Old 09-29-2014, 09:18 AM   #76
skymangs
skymangs's Avatar
Re: My 1950 Chevy "S-3100" Build (old+new)
Yup... Trim the rear of the frame to fit. Lookin good!
skymangs is offline   Reply With Quote
Old 09-29-2014, 10:25 AM   #77
CaliforniaDaddy
CaliforniaDaddy's Avatar
Saturday I started in on the front end. Im going to re-build everything up there. New wheel bearings, all new upper and lower ball joints,complete polyurethane control arm bushings and new brake rotors, and complete steering rack replacement. IE inner/outer tie rods and drag link and idler arm. I have only completed one side, but OMG its feels so much more solid. Took the sloppy right out of it.
“I would rather live my life as if there is a GOD and die to find out there isn't, than live my life as if there isn't and die to find out there is.”
CaliforniaDaddy is offline   Reply With Quote
Old 09-29-2014, 10:41 AM   #78
FarmerSid
FarmerSid's Avatar
Nice having a hoist.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 09-29-2014, 12:08 PM   #79
CaliforniaDaddy
Oh yeah, i wouldn't do have the things I do without it!!
Old 09-29-2014, 02:24 PM   #80
CaliforniaDaddy
well I have an opportunity to make a trade. Should i do it??? I have a local guy that really wants my OE 1950 chevy truck frame. he wants to trade me straight up for a 1950 5 Window Cab. So now im thinking put the 5 window cab on my S10 chassis and sell the 3 window cab???? What to do What to do!!!
Old 09-30-2014, 12:15 AM   #81
Henney
Did I miss what wheel/tire combo you're planning?
Henney is offline   Reply With Quote
Old 09-30-2014, 12:29 AM   #82
CaliforniaDaddy
20" Camaro SS rims
Old 10-11-2014, 12:02 PM   #83
CaliforniaDaddy
Well I got the front driver side finished, new rotors/bearings/bushings/SS brake lines/upper & lower balljoints, and the 2" drop spindle.
Old 10-11-2014, 12:06 PM   #84
CaliforniaDaddy
Also picked up a matching pair of solid OE bedsides and a new rear cross sill.
Old 10-11-2014, 12:10 PM   #85
CaliforniaDaddy
Here is probably my most fav part so far!!!!
Old 10-11-2014, 12:27 PM   #86
CaliforniaDaddy
yesterday I finished up the last step to getting my new CA tittle. I had to box everything up and go get a weight cert. what a pain that was!!!
Old 10-11-2014, 04:05 PM   #87
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice progress, and the gauges look sweet!
ChuckDriver is offline   Reply With Quote
Old 10-11-2014, 04:35 PM   #88
nvrdone
What did you do about the cab / chassis trade?
If it was up to me, I'd keep the 3 window cab. I think they are "cooler" and there were less of them made.
nvrdone is offline   Reply With Quote
Old 10-11-2014, 08:20 PM   #89
CaliforniaDaddy
Yeah I went and looked at the five window cab but it was junk no deal. However tomorrow morning I'm going to be driving down the hill from where I live to go look at a supposedly superclean three window 50 cab. The guy says it needs no metalwork, we will see. I'll be the first to admit I am a little bit scared to cut out all my cab corners and the floor etc. etc. so I'd rather have a cab that needs no metal patchwork
Old 10-11-2014, 09:28 PM   #90
IWanna49
IWanna49's Avatar
Lookin good CDaddy!! Great choice on gauges!
-Greg
'51 3600/s10 swap- in progress
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=641511
IWanna49 is offline   Reply With Quote
Old 10-11-2014, 09:40 PM   #91
CaliforniaDaddy
Yeah I'm glad I saved up all my duckets and decided to go with those ones
Old 10-12-2014, 03:12 AM   #92
47 Fasttoys
47 Fasttoys's Avatar
I also love the gauges, been looking at the same set for my project. Be sure to give us some feed back once you have them set up.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 10-12-2014, 03:32 PM   #93
tlorber
tlorber's Avatar
Cal daddy, I'm not sure why I only just found this thread, but it is great.
Do you know what steering column you used? I'm going to have a pretty tight clearance on my '54 so I'd like to see what will work. Also have you, or anyone else here gotten into cutting the inner fenders? I started mocking up the front sheet metal last night and those inner fenders take up way too much space in the engine bay.
tlorber is offline   Reply With Quote
Old 10-16-2014, 01:25 PM   #94
CaliforniaDaddy
This is the unit I picked up.
http://www.ebay.com/itm/32-GM-Hot-Ro...item5d4f2eab23
Old 10-16-2014, 01:35 PM   #95
CaliforniaDaddy
Small update, i found a KILLER deal on a very clean 1950 3 window CAB only very near my home. I pulled the trigger and now im going to use this cab and sell the other one. here is it. has only 1 rust hole and I already started replacing the driver side outer panel.
Old 10-16-2014, 01:36 PM   #96
CaliforniaDaddy
and a few more........
Old 10-16-2014, 01:38 PM   #97
CaliforniaDaddy
Started in on removing the outer driver panel.
Old 10-16-2014, 01:40 PM   #98
CaliforniaDaddy
And now on to the welding.....
Old 10-16-2014, 02:53 PM   #99
FarmerSid
FarmerSid's Avatar
Nice!
C4 IFS & D44 IRS
5.3 HO L33
Old 10-16-2014, 03:19 PM   #100
tlorber
tlorber's Avatar
Great find, and thanks for the pic on the steering column.
Thread Tools
Display Modes
