Closed Thread
Old 07-21-2014, 10:17 AM   #1051
Revoh
Revoh's Avatar
Smile Re: What did you do to your truck today part II.
Originally Posted by markeb01 View Post
Yes, congrats on the win!
Thank you!
Revoh is offline
Old 07-21-2014, 10:18 AM   #1052
1963c-10
1963c-10's Avatar
Originally Posted by Revoh View Post
I'll have to go home and measure. It's the normal half-ton style that goes all the way out to the edge, so whatever that is. If you have an extra chrome one, I'd definitely like to buy it from you. I sure hate that I lost it, but I guess that's the way it goes sometimes.
Thanks!
Yeah, its the 10 5/8" cap then. I'll look when I get home. I have 2 complete sets...one for each truck and caps for the trailer project plus 1 for each spare. I think I have an extra one in there though. Will know tonight.
Worst case....I did see a single for sale on ebay last night. Saw a pretty dented up set of 4 also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline
Old 07-21-2014, 10:21 AM   #1053
TJ's Chevy
TJ's Chevy's Avatar
Congrats on the win!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 07-21-2014, 10:22 AM   #1054
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by Dillon Rock View Post
How's that engines top end looking?
Looks fine...won't know till I have it checked for cracks. lol!
Old 07-21-2014, 10:48 AM   #1055
Revoh
Revoh's Avatar
Sounds good--I appreciate you looking into it! I've been all over eBay and can't find a chrome one (saw the set $$$$), but maybe I just searched wrong.
Thanks!
Revoh is offline
Old 07-21-2014, 10:50 AM   #1056
1963c-10
1963c-10's Avatar
Thanks!
I'll see if I can find the single cap in case I don't have an extra. The set looks ok, but a lot of dents and he tries to get high $$$ on all his caps.
1963c-10 is offline
Old 07-22-2014, 08:18 AM   #1057
schpeen
schpeen's Avatar
ordered my Altman Easy Latch kit today
schpeen is offline
Old 07-22-2014, 09:37 AM   #1058
steveb64
steveb64's Avatar
You will like those latches. Clean looking and work great. Oh, and safe too.
steveb64 is offline
Old 07-22-2014, 09:45 AM   #1059
schpeen
schpeen's Avatar
I have to slam the door so hard to get it to close the inside door handle popped off onto the floor so I knew I had to do something! My friend has a new Mercedes and you just click the door shut and power motors draw the door in tight! pretty slick for sure but I figured the Altman route would be fine. LOL
schpeen is offline
Old 07-22-2014, 02:44 PM   #1060
pimpston65
pimpston65's Avatar
check'd clearance on my shroud, perfect fit...
pimpston65 is offline
Old 07-22-2014, 03:24 PM   #1061
1963c-10
1963c-10's Avatar
nice....looks great
1963c-10 is offline
Old 07-22-2014, 11:05 PM   #1062
robber grin
Added my homemade tins to the gap I had between my wheel tubs and bedsides since raising the floor 3", drilled the sides for the change in mounting hole locations, then ran some 5/16th" butyl along all the edges, and installed them in the bed with sstl bolts.
Happy Birthday to me - rg
robber grin is offline
Old 07-22-2014, 11:19 PM   #1063
tincan1966
tincan1966's Avatar
Prepped the new engine/trans combo to be installed this weekend for the new owner of my daily driver '65.
tincan1966 is offline
Old 07-24-2014, 09:17 AM   #1064
robber grin
Chased the threads on my tailgate trunnion and chain mounting points, then installed an old GMC gate that I have until I get the Chevy one ready to go.
rg
Old 07-25-2014, 08:32 AM   #1065
robber grin
Tried a spare GMC tail gate just to see how everything lined up & looked then started reworking the Chevy gate that needs both ends replaced.
rg
Old 07-25-2014, 09:05 AM   #1066
1961Apache
Repaired the Ranco heater valve in my 61 c20. Got the part at NAPA.
Takes time and patience, but cheaper than having it rebuilt.
1961Apache is offline
Old 07-25-2014, 07:11 PM   #1067
Andice
Andice's Avatar
I installed a remote spare tire filler hose. Now I can check and fill the spare tire from the upper hole in the rear license plate.
Andice is offline
Old 07-25-2014, 07:16 PM   #1068
pimpston65
pimpston65's Avatar
forget the spare, that truck is Da' Bomb. WOW oh so pretty!!! me likey alot...
Old 07-25-2014, 07:31 PM   #1069
Andice
Andice's Avatar
Well thank you! I like it too. It runs great and is a pleasure to drive - but completely stock so no power anything.
Andice is offline
Old 07-25-2014, 07:34 PM   #1070
pimpston65
pimpston65's Avatar
as it should be, bigblock 6. post some centerfold shots inside cab,engine bay i used stockers as a reference on my build. it may be GMC but alot carries over to the chevy boys...
Old 07-25-2014, 07:43 PM   #1071
VonDog
VonDog's Avatar
Installed a 1" phenolic spacer and cured the heat soak issues I've been having.
VonDog is offline
Old 07-25-2014, 07:58 PM   #1072
Andice
Andice's Avatar
Don't have many interior shots but here is one before the instrument cluster was replated and here is an underhood shot before the front end sheetmetal was attached.
Andice is offline
Old 07-25-2014, 08:00 PM   #1073
pimpston65
pimpston65's Avatar
i hate you, that truck is awesome 100points fersure
Old 07-25-2014, 08:03 PM   #1074
Andice
Andice's Avatar
I also installed the drivers side door check today. I used a GM part ($$) to replace the aftermarket crap that I had installed 18 months ago. Both aftermarket door checks failed after very little use. Both have been replaced now with GM 3794798.
Andice is offline
Old 07-25-2014, 08:08 PM   #1075
pimpston65
pimpston65's Avatar
again i hate u, i have aftermarket ones. where did u get the oem ones from?
Closed Thread
Thread Tools
Display Modes
