08-06-2008, 01:15 AM | #851 |
PROJECT 7DEUCE
Re: Die-cast 67-72
Man I still have the model truck I bult way back when I was a teen but it was black otherwise the same..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-06-2008, 01:22 AM | #852 |
Re: Die-cast 67-72
I wanted to share some of the ones I have out on display in my toy room...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
08-06-2008, 01:45 AM | #853 |
Re: Die-cast 67-72
Are there any other 76's ANYWHERE.
Enigma comin '09 Low-Riders.com |
08-06-2008, 07:10 AM | #854 |
Re: Die-cast 67-72
There are a few versions of that`76 Stepside model.Matchbox has what they are calling a`75 Stepside that there are two versions of so far,green w/white and a purple.There is another small scale I`m not sure who makes.It just came out and it`s clad in`69 Indy Pace Car paint.Ertl made a 1/25 scale die cast way back that I have two versions of.I don`t remember if I ever showed mine or not.
08-06-2008, 08:49 AM | #855 |
Re: Die-cast 67-72
Here are some more that I have in my office, that I wanted to share with you all.....
08-06-2008, 11:41 AM | #856 |
Re: Die-cast 67-72
Ok. I thought you were talking about the models you put together.
Here's the two Matchbox that special-k was talking about. 1:64 scale. They also have a black wrecker which they make in several different colors, but I only have the black. Last edited by 90\87Formula; 08-06-2008 at 11:55 AM. |
08-06-2008, 07:09 PM | #857 |
Re: Die-cast 67-72
Hey Doug. Here's what I was talking about in the PM.
08-06-2008, 09:42 PM | #858 |
Re: Die-cast 67-72
Good looking collection. What did you do with the extra set of red von dutch rims? Those would look good on either one of the actual high profile trucks.
If I run across two on my quest, I will let you know.
Hook'em |
08-06-2008, 11:15 PM | #859 |
PROJECT 7DEUCE
Re: Die-cast 67-72
Whats up with all those high profiles... did you make those or are those more that I need to be on the look out for?
08-06-2008, 11:34 PM | #860 |
Re: Die-cast 67-72
The top and bottom on the left are original High Profiles. I bought several extras of the High Profiles, cut them open on the back side; swapped wheels/chassis and put them back in. I'm going to try my hand at modifying the extras. Right now I'm working on making a duelie, using the rear fenders from a Hot Wheels custom 69. I cut the fenders off with a dremel tool. Haven't figured out how to attach them though. Maybe some JB Weld?
I'm also working on some extended cab Hot Wheels custom 69s. Not having much luck with those though. Last edited by 90\87Formula; 08-06-2008 at 11:39 PM. |
08-07-2008, 08:50 AM | #861 |
PROJECT 7DEUCE
Re: Die-cast 67-72
I guess ill be on the look out for the yellow and white dub city truck I have the rest and thank good you custom built those cause imma running out of space.
08-07-2008, 11:14 AM | #862 |
Re: Die-cast 67-72
Yeah, I know what you mean. Most of mine are stored in boxes. Heres a pic of the box the yellow/white comes in. (courtesy of Fleetside Paul) Do you have the black with flames?
They all came out around the same time a few years back, except for the High Profiles which came out last year; so the yellow/white and black/flames are really hard to find loose and even harder to find boxed.. The 5-Deep has the same trucks/cars, they're just painted different colors. |
08-07-2008, 11:18 AM | #863 |
PROJECT 7DEUCE
Re: Die-cast 67-72
I have the black one with flames but do not have the yellow and white one..
08-23-2008, 07:48 PM | #864 |
Old member
Re: Die-cast 67-72
Did this one this past week. Nothing fancy.
I need a favor from one of you guy's that has the 67-72 chevy truck rc body . I need to know how long it is between the wheel whales... center to center please.
08-23-2008, 09:45 PM | #865 |
Re: Die-cast 67-72
they have a long and shortbed versions,
shortbed: 11.4" http://www.prolineracing.com/p-402-chevy-c10-1972.aspx longbed: 12.6" http://www.prolineracing.com/p-531-c...-bed-1972.aspx then they have a little smaller body but im not sure the specs one that one http://www.prolineracing.com/p-380-chevy-c10-1972.aspx |
08-23-2008, 09:54 PM | #866 |
Resident of Here
Re: Die-cast 67-72
You guys keep em in wraps. I take ALL mine out and play with em. More fun that way.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
08-24-2008, 05:03 AM | #867 |
Old member
Re: Die-cast 67-72
Thanks for the link. I have some BIG BALLERS I may put one of those bodies on the frame. I think they should fit. I hope to find one locally.
08-24-2008, 06:25 AM | #868 |
Re: Die-cast 67-72
I`d like to find an ochre & white and a black w/flames Cheyenne by Jada,loose of not.
08-24-2008, 09:47 PM | #869 |
Re: Die-cast 67-72
andy, just in case you didnt know the bodies dont come panted to you would have to paint them yourself
72 Blazer 4x4 3 inch lift w/ 35" bfg a/ts |
08-25-2008, 10:36 AM | #870 |
Old member
Re: Die-cast 67-72
chevy72tk,
Yes I know. Thanks though. I have a couple of old RC trucks if anybody is interested in them. I'll take $500.00 for all of them. I have more than that in the yellow Clod Buster. It has a 4 channel radio. It will crab steer the hood comes up has real ball bearings in everything that moves. All the lights are functional. I have chargers and a little tool box full of spare parts and stuff. This blue one is just straight out of the box I built it to play in the sand with at the beach. It's great fun. Here is my dragter. This truck has a black magic motor in it. When I built this truck that was a top end motor of the day like 10,000 RPM motor. This truck will fly for a electric.
08-25-2008, 12:22 PM | #871 |
Old member
Re: Die-cast 67-72
I bought about 5 of these just to have them for projects. They have been sitting in the attic for who knows how long.
Here is the underside that will be the chassy for the new body. Just ordered two of the 72 chevy truck bodies. Should have them by Friday I hope. They come with the front back and side marker decals. That means all I have to do is paint them to match my truck. I'll keep this updated as I go.
08-27-2008, 02:27 PM | #872 | |
Re: Die-cast 67-72
Hey WES. Did you see that Marks-Collectibles10 on eBay is no longer a registered user? This is the guy we bought the JL Blazers from and had problems with.
Bump for your post also. Quote:
08-27-2008, 05:34 PM | #873 |
Re: Die-cast 67-72
Any idea of the cost to take one of the 72 truck bodies and make it RC? I would love to have one, but I imagine the truck shell is the cheapest part of the entire project.
Hook'em |
08-27-2008, 06:03 PM | #874 |
Old member
Re: Die-cast 67-72
Look on your local craigs list and see if anything is for sale or local paper pawn shop.
Yes the body is the cheapest part.
08-27-2008, 06:47 PM | #875 |
Re: Die-cast 67-72
Looky what I got:
Looks alot better with blackwall Real Riders I think.It was put back together w/rivets.So,I want to drill them out and paint it different.
Thread Tools | |
Display Modes | |
