07-07-2012, 07:27 PM | #76 |
Re: 1975 Chevy SWB Fleetside
heres a couple pics taken moments ago, same angle. the 73-80 is a 76 to be exact and has the bumper still attached the 81-87 is an 86 and has no front clip or bumper.....
07-07-2012, 09:59 PM | #77 | |
72 BB C30 Super LongHorn
I just checked my 73 C/20 and it matches your pic. The truck is not here next to me; its at the mechanic's place. I'll text him & we shall see what he comes back with.. As I recall....I am almost certain that its an early frame. I remember needing to weld up a small crack in the front on the drivers side and your 1'st pic makes me belive that is what it looks like.
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 07-07-2012 at 10:06 PM. |
07-07-2012, 10:05 PM | #78 |
454 parts that I have been putting together for the swap...
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 07-08-2012 at 12:16 AM. |
07-07-2012, 11:03 PM | #79 | |
Looks like I am in LUCK! I tried to locate the VIN on the frame rails. I looked on the top of the rails all the way to where the frame dips under the cab on both sides yet I did not find them. Does anyone have a definitive location where the VIN is to be stamped on these?
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
07-07-2012, 11:06 PM | #80 |
The engine bay before I start swapping it all over...
07-08-2012, 10:03 AM | #81 |
haha explains your shotty bumper fit, but better they did that than butcher your frame!
07-08-2012, 10:29 AM | #82 |
Moderator
VIN is under the cab. It could be the full 13 digit VIN or a 9 digit partial like the original engine and transmission (Division number 1, model year 6, assembly plant designation 7, and build sequence # 8-13).
http://gmpartswiki.com/getpage?pageid=60415 http://gmpartswiki.com/getpage?pageid=60417
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-08-2012, 03:32 PM | #83 | |
although, I did try to see in that general area when I was in there. On top of the frame rail, side, or bottom portion areas? Driver's side or passenger's side?
07-09-2012, 02:04 AM | #84 |
Got a return call back from the engine shop.
My TH400 is done. Resealed, HD sprag installed, minor tweaks. He is working on the 496. The Camshaft ended up being an UltraDyne piece, prior to the company being bought out. He told me it was a US made piece; so good stuff there. .515 lift, 112 centers, 272 duration. Going to soften up the valve springs with a new set, just to be safe. Not revving this past 6000. Im kinda sold on using an MSD 8361; or an old 8460, bypassing the amplifier and using a 6ALN I have here. Got the wiring harness in route. Reseal the whole motor, along with new head gaskets. He thinks that he will be done by 7-15-2012 with both. The truck is up on the rack now. My guy has already begun to loosen up all of the leafs, U-Bolts, etc etc. Gotta get the auxiliary gas tank out and over there while it is up in the air for installation. I guess once all of the rear axle and leafs are swapped out, we can concentrate on the front end. Made arrangements to put the Truck on a frame rack; just to be safe. I see a minor twinge here and there from what looks like some minor front end damage a few owners before me. Once its all perfect, we can complete the front suspension and get her aligned ( After installing the engine/trans combo ). I am getting excited a little bit now. I can see some daylight now on completion of all the swapping
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 07-14-2012 at 05:52 PM. |
07-13-2012, 02:12 AM | #85 |
Just picked this one up tonite.
Foam is in very good condition! Tops of the velour are sorta sun damaged; will need to re-dye it. I will have to slightly modify the floor frame for it. Maybe some simple strap and weld in a bolt for stud mounting. It was a bit wider than my factory seat's bracket mounting dimensions. But, being that it's longer, I can narrow it to fit the GM mounting positions. Will need to make a center console cup holder for it. otherwise, its all in very good condition. Got it all for $80.00!
07-13-2012, 02:03 PM | #86 |
Its looking like your collection of parts is getting bigger.
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
07-14-2012, 04:17 PM | #87 |
OK, finally something to show you...
1975 SWB Progress... Here is the 10-Bolt posi installed with the custom made drop leafs. Notice that the old leafs were torched. The old truck 12-bolt will be junked; saving only the metal brake lines, etc... & the 12 bolt pinion flange, nut & washer. The prior guy wanted to have them re-arched! No way, as they are now brittle from have the spring tension removed. I forgot to mention that we used a 10-Bolt from a 1985 Suburban. Some of the small bolts were metric, others not; just fyi. Do note that we had to change the parking brake cables from the prior 12-Bolt into the 10-Bolt backing plates. The 1985 parking brake cables were longer than the stock ones from the 12-Bolt that were correct length for a SWB. A 2'nd fuel tank to be added. Will use a mechanical 3-port switch valve. .250 wall Class-5 Trailer Hitch; will clear the rear chrome bumper.
07-14-2012, 04:18 PM | #88 |
add pic...
07-15-2012, 03:49 PM | #89 |
After looking over the front end briefly, I noticed that I didnt have a front sway bar.
I went out and pulled out 2 extra front sway bars that I have from my 72's. I compared those to my 73 3/4 ton C/20. The 73 front sway bar appears to be a 1-1/4" bar. The 72 front sway bars I have measure out to 1-1/8" bars. So, I think that I will use the 72 sway bar piece. Does anyone have any suggestions on front a-arm bump stop insulators in URETHANE? Does anyone have any suggestions on the clam shell URETHANE motor mounts that either Energy Suspension or Prothane offer? The transmission URETHANE mount looks like that they are the same from either manufacturer. Does anyone have any suggestions on the rear axle bump stop insulators in URETHANE? Thanx!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 07-15-2012 at 09:53 PM. |
07-19-2012, 02:19 AM | #90 |
The Truck on the ground with the drop leafs and the 10-Bolt installed....
I like the stance. Might need a few 1000 miles on the rear leafs to get them to settle down. These are the leaf springs that I had custom made. I am going to order up some BB front coil springs and install those.
07-29-2012, 01:50 AM | #91 |
Updates...
Been a while, sorry. I do work alot and while working I try to amasss everything for the 496 swap. The 496 is done, blue-printed, and 99% ready for the install. TH400 will be done this coming Saturday. I purchased a new clutch for the fan blade. New hi-torque starter. The fan blade has to be powder coated Black. I couldn't have it chem-stripped as the caustic materials will dissolve the aluminum blades. Here are some images of some of the parts I have for the 496. Correct 454 pulleys, and misc stuff. I had everything chem-stripped. Will take everything in to be painted semi-gloss black once I have the PS pulley back....
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 07-29-2012 at 02:01 AM. |
07-29-2012, 01:57 AM | #92 |
more stuff chem stripped for paint...
07-29-2012, 02:06 AM | #93 |
454 Power Steering Pump 1973-1975 & 1976-up
I picked up a rebuilt 454 BB power steering pump. Question : Is the later 454 pumps using a press on pulley different from earlier ones using the front securing nut?
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 07-29-2012 at 04:16 PM. |
07-29-2012, 03:12 AM | #94 |
I think the press on pulley is for serpentine systems. I only say that because my '89 Suburban with a 350 has a press on pulley.
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
07-29-2012, 04:20 PM | #95 |
Here is the rebuilt pump I got...
The low side tube drop out is correct on the can. Looks like maybe a different front pump?
08-05-2012, 12:21 PM | #96 |
496 done!
Shop owner diassembled and re-assembled it. New gaskets throughout. 1 piece pan seal. Set at TDC/0*. Ready to fire. Just have to start installing all of the new parts onto it. The stock low plane 454 cast intake manifold was chem-stripped, gasket port matched, and recleaned prior to installing it. Having an 800cfm QuadraJet built for it. The valve covers are only being used as a dust deterrent until I determine which covers I will use. The TH400 is having the rear thrust bearing replaced. Original GM piece was showing signs of wear. Should have it back wednesday. Had my Allison convertor rebuilt with newer upgraded parts. 1400 stall.
08-05-2012, 04:11 PM | #97 | |
Mine has 1350 u joints. A t/a cover girdle strange c clip eliminators and a truetrack diff with 3.73 gears. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
08-09-2012, 02:47 AM | #98 |
I used earlier stock GM 28 spline type axles.
The only thing I can think of upgrading on the 10-bolt would be to incorporate FORD 9" style Torino side axle bearing style assemblies. OR Have a 9" rear axle made up for it. We shall see how the 10-Bolt holds up!
08-09-2012, 02:50 AM | #99 |
TURBO 400 done!
Allison Convertor rebuilt!
08-20-2012, 02:05 AM | #100 |
Just waiting on car lift availabilty...
Been buying up some small parts for the install. A new 800 cfm Quadrajet is being done down at my carb shop. Sent in 3 MSD distributors to be rebuilt. I have 3 MSD 8460's; old style MSD units with the 5400 amplifiers. One 8460 is missing the 5400, but was near mint. Gonna dial it in to work with a 6ALN I have. Otherwise I have a DUI HEI distributor ready to use. Question for you electrical guys : Can I run an HEI with the factory 1975 wiring harness? Or do I need to run it off of an accessory tab from the fuse block? I cant recall if the 1973-1980 Trucks had built in resistor wiring...
Thread Tools | |
Display Modes | |
