#1076 |
Re: My 86 build
got a maf for the motor, yolk for the trans, and I'm still waiting for the water pump to show up.....hopefully this week?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#1077 |
Re: My 86 build
I saw this pic at the beginning of your thread, I have rear slider window but missing the middle aluminum pieces. Would you mind selling the aluminum pieces that is shown in the pic?
![]() I will be happy if so. Thank you, Nasser
email me @ nasser_060@hotmail.com and Check out my flicker @ http://www.flickr.com/photos/0060/ |
#1078 |
Re: My 86 build
I'll see if I can find that old slider for ya...
#1079 |
Re: My 86 build
got some new stuff.....trans yolk, and a new maf....also ordered a flowmaster x-over kit......
#1080 |
Re: My 86 build
Thank you, will be waiting you.
#1081 |
Re: My 86 build
today I bolted the front end back on and got the rad in and mounted up.. till need a upper hose, and finnish wiring up the fans....also tried out the MAF, but I need to extend the wires for it to work......
#1082 |
Re: My 86 build
hooked up the MAF and the cold air kit.....
#1083 |
Re: My 86 build
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
#1084 |
Re: My 86 build
pushed 'er out side to get some sun.....lol.
#1085 |
![]() Join Date: Aug 2010
Re: My 86 build
Dude that engine looks amazing in there!!! Hey where dis you get your trans crossmember? What brand??
Posted via Mobile Device |
#1086 |
Re: My 86 build
it's a universal unit from Trans Dapt, that I modified a little for the exhaust.....
#1087 |
Re: My 86 build
one more...
#1088 |
Re: My 86 build
today I finished up the wiring, e-fans, brake switch, and ran the stock harness for the front lights inside the fender.... still waiting on the water pump to show up, then I'll install it, and the upper hose, as soon as I find one that fits....also need to get a conversion u-joint for the driveshaft, and then I can mock it up to see if it needs to be cut.... and I need to do something for the colum shift or go to a floor shifter,...not sure yet...that's about it.....oh yeah, and put the mufflers on....
#1089 |
Home Built '87
Re: My 86 build
Man you are making me feel bad b/c you are moving so fast on stuff that took me forever to do!! lol
I had to use a generic flexible water hose from Napa for my set-up to clear everything, just fyi.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#1090 |
Re: My 86 build
I'm goin with a f body pump, so that changes the outlet some, but there's got to be somethin thats close.....
#1091 |
78K & 79C Jimmys
Re: My 86 build
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#1092 |
Re: My 86 build
looks like storyland hill/river road??
#1093 |
78K & 79C Jimmys
Re: My 86 build
yup ,stopped to check things out
#1094 |
Re: My 86 build
picked up my x-over kit today, and ordered a lokar 1800 for the colum shift..and got a u-joint for the drive shaft......
#1095 |
Re: My 86 build
Nice build. doing alot of things i wish i could lol.. id love to do an ls swap down the road.. question though what did the everything to bag the front cost you ? not sure if you mentioned it before.. apprecate it. truck looks sweet
#1096 |
Re: My 86 build
the bags were roughly $100 a piece, and I made the mounts out of some scrap 1/4" plate......
#1097 |
Re: My 86 build
some pics of the x-over and mufflers....I started it tonight with the mufflers on....sounds awesome!!...
#1098 |
Re: My 86 build
I got a chance today to work on the truck, so I managed to get the u-joint installed in the drive shaft, and tried the driveshaft in the truck for a test fit..I thought I was going to have to cut it from what I've heard about the 4l80e being longer that the 700r4, but the driveshaft fit as perfectly as it did before!....
#1099 |
Re: My 86 build
...also the water pump finally came in the mail today!!
#1100 |
Re: My 86 build
....installed the water pump today....I think I found a upper rad hose that will work, should be in tomorrow....also the belt is close to the upper outlet,s o I picked up a smaller diameter idler pulley to give it some more room....
Thread Tools | |
Display Modes | |
