10-17-2010, 08:52 AM | #76 |
GoatLube Experss
Re: Favorite tool you own?
die grinder ! I have 5 diiferant ones and a ton of atachments for em, I use at least on one most every project I do . 4.5 angle grinder is a close second
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) Last edited by jitteryguy; 10-17-2010 at 08:54 AM. Reason: grahmer |
10-17-2010, 12:53 PM | #77 |
My 1/2 inch drive snap on ratchet with screw driver handle and my gear wrench ratcheting wrenches.
America is all about speed, hot nasty bad ass speed |
10-17-2010, 05:10 PM | #78 |
Today ? within the hour ? My propane torch and my HF pad "foam creeper"
Tomorrow ? Who knows
"I feel the need for speed!"... as soon as I am done with my nap. |
10-17-2010, 07:21 PM | #79 |
#16876
I love my foam creeper. I bought mine only after using yours. Great tool and it's not broken yet.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
10-17-2010, 11:59 PM | #80 | |
Later today my fav was the good ol' Vise Grips !
10-19-2010, 03:41 AM | #81 |
My new favorite got-to-have-it tool!
TORK-GRIP The Ultimate Torque Wrench Note: Conventional torque wrenches only work with expensive socket wrenches, and usually only with one size of those. Not so with the new TORK-GRIP Universal Torque Wrench! This tool is complete all by itself, and will attach firmly to any non-recessed fastener, nut or bolt. Compatible With All Of Your Existing Fastener Tools! For recessed fasteners, such as recessed crank bolts, Allen bolts of all sorts, Phillips and slotted-head screws, the TORK-GRIP Universal Torque Wrench can grab onto any 1/4", 3/8", 1/2" or even 3/4" drive socket, any Allen wrench, or any screwdriver-type handle! TORK-GRIP Universal Torque Wrench An Indispensible Tool for All Repairs It is well known that it is absolutely impossible to do any repair more complicated than an oil change without a torque wrench. Unfortunately, the old-fashioned torque wrenches available in the past have been useless by themselves, requiring an expensive set of ratchet socket wrenches to make them work. Not so with the revolutionary TORK-GRIP Universal Torque Wrench! Fully compatible with S.A.E., Metric, Whitworth systems! "Real World" ® Calibrations! Not visible on the prototype shown in the photo, the TORK-GRIP Universal Torque Wrench features the Real World ® calibration system! Old-fashioned torque wrenches from our pitiful competitors are calibrated in meaningless numbers. The TORK-GRIP Universal Torque Wrench, however is clearly marked in easily understandable calibration marks instead: Inertial Impact Alignment Tool Works as an inertial impact alignment tool (also known as a "hammer"), too! The TORK-GRIP Universal Torque Wrench is a solid, hefty tool, and can serve as a hammer in case of need. If the bulk of the tool itself isn't sufficient for your hammering needs, you can clamp any heavy metal object into its powerful curved jaws to increase its heft and hitting power! Great for Self Defense Too! The TORK-GRIP Universal Torque Wrench is also extremely useful in medium-duty hand-to-hand combat, due to its superior reach and ruggedness. You can even clamp a knife blade into the jaws when needed for that extra "edge" over your opponent.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
10-19-2010, 06:10 AM | #82 |
HAHAHA ^^
Its so simple! Why is this just developed?!? |
07-23-2011, 11:50 PM | #83 |
07-24-2011, 12:40 AM | #84 |
Hand Crafted C-10
08-06-2011, 10:20 PM | #85 |
my dad
08-07-2011, 12:23 AM | #86 |
Its been fixed once or twice.
Bruce 73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD http://i56.photobucket.com/albums/g1...Rusti192-1.jpg |
08-07-2011, 12:27 AM | #87 |
I have an IR231 1/2" impact I bought when I started at BMW 15 years ago. It still breaks loose bolts for the new kids when their composite guns just won't do. A little piece of me is gonna die when it finally kicks the can!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
08-07-2011, 01:34 AM | #88 |
~Rest In Peace~
my brain
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
08-07-2011, 01:59 AM | #89 |
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-07-2011, 09:05 AM | #90 |
08-14-2011, 11:57 PM | #91 |
Grandpa in the rustmobile...
vice grips my gfs dad calls me the vice grip man lol i have a teeny pair that i carry
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-15-2011, 03:24 AM | #92 |
Turbo Guy
Bandsaw. No need to get out the grinder anymore to make a tab or trim something.
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles. 1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit! Things I've broken so far: 12 bolt diff saginaw 4 spd many, many pieces Aluminum case Super t-10 4 spd |
08-15-2011, 11:22 AM | #93 |
here, just not logged in
Water hose... Don't have to spend $ at the car wash. Easier than pouring a bucket of water at a time on your truck.
08-15-2011, 06:22 PM | #94 |
My "little friend"...
1971 GMC C2500 Custom Camper - Second Owner. 350/TH350, Dana 60 Rear. |
08-15-2011, 07:02 PM | #95 |
everlast 100lb bag hanging a foot from the support wall with two ratchet straps and 4 grade 8 bolts holding it in place.... it keeps me from hitting the truck some times
08-15-2011, 07:23 PM | #96 |
Telescopic magnet with my mig welder a close second.
08-16-2011, 06:53 PM | #97 |
Hollister Road Co.
I'm not sure if its my favorite but it does save me the most work when I remove king pins
08-16-2011, 07:12 PM | #98 | |
Just do the bodywork and spend to many hours block sanding, that will keep you from hitting your truck.
08-16-2011, 07:54 PM | #99 |
08-16-2011, 08:14 PM | #100 |
Thread Tools | |
Display Modes | |
