#1026 | |
![]() Join Date: Sep 2010
Re: What did you do to your truck today!
Good job Posted via Mobile Device |
#1027 |
RAT1968 '68 Cab/'71 Parts
Will the mock-up ever end?
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#1028 |
Welded a 5" long crack on the rear of my frame right where the bumper mounts, not too sure how it got there,the bumper i took off was welded to the frame so ether it was welded because the frame was cracked somehow? or it cracked from being welded? the crack was almost directly in the center of and parallel to the welds.
Also made and mounted a ground strap for my fuel cell and ran the sending unit wire up to the cab but did not terminate the cab end yet.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#1029 |
Oooo nice.
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#1030 |
me and my brother put headers on my truck and then drove it home 30-45 minutes with open exhaust. on wednesday i'll be getting the exhaust done.
#1031 |
#1032 |
it was a blast but most deffinately nerve wracking and i eas really nervous cause i saw two cops. a stock 307 open header sounds awesome the only problem was driving on the high way with a 3 on the tree she sure was loud then.
#1033 |
Collector of Projects
Got the new body mounts and ORD 1" lift blocks in place... took forever to get the bolts out without hacking to floor....
#1034 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Powder coated my hooks just gotta get some bolts for em.. Also picked up some weatherstrip adhesive for the new seals.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#1035 |
Bought some more Ralley wheels for it .I am currently running 6" van ralleys ,but now also have a set each of 7" and 8" truck ralleys .Now I need to figure out what is wrong with the sand blaster I borrowed so I can get them all blasted and painted and decide which ones to keep. My wife thinks it strange that I have 4 sets of wheels for one truck .
#1036 |
![]() Join Date: Oct 2010
Had a great time replacing the heater core in my 70 C-20. Found a bird nest stuck in there and while I was at it found got rid of some useless wiring that the previous owner had redone but never removed. I got heat now and a little less weight so she might go faster.
#1037 |
I had a productive day, I painted the inside of my tailgate, front bed panel, and the white on top of the doors. The paint is dupont light blue #507.
Tomorrow, I am supposed to get some parts that I order earlier in the week. New headlight bezels and attaching hardware, new door handles, and new rear cab molding. With in the next month I plan have on having the interior painted, seat recovered, new dash pad, and new carpeting. I am excited! ![]() Keith |
#1038 |
Pulled the 307 from the Burb. Now I'll clean up the engine bay and install the 350. Received the Goodmark rockers Friday for the Blazer. Thia week heading to Mich. to bring home a parts Blazer.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#1039 |
Check with Pep Boys if your looking for the inexpensive aluminum tube frame and tarp variaty, they usually have the lowest price. Whatever you buy make sure its fastened down to the ground, fence and even your truck this winter as the wind will want to take it away, I use bike tie down straps and rope, and pep boys even carries ground screws that are nothing more than dog runner lead screws from a pet store but they work.
#1040 |
Finally finished tearing out all the original ducting for the A\C and heater. Taped/ pappered everything up and now ready to start sanding and primer, sometime this week. As soon as I get a chance I'll post up some pics.
#1041 |
I've had another productive day! I finally had some time to take the grill out and sand it down smooth and paint it white. I also installed new head light bezels and my new chevy bowtie.
Everything had been coming along smoothly which is definitely nice! Keith |
#1042 |
PROJECT 7DEUCE
Got my radiator black from eastwood today so I can match my e fan shroud to the radiator..
#1043 |
Registered Chevy Owner
I went out and got this old radio for $10, and ya it works
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
#1044 |
Worked on the bed wood today. Cut it all down to size. I still need to notch the boards. But its looking like a truck bed again.
[IMG] Best part is both my sons worked on this with me. [IMG]
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#1045 |
Master Procrastinator
bed looks nice, I opened up all 8 boxes from CPP drooled a bit, turned the heater on in the shop, dropped off my lower ball joints to be pressed in and as soon as they are ready I pick them up and head into a hopefully somewhat warm shop and start painting all the new parts and final coat my frame in preparation for the rest of my parts needed to do the install of all my parts
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
#1046 |
put a new hei distributer in. The old rotor moved about a 1/4 inch. The rotor was hitting the contacts in the cap. How it ran is beyond me.
67 slider I like the bed. Most people avoid knots but for some reason I like the character. |
#1047 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Hung the fenders(temporarily)after installing the headers, and painted the new floor pans and rockers. Then reistalled the seat. getting ready to freshen up the fuel and light that posi up!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#1048 |
#16876
I walked by mine and ran my hand down the side as I went outside to work on the septic system.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#1049 | |
#1050 |
yes, i do
Damn, you guys are having a mild winter. My dad did say that it has been rather mild so far. Anyway i made a dump run in my 72. I need to get some sound insulation in that thing
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
Thread Tools | |
Display Modes | |
