Old 04-04-2010, 12:56 AM   #76
nrb's70gmc
nrb's70gmc's Avatar
Re: HEI Ignition Problem
when i pulled the sock out i took it off the pickup tube (fuel) and actually it was fairly clean ( i cleaned it again anyway) and it was intact as well, it was also flexible-there were no holes either ---so i guess someone changed it before i bought the truck--
i put the new fuel filters on also today (i think the timimg is way retarded because it was a dog) and it was runnin really crappy
i retimed the motor to 8 degrees btdc---well test it tomarrow
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 04-04-2010, 12:58 AM   #77
nrb's70gmc
nrb's70gmc's Avatar
i hope im getting to the end of this problem
Old 04-04-2010, 01:09 AM   #78
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
Check the air/fuel mixture screws. they may have backed out a little by engine vibration and could be throwing off the idle once it warms up. This has happened to me before on my 68 442 with an edelbrock 1407.
I hope its just something simple, and your back on the road tomorrow!
Good luck bro.
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 04-04-2010, 01:13 AM   #79
highperf4x4
It's too bad you don't have another dizzy to drop in there to see if it helps.
What have you not changed yet? Spark plugs? Fuel pump? Wires? Coil?
Do you have a compression gauge?
highperf4x4 is offline   Reply With Quote
Old 04-04-2010, 01:17 AM   #80
nrb's70gmc
nrb's70gmc's Avatar
Good luck bro.
Thanks man, i just cant catch a break with this problem--
has anyone here ever had a vacum advace go bad? when i was timing the motor i unplugged the advance and the timimg did not move at all (plugged with my finger or open) the idle speed did not change at all either.
Old 04-04-2010, 01:20 AM   #81
highperf4x4
With the carb you're running the vacum advance is probably connected to the "timed" port. So it doesn't advance until you move the throttle.
Old 04-04-2010, 01:22 AM   #82
nrb's70gmc
nrb's70gmc's Avatar
i have not changed the vacum advance-wires,plugs
i have a new coil in there (2 months old)
visualy the wires look good as well as the plugs
the vacum advance is the only original part left on the dist..
Old 04-04-2010, 01:24 AM   #83
nrb's70gmc
nrb's70gmc's Avatar
i dont understand what that means, but the vacum advance is plugged into the carb (left hand side when looking at the carb. (the right hand side vacum port (or what ever it is) has a cap on it
Old 04-04-2010, 01:25 AM   #84
highperf4x4
The vacum advance won't cause the engine to run as bad as what you're experiencing. There would be a minor loss in power and fuel mileage but not much.
Old 04-04-2010, 01:28 AM   #85
nrb's70gmc
nrb's70gmc's Avatar
i have replaced the fuel pump as well but not recently ( a guy at kragen was telling me it may be the fuel pump) causing all thisd as well.
he said when it gets hot it will just stop pumping
Old 04-04-2010, 01:29 AM   #86
highperf4x4
You have 2 ports on the front of the carb. The passenger side is a "timed" port. That means it doesn't supply vacum unless the throttle is pushed. The "full" vacum port on the driver's side will supply vacum all the time. You will normally use the timed port.
Old 04-04-2010, 01:45 AM   #87
72swb_327stroker_?
knuckle buster..
Here goes a pdf manual for any 1403-1413 series edelbrock carb.
This always comes in handy!Edelbrock Performer series carb manual
I still think this is more fuel related than ignition... but they are so similar, symptom-wise it is hard to diagnose.
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 04-04-2010, 08:07 AM   #88
neba
a clear plastic fuel filter is less than 5 dollars and a easy way to see if your getting fuel. you can eliminate tank sock, fuel pump, or clogged lines. your problem is either fuel or spark. this will cut your search in half. if your engine stalls.open the hood and look at filter. if its empty you know its a fuel problem.
neba is offline   Reply With Quote
Old 04-04-2010, 09:04 AM   #89
jdstx
jdstx's Avatar
[QUOTE=nrb's70gmc;3894169]
one thing i cant understand
i have always had the dist dust cap (mallory sticker) sitting straight across like west/east--- it was parallel with the fire wall
This won't solve the problem, plenty posted on that already, however....
If the engine was turned with the dist. pulled, the oil pump shaft does not rotate. When the dist. is reinstalled it may not clock to the original position when it engages the pump shaft. An oil primer can be used to manually rotate the pump shaft a little at a time to get things to line up the way you want them. To avoid this, find #1 TDC before pulling the dist.
jdstx is offline   Reply With Quote
Old 04-04-2010, 09:48 AM   #90
nrb's70gmc
nrb's70gmc's Avatar
[quote=jdstx;3899850]
yes me to that is how mine has always been also , except the last time i put the dist in.
i get the #1 plug at tdc but when i put the cap on the dist. the rotor wont line up with the #1 post on the cap (when the cap is parralel) it bothors me because it just looks funny.
right now im just concernd about getting it running good again-
Old 04-04-2010, 09:51 AM   #91
nrb's70gmc
nrb's70gmc's Avatar
a clear fuel filter is what i use all the time (just put a new one on yesterday)
Old 04-04-2010, 01:15 PM   #92
72swb_327stroker_?
knuckle buster..
any news yet?
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 04-04-2010, 01:59 PM   #93
nrb's70gmc
nrb's70gmc's Avatar
any news yet?
dude its 20 degrees outside lol, but im thinking/hoping it is a fuel pump problem. i have a lot of things to do today. besides my truck.
alot of people are thinking its a fuel problem
i did go outside and hooked up some LED license plate bolts then my fingers were freezing.
i will let ya know monday or tuesday.
Old 04-04-2010, 02:02 PM   #94
72swb_327stroker_?
knuckle buster..
wow! thats cold as $h$#!
Damn, well hope all turns out well for ya!
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 04-04-2010, 02:18 PM   #95
nrb's70gmc
nrb's70gmc's Avatar
will let ya know for sure!!!
Old 04-05-2010, 02:01 PM   #96
mdwilf
mdwilf's Avatar
Could be the vacuum advance - take the cap off & if you don't have a vacuum tester, just put a hose on the vac adv & suck on it - you should see things move inside. If not, it's bad.
mdwilf is offline   Reply With Quote
Old 04-05-2010, 03:30 PM   #97
nrb's70gmc
nrb's70gmc's Avatar
UPDATE-
i started the truck up and was watching the fuel filter, it was full the whole time (including when the truck died a few times)
i have never had the truck die like that before just sitting (idling-warming up)
so i re checked the timing and it was at 4d btdc i was told 8d btdc was a good spot to start at.
so i timed it to 8d (was idleing way better and smoother) i let the truck warm up- i pulled out of the drive way and i felt the same old problem (hesitation,running out of fuel type feeling) so i pulled back in put it in park and was reving the motor at high rpm the motor is back firing or sputtering (i have never had this problem before either)
like i said the fuel pump is pumping the fuel because my fuel filter was full-
do these edelbrock carbs have a internal fuel filter? ware the fuel inlet is?
Old 04-05-2010, 04:56 PM   #98
nrb's70gmc
nrb's70gmc's Avatar
UPDATE
i guess the performer carbs dont have a internal filter (i checked mine)
earlier today when i had the engine running i was under the hood and the motor stalled i noticed a puff of whitish smoke came out of the carb (fuel filter was full)
now i know the both my modules tested fine but someone also said there modules tested fine also but they turned out to be bad.
guys im so confussed,lost,upset,pissed off
im a pretty mellow guy but when things like this happen (unknown engine problem) it is so damn hard to keep my cool.
Old 04-05-2010, 04:57 PM   #99
nrb's70gmc
nrb's70gmc's Avatar
i blowed and sucked on the line and i could hear things moving
Old 04-05-2010, 05:32 PM   #100
nrb's70gmc
nrb's70gmc's Avatar
could a alternater going bad cause these problem?? i have a 10 gauge wire
Thread Tools
Display Modes
