10-19-2014, 11:47 PM | #101 |
Camaro Club
Re: 88 silverado suburban
10-19-2014, 11:50 PM | #102 |
Camaro Club
10-21-2014, 06:30 AM | #103 |
Camaro Club
10-21-2014, 11:52 AM | #104 |
Nice work. Can you remove the carrier bearing and keep the crossmember?
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
10-21-2014, 06:35 PM | #105 |
Camaro Club
i was able to keep some of the crossmember. I did have to do some trimming on it though. The ford shaft bolted in like it was factory. And it eliminated all of the vibrations I was noticeing and some that I didnt realize were coming from the driveshaft. The whole vehicle feels tighter and smoother on take off and cruising.
02-16-2015, 09:33 PM | #106 |
Camaro Club
Dropped the burb off for some work. Having a local shop replace the Front axle U-joints, Ball joints, and bearings and seals if needed. The U joints on the ends of the front axle shafts were shot. I dont know how they have stayed together this long.
02-17-2015, 09:17 PM | #107 |
Camaro Club
They installed 4 new ball joints with grease fittings, 2 new greasable axle joints, bearing seals, and drag link. I still feel some wandering in the steering. Wandering if the gear box is just worn out.
02-25-2015, 11:31 AM | #108 |
You have a very cool rig here! I don't recall seeing a granny gear trans in a Burb before. Good job.
Romans 10:9 - The Truth |
03-28-2015, 02:01 PM | #109 |
Camaro Club
Thanks. I havent seen another one either. Getting ready to go pick up some brake parts at o'reilly's. I replaced the master cylinder with a brand new Duralast unit because my pedal was always hard and sometimes didnt want to return, but now I have a broken bleeder on my left caliper. Then while trying to get it out i broke a screw extractor. So I did some calling and decided to spend the $22 and just replace the caliper. Might even grab a set of pads while I am at it, these ones still have some life but look like they are going to crumble.
04-04-2015, 06:35 PM | #110 |
Camaro Club
04-05-2015, 07:51 PM | #111 |
Camaro Club
10-25-2015, 07:54 AM | #112 |
Camaro Club
10-25-2015, 11:59 AM | #113 |
Looks real good. Been driving it much?
10-26-2015, 06:26 AM | #114 |
Camaro Club
not as much as i should. We take the kids to the drive in movie in it and i have done a few car shows but it mostly sits. the spot that i have to park it in my yard isnt convienient to drive it daily
10-28-2015, 07:48 PM | #115 |
Great job and nice work.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
11-20-2015, 10:31 AM | #116 |
You did an AWESOME job!
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
11-21-2015, 08:03 AM | #117 |
Camaro Club
thank you. The family and I took it out on Sunday drive last week and tried to get lost on some back country roads. We had a blast and that old 4 speed is alot of fun
11-21-2015, 02:04 PM | #118 |
Great looking Suburban. You did a good job of the lift: not too much but just right. I'm not a huge fan of all the modern rigs out there that people jack to the sky - you did a good job to respectfully stay out of that crowd. Well done!
11-22-2015, 06:18 PM | #119 |
Camaro Club
Thank you. I was trying to keep a stock-ish appearance but with a little of my own style. I like to look at huge trucks but with a wife and kids they just aren't practical.
03-23-2016, 08:30 AM | #120 |
Great find on that 1 pc driveshaft. I really wish I could find a 1 pc for my crew cab short bed build. I really hate 2 piece drive shafts. I am converting my 88 crew cab to 4x4 as well. I had to use the same slot deal for the engine xmember. If you have the time you should check out my build thread and see if I made any visible mistakes.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF 2020 1500 Silverado 3.0 Babymax 2002 2500 Silverado- 6.6/ Allison 2010 CTS V- The "NastyBuzzard" 1979 Trans Am - Eventually getting 6.0/T56 swap with boost |
03-24-2016, 09:22 PM | #121 |
Camaro Club
I will check it out
05-30-2016, 11:00 PM | #122 |
Camaro Club
Well, I sold my original 14 bolt out of this thing so its time for paint!!!
Spent this evening stripping everything off of the roof so I can start prepping it. The plan is to start with the roof and paint and reassemble it before doing any other tear down. I just want to get the roof out of the way. Then couple small patches it needs on the quarters and tear the rest of it down to prep for paint. |
05-31-2016, 12:57 AM | #123 |
Nice. Keeping the same color?
06-04-2016, 05:43 PM | #124 |
Camaro Club
06-05-2016, 08:04 PM | #125 |
Camaro Club
Thread Tools | |
Display Modes | |
