heel ff Sander 😂
Just following the process the truck is in good hands for sure
63split is offline   Reply With Quote
Old 04-09-2016, 04:05 PM   #4
RockinKees
RockinKees's Avatar
Lots of work, such a Rat Rod
Cheers!! Kees.
Kool Guyz CC
Old 04-09-2016, 09:33 AM   #5
reaper71
reaper71's Avatar
Looking Good Kees!!
How much do you lack from finishing?
Mark...
reaper71 is offline   Reply With Quote
Old 04-09-2016, 04:02 PM   #6
RockinKees
RockinKees's Avatar
Originally Posted by reaper71 View Post
Looking Good Kees!!
Mark...
Well Mark, quite a lot
All those little things and one construction to be made, that is the tailgate.
I do not want those chains again, so I welded the holes shut in the bedside, maybe you saw that in the last pictures.
So now I have to make something work for the tailgate
Also a fair bit of wiring to do, with all that I want
Then I want to make the kickdown to work, it's electric thus must make a switch or so at the carb, plumbing for the propane, building doors, insulate the cab, reupholster the bench and so on...
So, not finished yet
But, I take my time, set deadlines and go over them all the time
Ha, I'm having FUN!!!
Cheers!! Kees.
Kool Guyz CC
Old 04-12-2016, 02:38 AM   #7
Steve-W
Steve-W's Avatar
Amen!! Deadlines were ment to be broken.��
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 04-11-2016, 09:20 AM   #8
reaper71
reaper71's Avatar
I understand that my friend!!!
These thing's suck up time like a vacuum!
So....a tailgate from scratch? can't wait..
Mark...
Old 04-11-2016, 10:17 AM   #9
lower50's
lower50's's Avatar
Having fun working on trucks is what it's all about.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-11-2016, 04:03 PM   #10
RockinKees
RockinKees's Avatar
Mark...
Uhm...no, I'm not that skilled
Have to modify my own old beated tailgate to work with a link assembly from a later truck....
lower50's
Yep, 100% agree on that!!
Even if it works against you
Cheers!! Kees.
Kool Guyz CC
Old 04-12-2016, 05:14 PM   #11
RockinKees
RockinKees's Avatar
Some metal work again today
Had to make a box around the fuelhoses / pipes, to make sure the soft spots are save from any unseen forces
There are ofcourse some rubber elements in the fuellines that I want to protect against vandalism, thats all
So, here we go!
The hoses and pipes:
Turning metal into shape:
Half finished:
It looks big, but in realtime it's not so big...
Now I have to think if I should make an underside onto the bed, so that it's closed (in metal or bedwood??) or if I leave it that way....
If you got ideas, please tell!!
This last pic is how it is behind the fueldoor (not fully mounted yet)
Cheers!! Kees.
Kool Guyz CC
Old 04-13-2016, 09:39 AM   #12
Steve-W
Steve-W's Avatar
.... that I want to protect against vandalism, thats all ....It looks big, but in realtime it's not so big...
I would close it completely, but in a way you can open it, just in kees (haha) you need access to it.
projects:
1969 Chevy C10
1950 GMC 100
Old 04-13-2016, 08:27 AM   #13
Kim57
Kim57's Avatar
Coming along real nice.
Kim
My build thread
Old 04-13-2016, 01:49 PM   #14
RockinKees
RockinKees's Avatar
Kim
Thanks Kim!
Steve-W
Well Steve, in that kees , the upper box is just bolted on, it's removable.
Maybe I make the rest from the same wood as I make the bedfloor from, just have to think about it some more....
Today I sanded and primered the rest of the inner bedsides and also primered the spears. Inner bedsides going to be high gloss black, the spears high gloss red, just as the cab ofcourse
Yeah, getting things done
Cheers!! Kees.
Kool Guyz CC
Old 04-14-2016, 09:24 AM   #15
reaper71
reaper71's Avatar
Looking good Kees...I would make most of it from metal, at least to meet up with the floor so it wouldn't stand out to much.
Just my opinion..
Mark...
Old 04-15-2016, 04:07 PM   #16
RockinKees
RockinKees's Avatar
Just my opinion..
Mark...
Thanks Mark, I probably close it the whole way down, metal seems the way to go...
Over to the TH400 kickdown switch. When I pulled the transpan, I checked if the magnetswitch for the kickdown worked. I can feel and hear it when I put some current on it, so I assume it works.
Now I must have a switch at the carbside to let it work as it supposed to be
Remember when I asked about the magnetswitch which was at the front of the carb?
Well, I cut its bracket up
I made this into a new bracket for a new Old School Microswitch
After a bit of tweaking and some professional adjustment , I bolted the switch at the carb.
When you push the throttle, it activates the switch at around 75 - 80% full throttle.
It can be further adjusted if needed because I made slotted holes where the switch is bolted on.
I don't know the normal adjustment of such a switch so I guessed it would be something like this.... Correct me when I'm wrong?
This is idle:
This is at full throttle:
I also measured the starter, because it made an awfull metallic sound when you started the truck. Looked like the startergear was all the way down in the flexplate.
I made an aluminium plate of 1 mm (19 gauge) and bolted the starter with plate back to the engine. Now I have the startergear about 3/4 of the theeth in the flexplate. I think this should be okay.
This is how it is on the starter:
Last but not least, I painted the inside of the bed high gloss black
And the spears high gloss red
I think its gonna be nice when finished
Until next time, sleep thight!!
Cheers!! Kees.
Kool Guyz CC
Old 04-15-2016, 06:17 PM   #17
Kim57
Kim57's Avatar
Black and red look real good.
Kim
My build thread
Old 04-15-2016, 07:17 PM   #18
Painted75
Great build! Especially given where you are. One question though, why didn't you carry the Red all the way around the taillight surrounds?
Painted75 is offline   Reply With Quote
Old 04-18-2016, 04:46 PM   #19
RockinKees
RockinKees's Avatar
Kim
Thanks Kim, I thought so too
Painted75
Thank you!
The reason why I didn't paint the whole surround is this:
The taillight bezel is mounted over the surround.
There's gonna be a white pinstripe between the red and the black, it isn't finished yet
About 6 months ago, I ordered the new bezels you see here. I ordered aluminium, only checked then if they were in the order I got. I just found out they are stainless
So I got a little lucky
Cheers!! Kees.
Kool Guyz CC
Old 04-19-2016, 09:14 AM   #20
reaper71
reaper71's Avatar
Looking good Kees!!
Mark...
Old 04-19-2016, 12:43 PM   #21
ptc
ptc's Avatar
getting done..... nice man! The black and red is 'timeless' for hotrods and bikes and white pinstriping it all will make it complete.... perfect!
I did a rendition of that on my last bike build but went with grey base and then red and white pinstripe instead.....
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 04-19-2016, 08:53 PM   #22
Advanced Design
Advanced Design's Avatar
Kees, the red and black looks really good!
Advanced Design is offline   Reply With Quote
Old 04-29-2016, 04:43 PM   #23
RockinKees
RockinKees's Avatar
Thanks Mark, Doug and PTC!!
Ptc, what you said about colors, I was thinking the same, red/black is timeless Hot Rod
I thought of grey with red spears too, or even mint green with black spears, all to get that fifties look.
I built and striped my bike also in that fifties look
https://lh3.googleusercontent.com/t6...=w1247-h935-no
Cheers!! Kees.
Kool Guyz CC
Old 04-29-2016, 04:58 PM   #24
RockinKees
RockinKees's Avatar
I did some small things last week, such as painting some ereas you don't see when mounted.
Perfect day to do some things:
Sanded all the parts, primered them and painted it gloss black.
Also took care of the rear inner fenders, got all the Californian Dirt off, took a couple of hours, good stuff
Set the inside in rustconverter, primered and then put them in paintable undercoating, just as the cab. Now a coat of three gloss black and on they go!
I also got all the coolant hoses in, bolted the LPG system in (propane), got the fillerhoses in and got all the pressure hard lines in. Only have the LPG electrics left.
I already did the fuellines from tank to filler:
And as Ptc said, we have huge license plates, so I made a little less huge hole in the roll pan, for excess the towhitch and plug
And, last but not least....I got the coolerlines for the trans made all the way to the cooler
The end is in sight.......
Cheers!! Kees.
Kool Guyz CC
Old 04-29-2016, 09:32 PM   #25
Advanced Design
That is some pretty countryside Kees!
Good work too, getting close to the finish line.
Thread Tools
Display Modes
