Old 04-23-2013, 12:38 PM   #101
mccurrkm
mccurrkm's Avatar
Re: 85 6.0 lq4 4.80e swap
well we took the thermostat out and now it is flowing fine. I guess I got a bad thermostat. My computer is also not turning the fans on so we have to figure that out and everything should be good. Maybe the tuner accidentally turned them off...
My 85 LQ4 Build
mccurrkm is offline   Reply With Quote
Old 04-27-2013, 08:10 PM   #102
chevybuilder18
chevybuilder18's Avatar
Originally Posted by mccurrkm View Post
Well it wasn't the thermostat. Still having the same problem. I guess it is the water pump. Either that or I have something stopped up. I have one big electric fan pulling and two smaller electric fans pushing air. The big one is set to come on around 190 and the smaller ones 195. I may have to change that later but that is what the tuner put in.
That sounds right on though. i dont think youd have to change the temp settings from 195..
glad it was the thermostat. hows it driving now?
auto parts stores get stuff mixed up. you may have had a hotter type thermostat. probably didnt open till 215 degrees. since your engine and the Ls is so close but different, not all components will be the same, some assume otherwise.
BTW im liking your thread keep it coming!
Her name is Quicksilver
1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER
gotta pay $$ if you wanna play
chevybuilder18 is offline   Reply With Quote
Old 04-29-2013, 12:28 PM   #103
mccurrkm
mccurrkm's Avatar
Seems to be doing fine now. That radiator is sweet, it looks like a waterfall when you have the cap off...lots of flow. I got the thermostat to fit the truck it came out of so it should have been the right one but who knows. Still have the problem with the computer not turning the fans on so I think we are just going to wire it up so that it comes on when the truck is running and the a/c fans to come on when the a/c is turned on.
My 85 LQ4 Build
Old 04-29-2013, 12:37 PM   #104
AJII
AJII's Avatar
I had the same problem with my thermostat in my swap.
I drilled a couple of 1/4" holes in the thermostat and this lets enough water flow through to make it operate as it should.
1985 K10 Under Severe Reconstructive Surgery
5.3/New Paint/New Interior/Yadda Yadda Yadda
AJII is offline   Reply With Quote
Old 04-29-2013, 12:49 PM   #105
mccurrkm
mccurrkm's Avatar
Good idea, I thought about that in case it was an air bubble causing it not to work. Thanks!
My 85 LQ4 Build
Old 05-05-2013, 03:11 AM   #106
chevybuilder18
seen this, its carbed but it makes a lil sense to put the fan switchs on the hose like he did... a bypass in the middle of thermostat and radiator. steam vent?? ik you guys have done the swap. but he points out some intresting stuff..
Old 05-06-2013, 12:34 PM   #107
mccurrkm
mccurrkm's Avatar
seen this, its carbed but it makes a lil sense to put the fan switchs on the hose like he did... a bypass in the middle of thermostat and radiator. steam vent?? ik you guys have done the swap. but he points out some intresting stuff..http://www.youtube.com/watch?v=RLaRLiqmDW0
What he did there was just put in a piece of pipe in the upper radiator hose with two fittings...one for the steam vent line and one for his temperature gauge I think. Good video with good info!
My 85 LQ4 Build
Old 05-08-2013, 12:36 PM   #108
mccurrkm
mccurrkm's Avatar
Got the fans rewired to turn the main one on with ignition and the other two to come on with A/C compressor. Cooling fine now. Went to charge the A/C and it won't hold vacuum. It was still pressurized when we took it apart. Took the hoses and all back down and checked everything and then when going to check it again, the fitting on the machine broke. Maybe it was just cracked and we didn't know it and there really isn't a leak in the system...fingers crossed. Waiting on a new fitting today and will recheck it, probably shoot a little die in it.
My 85 LQ4 Build
Old 05-28-2013, 09:02 AM   #109
mccurrkm
mccurrkm's Avatar
There doesn't seem to be a leak in the A/C. We shot die in it and took it all apart and still couldn't find a leak. It just has a hissing sound for a few seconds when we turn the truck off. Maybe it is supposed to do this It doesn't seem to be loosing Freon so I guess I am going with it. Put it all back together and then smelled gas...looked and its leaking from one of the fittings on the pump. Working on getting that fixed this week. Always something...
My 85 LQ4 Build
Old 05-28-2013, 04:38 PM   #110
truckzilla
truckzilla's Avatar
You are so right about that! It always seems to be something!
truckzilla is offline   Reply With Quote
Old 05-30-2013, 11:40 AM   #111
mccurrkm
mccurrkm's Avatar
Yep, never ends with my luck haha
My 85 LQ4 Build
Old 05-30-2013, 11:49 AM   #112
mccurrkm
mccurrkm's Avatar
Got the fuel leak fixed. Cooling systems is working great even with the A/C running which is also blowing good cold air. It needs a heat shield around the fuel pump as my exhaust is a little close to it. Hopefully we can get that done today and bleed the brakes and it should be back on the road.
My 85 LQ4 Build
Old 05-30-2013, 12:22 PM   #113
chevybuilder18
thats great! Do the Lq4s come with a 4L80e? i have a pcm for my LM7 for a 6.0 liter lq4
Old 03-07-2014, 08:28 PM   #114
low'n'slow
Put the drive shaft back in Saturday and it fit great! So I guess the yoke did swell a little when they welded it back up. Front clip is back on...power steering hooked up...now just have to finish the other hoses for A/C, heater hoses, and radiator hoses, then tidy up all the wires running around the engine bay. Also ended up deciding to run two more electric fans in front pushing for the A/C...ordered those today. Getting closer!
I'm doing this same swap in my 86. What all did you have to do with the driveshaft?? They say when you put a 60E in these trucks you can use the stock shaft with the right motor mounts...how much shortening did the shop have to do?
low'n'slow is offline   Reply With Quote
Old 03-26-2014, 02:21 PM   #115
mccurrkm
mccurrkm's Avatar
I actually have the 80e so I had to shorten it. It seems like I had to take off a little less than 2 inches. I can't remember exactly.
My 85 LQ4 Build
Old 03-26-2014, 02:27 PM   #116
mccurrkm
mccurrkm's Avatar
Just thought I would update a little bit. I have just been driving it on the weekends and taking it to truck club meetings and shows. I have still been having trouble at wide open throttle with surging and cutting out. The pump was starting to make a bunch of noise and starting to worry me some so I decided to pull the bed and replace the fuel system.
My 85 LQ4 Build
Old 03-26-2014, 02:28 PM   #117
mccurrkm
mccurrkm's Avatar
Figured out why my fuel gauge worked sometimes and sometimes it didn't...
My 85 LQ4 Build
Old 03-26-2014, 02:30 PM   #118
mccurrkm
mccurrkm's Avatar
Broke a tank strap and couldn't figure out how to get rivets back in that small space so I did the next best thing...then painted them.
My 85 LQ4 Build
Old 03-26-2014, 02:34 PM   #119
mccurrkm
mccurrkm's Avatar
I originally had some help with this install and the fuel system is a part I did not install. When I took this system out I figure out pretty quick why my fuel pressure was so unstable. Take a close look at the fuel pump placement lol.
My 85 LQ4 Build
Old 03-26-2014, 02:37 PM   #120
mccurrkm
mccurrkm's Avatar
Got the new system installed and painted the frame a little. Seems to be running just fine right now with no leaks so I'm ready to put the bed back on. I also installed a new grill a while back so just throwing in a pic of that as well.
My 85 LQ4 Build
Old 03-26-2014, 02:51 PM   #121
Cherub
Cherub's Avatar
looks good man
Cherub is offline   Reply With Quote
Old 03-26-2014, 03:06 PM   #122
cleansquare
Wow glad you pulled the bed huh!
cleansquare is offline   Reply With Quote
Old 03-29-2014, 09:29 PM   #123
iceship
so what type of gas mileage are you getting in it. ..
iceship is offline   Reply With Quote
Old 04-30-2014, 10:11 AM   #124
mccurrkm
mccurrkm's Avatar
I think somewhere around 18...I'm not positive since I don't have my new gauges yet.
My 85 LQ4 Build
Old 04-30-2014, 10:13 AM   #125
mccurrkm
mccurrkm's Avatar
Here is a video of it on the Dyno the other day...Put 325 HP and 324 TQ to the wheels.
https://www.youtube.com/watch?v=VA8CY9UPu9A
My 85 LQ4 Build
Thread Tools
Display Modes
