#76 |
Re: 6.2 starting issues
Took them out and put a + and - on them u until they got hot. Which was super quick.
Posted via Mobile Device |
#77 |
Moderator
![]() Join Date: Oct 2008
Geez. These GM/Navistar/AMG 6.2L & 6.5L Diesels are pretty simple. They need fuel at pressure, compression, and Glow plugs below 70degrees make it an easier start. But. They can and will kick off without glows.
You've got fire in the glow plugs. No question there. The only item you haven't verified is compression #s... But you stated it ran well before you ran out of fuel... I assume there was no smoke after the initial start-up puff when the engine was still cold? If this is all true the compression should not be an issue. This brings us back around to fuel. You've got fuel at the injector fittings with the fittings cracked open. Did it spray out with authority or just dribble out? A good DB2 Injection Pump is capable of 10,000 psi fuel pressure off the distributor head. Your injectors should pop at 1,800- 2,000 psi. I set my 76 & M1008 injectors to pop at 2,000 give or take a few psi. Just in case you nobody told you... Crack the fuel lines and stand way back as you crank it. DO NOT EVER get any part of your body near that high pressure fuel spray unless you are looking for mods via amputation. This is deadly serious. The pressures involved will inject fuel into your lower skin layers and kill large areas of your skin from the bottom up.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#78 |
It leaks out of the lines. Thats it nothing more
#79 | |
Just a dribble should be good, when I was test firing the 6.2 in the K30 it was just a dribble and then it fired up, took a while though. You might want to start a thread over at Dieselplace and see if maybe they can add something to help. http://www.dieselplace.com/forum/forumdisplay.php?f=20
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
#80 |
They started smoking, so I stopped heating them up. Besides they are about 3 months old.
How do you check if the injector pump is bad' it wouldn't push fuel to the lines right? Posted via Mobile Device |
#81 | |
I doubt running it out of fuel did anything to it, sounds like there is still air somewhere.
#82 |
Does the dual tank switch make much of a noise when switching tanks? I had a friend come over and assist me yesterday. He told me the switch seemed not to be working cause it wasn't locking into place. I have only been placing fuel into one tank. Should I be putting fuel into the other to the other tank to see if the fuel is just being feed by what's in the filter??
#83 | |
Then see if you can get it running. If it does run then move the jug to were the line runs to the fuel pump from the tank switch. Process of elimination, it's a hassle but need to rule out as you go.
#84 |
I have yet to try the latest advice.
Just an update. I moved it back into the driveway (wife didn't like that) to make it a motivator to keep working on it. Posted via Mobile Device |
#85 | |
cold it be a broken cam or off timeing on the pump? just speaking out load lol the only other thing i can think of is that the pump is not putting out the min pressewr to open the injectors
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
#86 |
My father swears by his mechanic s words that there is a manual fuel prime pump on this truck. Is this accurate?
Posted via Mobile Device Last edited by brown82; 11-30-2012 at 10:58 PM. |
#87 |
Not that I have ever known of
#88 |
Moderator
Not stock. If the mechanic installed one ask him where it is... It's a possible air leak location.
#89 |
Back to working on truck. Discovered a "hot" wire that seems to be hot at all times. Can you help?
![]() Connects to that block and runs over by the glow plug relay ![]() Posted via Mobile Device |
#90 |
I also found those purge valves, they are stock and built into the frame by the rear axle
#91 |
have you tryed just unpluging the glow plugs and hiting it with a little either?
#92 |
Moderator
That J block is supposed to be hot all the time. It's real easy to find it on the electrical diagrams.
I'm not sure what the black wire with the blue strain reliefs is for... It's not stock looking. I'd cover up the loose end or remove the hot end from the J block. If that loose terminal shorts against something it'll blow the fusible link at the starter.
#93 | |
Best to get the glows working. Head over the dieselplace.com they have a 6.2 section with some knowledgeable guys that will get fixed up.
#94 |
No mechanical primer on these trucks, wish there was... would save a lot of grief and wear on the starter and batteries.
#95 |
I no its nit a great idea but it will help to narrow it diwn to the plugs or fuel. I am not saying feed it with either just a shot ti get ut going. Why is every one so scard of either. If used right it is great. And if u are in to motors you no how ti use it. I know that detroit used either as a cold start aid abd same as cat
#96 | |
![]() I would get it cranking then hit it with ether. Don't spray the ether then try to start, it may lock up and the force will break the bolts off the starter. Ether fires before TDC that's why it is bad.
#97 | |
#98 | |
Lots of ether practice plus it smells good lol
#99 |
lol. i have seen some of the old diesel be rebuilt do to being either whores and still wont start with out it.
anyway back to the 6.slow lol. when mine would not start it was the plugs where burnt out now i am thinking with this one he is not geting fuel. just seems to be the only thiing he has not shecked but cant see why runing it out of fuel would junk the pump but what about the lift pump? not enough suplie? i no the cummins get really wierd when they lose the lift pump.
#100 |
Moderator
I agree that the lift pump is probably suspect. It's just a camshaft eccentric mechanical fuel pump like a good ole 350 with a carb. The diaphragm can fail.
The engine will run without a lift pump because enough fuel will continue to siphon from the tank to keep the injection pump happy. If you let air into the system, like changing fuel filters or running out of fuel, the injection pump is not capable of drawing fuel forward from the tank. If they're good the mechanical lift pumps work just fine. I've put electric lift pumps on my older trucks because I'm a darn lazy engineer. ![]()
Thread Tools | |
Display Modes | |
