01-18-2012, 12:42 AM | #76 |
Re: The 68 c10 plain and simple
Your truck is really coming along nice, the cab is at the same stage as mine was two weeks ago, I had to laugh when I seen your seat frame. As it looks the same as mine did, but I didn't really notice mine needed paint until I had a picture of it. I am sure you will get to yours as I had to tend to mine. Good luck with your build as its coming along really clean.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
01-18-2012, 12:48 AM | #77 |
thanks for the kind words the thing that makes it so hard is i love to drive it and it is my daily driver i guess i need to hurry up with the chevelle or camaro so i can do a proper tear down... and someday i hope i can save my old seat just couldnt help the $100 deal i got it make a world of difference
Explicit Performance "we build dreams" 68 ss 396 chevelle build aka black bettyhttp://67-72chevytrucks.com/vboard/s...d.php?t=504088 68 c10 50th anniversaryhttp://67-72chevytrucks.com/vboard/s...d.php?t=444579 68 camaro build http://67-72chevytrucks.com/vboard/s...=1#post5147614 |
01-26-2012, 08:09 PM | #78 |
motor and 308 rear end going in this weekend and some more work to the chevelle aka black betty and possibly bolting up the front clip on the 68 camaro
01-29-2012, 09:50 PM | #79 |
haha i have too many cars
i did anage to take a few pics of the truck so here they are
02-20-2012, 07:26 PM | #80 |
Time for new motor
I am waiting for the machine work to be done to my 68 dated 327 motor its being bored .40 cleaned i have 40 over flat top pistons the good 041 heads to put on it same holley strip intake and a m55a oil pump and the bump stick!!!!!!1 its ersons high flow 2 cam 479 479 235 235@.50 with a 108 so not much more than the 488 488 232 234 @.50 on a 108 that was in it i just hope it pulls well so im hoping to have the new motor in this weekend and drive it
02-27-2012, 12:08 PM | #81 |
so heres the new motor in the truck i happened to pick of the parts friday at 5 then had the short block together around 630 then went to the jet hot car show in burlington holley hill mall, so i got up about 11 on sat and got the old motor out and started to tear it down to get the tins and some other parts i didnt have like the oil pump bolt and so on and the steel drive shaft gear
heres some specs on the new motor 68 dated 327 .40 over bore std std crank .01 oversized bearings m55a oil pump 30w vr1 oil with extra zddp it has a erson cam 235 on both sides 479 lift on a 108 double roller timing set 041 69 dated heads with 194 150s holley strip dominator intake and the little 600 edelbrock wasnt enough for this new motor so i bolted my 600 holley on it and then basically i was done sat night at 2 in the morning besides putting in the antifreeze and and getting another carb base gasket but it fired up and ran great and has that same nice lick to it that it had before Ill have to post a video of it soon
02-27-2012, 02:15 PM | #82 |
Looks great!
http://67-72chevytrucks.com/vboard/s...d.php?t=355153 |
07-25-2013, 03:54 AM | #83 |
so Ive managed to get more done to my daily driver
even found a like new tailgate Put the whole truck in primer does anyone make any gold interior parts for these trucks? or seat covers? and i need the white door panels will post pics soon
11-16-2013, 11:19 PM | #84 |
Look up member truckseats on here. they can probably help you. any updates?
11-17-2013, 05:42 PM | #85 |
yeap its all in primer
and I managed to break a rocker note this is my daily driver Ill post a pic also check the video link to hear the 327 rocker broke!!!!! odd it happened with the erson high flow 2 cam, its 479 479lift engine, I think i will get the stainless ebay header next the jegs ceramic do not hold up front Back
11-18-2013, 12:44 PM | #86 |
Sounds good! That's weird about the rocker, maybe it was just a bad one.....
Thread Tools | |
Display Modes | |
