10-07-2009, 09:25 PM | #76 |
Re: Project NOT4SLE
Excellent. You going to paint the grill area white? In fact, what colors you gonna shoot anyway?
10-07-2009, 09:51 PM | #77 | |
Re: Project NOT4SLE
Overhaulin did a old dodge truck with the basic idea and I really like the way it turned out. SO I was thinking black interior with red trim or red interior... heres a sample of the truck form overhaulin If I do not go this route, it will probably end up BRIGHT blue... like ford or corvette bright blue. Your pic reminds me of a pic of me on my ski. |
10-08-2009, 01:40 PM | #78 |
Re: Project NOT4SLE
Well started the ole girl up, ran her around the block for the first time as well.
Ill have to figure out how to upload my cell camera to here or grab the digital when I go and smog her today "fingers crossed" otherwise its a hundred dollar smog. Changed the nasty nasty oil and ill run that oil for about hundred miles or so. off to Tuckers GOD I HATE THAT PLACE. Going to try and find a license plate mount and light as well as new taillights. that way it is possibly drivable to get a vin inspection, licensed and registered pending smog.... |
10-08-2009, 09:13 PM | #79 |
VA72C10
Re: Project NOT4SLE
Hope it all works out for you.
Looking for a 67-72 swb or blazer project in or around VA. |
10-08-2009, 11:05 PM | #80 |
Re: Project NOT4SLE
Awesome brother. Is that Lake Mead? Looks like you guys get some crazy waves there. We have to get behind a big boat to find wakes big enough to jump.
The avatar is actually my oldest boy. He was supposed to be giving me a straight line shot for an ad to sell that jetski but he caught a couple of waves and it came out of the water. Looked pretty cool though so I kept it. I have a couple of 01 GTX Lmiited's now so the GTS is gonna move on to the next family. I'll bet at least 50 different people have taken their turns on that GTS while I've had it and I've worn out a 2 person tube behind it. This is one my new cruisers. Current last max mph reads 68! Last edited by highperf4x4; 10-08-2009 at 11:10 PM. |
10-08-2009, 11:26 PM | #81 | |
Re: Project NOT4SLE
Yes, Lake mead will get upwards of 10 foot swells at time... yes 10 feet. figure the honda ski is 10 foot long and you get the idea. Anyways, come on out when the wind pics up we have areas that get HUGE waves |
10-08-2009, 11:36 PM | #82 |
Re: Project NOT4SLE
Well I ran some errands today and grabbed some parts, changed the engine oil, changed the upper radiator hose which no matter what would leak a bit at the housing (found a pin hole in it I think), and got to doing some more work on her. never got the truck out as the parts I needed to go to vin check were not installed till today.
I purchased a new set of rear bumper brackets. When I bought a cab a few months ago the guy gave me a chrome bumper. I bought the rear mounts and they are the exact same weight (on my shipping scale) as the ones on the truck and fit EXACTLY perfect. i also purchased a license plate mount and light as well as some tail light and reverse lenses. I had to stop installing the bumper as the chrome carriage bolts I had had a shoulder that was to tall after going through the bumper and the brakcets would not tighten down. Hopefully Tuckers will have those tomorrow when I run by. I also installed the seat and seatbelts as well When done I installed a new ignition bezel and switch. I had a problem which I thought was a solenoid or bad ground. Sometimes when cranking the motor it would just click and then crank. It ended up being recommended I replace the ignition switch and she fires right up now. The bad was the interior on this truck was what I thought in great condition until the new bezel chrome looks ten times better then the cigarette lighter bezel Tomorrow Ill be getting the correct carriage bolts for the bumper and getting it on. Then going to smog it and vin check, title, and register it. |
10-08-2009, 11:39 PM | #83 |
Re: Project NOT4SLE
Excellent. You lucked out on that bumper!
Good luck tomorrow! If I drive all the way up there for some jet ski riding then you better share them bud lights!! Last edited by highperf4x4; 10-08-2009 at 11:40 PM. |
10-09-2009, 12:00 AM | #84 |
Re: Project NOT4SLE
10-09-2009, 12:08 AM | #85 |
Re: Project NOT4SLE
10-09-2009, 10:33 AM | #86 |
VA72C10
Re: Project NOT4SLE
I think the reason the bolts wouldn't tighten is the bumper brackets are backwards. The pictures I've seen have them reversed from how you installed them. That might solve the problem w/out having to buy more bolts...
10-09-2009, 12:13 PM | #87 | |
Re: Project NOT4SLE
I ended up needing new bolts anyways. |
10-09-2009, 01:19 PM | #88 | |
Restoration Virgin!
Re: Project NOT4SLE
Good luck w/ the smog/ vin!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
10-09-2009, 01:50 PM | #89 |
Restoration Virgin!
Re: Project NOT4SLE
Is the thermostat housing leaking??.....If so, might want to buy thermostat housing at AutoZone....make sure it is the cast iron or aluminum one (don't buy those cheap chrome Mr. Gasket ones!!!).....then buy this Fel-pro prema-dry plus gasket....no sealer needed and it'll seal up that leak for good!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 10-09-2009 at 01:50 PM. |
10-09-2009, 03:46 PM | #90 | |
Re: Project NOT4SLE
Smog sucked. passed on the high side and 5 times to many HC on idle 700PPM allowed and I was at 3500PPM... any ideas? |
10-09-2009, 03:47 PM | #91 | |
Re: Project NOT4SLE
10-09-2009, 03:49 PM | #92 |
Re: Project NOT4SLE
Well I failed smog but heres a few more pics of the parts I purchased installed. Allowed is 700PPM and I had 3500PPM. At idle. the high speed was perfect or good enough I could drive across town to get it to pass but I should be able to get it in check.
Here I am trying to bend the bed out a little to fit the taillight lens. I know why they were not on when I got it. LOL |
10-09-2009, 09:19 PM | #93 |
Re: Project NOT4SLE
Well, take another crack at it with your idle jets adjusted to lean. |
10-12-2009, 12:03 PM | #94 |
Re: Project NOT4SLE
I adjusted the idle and timing a bit but have not had time to get back to the smog place yet. I have a 100 smog place I may be hitting up when I get back.
I am in Phoenix today and headed to MEsa later to meet up with Nate from Porterbuilt to pick up some more goodies for the truck. THen when I get home and have her registered I will be lowering the truck so I could double check wheel backspacing on my wheels and get them coming. Ill take a few "spy" pics around Nates place to see what is being worked on |
10-12-2009, 05:33 PM | #95 |
Re: Project NOT4SLE
Just left Porterbuilt, PIcked up my suspension parts. If I had Camera cord I would show you all the nice shiney suspension stuff. LOL
Nate is a top notch super nice guy. In case anyone was wondering. He was very helpful on some questions I had and took time out of doing "simple stuff" like making a chassis for a nova from scratch. |
10-12-2009, 07:20 PM | #96 |
Re: Project NOT4SLE
pics pics pics
10-12-2009, 08:09 PM | #97 |
Re: Project NOT4SLE
10-12-2009, 08:51 PM | #98 |
Re: Project NOT4SLE
ok,
you still didn't tell me if you were painting the grill white though |
10-12-2009, 08:58 PM | #99 |
Re: Project NOT4SLE
Lots of Porterbuilt goodies.
10-12-2009, 09:26 PM | #100 |
VA72C10
Re: Project NOT4SLE
Nice!!!
Thread Tools | |
Display Modes | |
