10-18-2010, 06:02 PM | #951 |
Re: What did you do to your truck today!
It'll be cold here soon so its time for the work truck to work.
ROD 1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C. 1971 C20 Camper Special. 350/350. SOLD 2002 Chevy Tahoe LT |
10-18-2010, 06:04 PM | #952 |
it was already painted when I bought it. Not sure what he used but it is holding up great.
10-18-2010, 06:12 PM | #953 |
I took it in for a body shop estimate because some idiot sideswiped me.
10-18-2010, 06:32 PM | #954 |
10-18-2010, 06:32 PM | #955 |
Big Red - Now its a SWB!
I put on the 90's van marker lights that I picked up at a junk yard the other day. Then I put in a center seat belt. Installed a horn out of a ford explorer because the stock one in my truck was too weak. Degreased the engine because it was a mess from a p/s leak. And pulled my p/s belt so it will stop spraying fluid until I put on a new hose later this week. Man I feel bad for you guys that don't have power steering!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
10-18-2010, 06:45 PM | #956 |
I put new spark plus, wires, cap and rotor on. Degreased the engine and cleaned up the bay, filled up with new oil, and power steering fluid, and tranny fluid. Tuned the carb. Took off and painted my air cleaner and reinstalled and drove for awhile. Felt good after being parked for awhile.
Posted via Mobile Device |
10-18-2010, 07:34 PM | #957 |
Ordered the vinyl for the recovering of the buddy buckets and took the blazer to a body guy for a quote on installing new floor pans and rockers. Might be able to pull off both
10-18-2010, 07:36 PM | #958 |
Its a Truck Thing......
Put in an electric washer pump, wired it to the original switch and moved the washer sprayers to the wiper arms....
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" Last edited by 71meangreenc10; 10-18-2010 at 07:36 PM. |
10-18-2010, 07:44 PM | #959 |
I havn't done this listing "what I done to day" much ,,but today I made headway and feel like telling all ...I have every thing I ever done to my truck written down with the amount of time and the cost of every nut and bolt .. I installed battery cables ,put heat wrap around the starter,,and wrapped heat shield around gas line next to Manifold ,,drilled holes and hung the heat shield to the fire wall,,hooked up heater hoses ,,hooked up power steering hoses, screwed in tranny line fittings into the tranny and hooked up the lines to the radiator,,plugged the clutch hole in the fire wall .
Tried fitting up the modulator tube but it sure doesnt look it is the correct one so will go back to the wrecking yard and find another.. getting closer to crank up.. yahoo I guess is in order..LOL |
10-18-2010, 10:07 PM | #960 |
Registered Chevy Owner
Drove it like I stole it.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
10-19-2010, 12:51 AM | #961 |
pulled the whole front end apart on my '72 cheyenne donor truck with 5lug front disc to swap to my '70 c10 daily driver. started washing and glass beading the parts to prep for paint.
'72 cheyenne10 tilt, tach, a/c, posi '70 custom10- daily grind |
10-19-2010, 01:14 AM | #962 |
OK, not today, but yesterday. Got my fenders back on and fitted.
"nothing like an Old Skool cruise" |
10-19-2010, 10:03 AM | #963 |
Drove it for the first time in 3 years. Well yesterday was my second time, but man does it ever feel good!
10-19-2010, 11:13 AM | #964 |
^^^^^ Nice!
10-19-2010, 08:47 PM | #965 |
I primered the doors, painted the dash pad and visors from blue to black
A USED TRUCK IS A LOVED TRUCK! |
10-19-2010, 10:33 PM | #966 |
Installed the band-aid rockers from WES. Turned out great! Thanks Wes!
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
10-19-2010, 10:46 PM | #967 |
RAT1968 '68 Cab/'71 Parts
Not really *work* work on the truck.
We stopped by Early Classic Enterprises (Fresno/Clovis) and jawboned with Stan and Mark. Also, I loaded some build pictures here: http://tinyurl.com/27mch3q Not in any good order. But this is the place I'll keep loading them. Now I have to go away and spend more money on the web...Bye.....
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
10-19-2010, 11:13 PM | #968 |
Swapped motors in the car. Almost done. Truck will be next. I might install this in a truck or just use old heads. Block is back from machine shop for the truck. Still undecided if I should put blower back on or not.
10-19-2010, 11:58 PM | #969 |
I went to the bone yard and got an hei dist. that i may get to put in tomorrow. Then i will get my nieghbor to set the timing for me. I really need to get a gasket and change the tranny pan gasket on the th400.
10-20-2010, 12:22 AM | #970 |
Master Procrastinator
I stood in the garage looking at my sandblasted frame wishing my welder buddy was in town to do my frame work so I could coat it, then I picked up some tools for next weeks CPP delivery, came home and jumped on the board to do some research for the next few days work
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
10-20-2010, 11:26 PM | #971 |
Ordered $1600.00 worth of Parts from 3 Different Vedors today!
Almost ready for paint!!
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
10-20-2010, 11:27 PM | #972 |
That is an absolute SWEET STANCE on your Truck!!!!
10-21-2010, 12:06 AM | #973 |
x2, looks amazing!
Eric 1967 C10 LWB SOLD.... 1995 Ford F-250 4x4 Powerstroke, 342k "Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known." -Ronald Reagan |
10-21-2010, 03:40 AM | #974 |
Collector of Projects
I spent an hour or so trying to remove the thick black paint the previous owner put on the truck... I gues he thought a black truck would sell better.... dumb a$$ .... I used sandpaper and rubbing compund with a green scotch bright.... Not much shine left on the Ochre but its still 100 times better then the black...
10-21-2010, 08:23 AM | #975 |
2WD Jimmy
[QUOTE=mcmlxix;4252038]I spent an hour or so trying to remove the thick black paint the previous owner put on the truck... I gues he thought a black truck would sell better.... dumb a$$ .... I used sandpaper and rubbing compund with a green scotch bright.... Not much shine left on the Ochre but its still 100 times better then the black...
QUOTE] Completely Agree... I dont understand the black primer look that some guys like. How about some coarse rubbing compound and a rotary buffer? Last edited by Tom Vogel; 10-21-2010 at 08:24 AM. |
Thread Tools | |
Display Modes | |
