#101 |
Re: '65 SWB Patina Build
Door patch is starting to look decent, after a TON of work. Ended up having to cut the fold of the door skin back to get the old stuff out which was rusted to the skin. Spot welded the patch panel to the outside skin, i'll grind it down and then fold the skin back down and weld. Ughhh. So much for a $60 panel. Fit was absolute ****.
#102 |
#103 |
#104 |
New poly cab bushings. Back on the frame.
#105 |
Holy **** that thing looks killer
#106 |
Thanks, I love this picture. My buddy said I shouldn't even C notch it, rear end is resting on the frame in this picture.
Driver side door is finished. My buddies dad did the finishing work on it at his body shop. Also put in new door hinge pins. |
#107 |
Haha I would probably notch it, might ride alittle rough
#108 |
Basically it would sit as it aired out all the way. Ride height would be a few inches higher, which would have no effect on ride quality. Notching would just allow me to set it down a little lower.
#109 |
Ahh I see what your saying, I think the stance is killer... Man I want to lower mine so bad but I have a lot of parts to buy to do it. Anyways when's the bed going on? you going to have to modify the rear tubs?
#110 |
Looking good man.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#111 |
Well I decided to ditch the 80 and go with a semi built 60 instead.
#112 |
Accidental double post, still running the 80 though.
#113 |
Ordered a PSI harness today. And if my VA money comes in the next few days I'll be purchasing a Circle D converter!
#114 |
Post Whore
![]() Join Date: Mar 2013
Looking good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#115 |
Been jammin right along on the truck. Not sure what color to paint the interior. Thinking a cherry red to match the wheels?
#116 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
I think that would be too dark.
Charcoal or fawn....Just my opinion.
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#117 |
Yeah, doing fawn with a black mat. PO painted the entire interior like a desert tan lol.
#118 |
I've been working on the brakes all weekend, adapting the 88-98 1500 stuff to my truck.
Essentially used a secondary bellcrank behind the brake pedal which actually attaches to the booster pushrod. ![]() ![]() |
#119 |
Need to flip the loop on the 3/16 line (although it would probably work fine as is). I just got tired and didn't get to it.
#120 |
Redoing all my lines in Copper, but I finally got to test out the front
https://www.facebook.com/video.php?v...92136505117898 |
#121 |
I took all my old brake lines out and replaced the lot with copper, you can't cut corners with brakes if you would ask me.
Nice looking patina truck ![]() |
#122 |
#123 | |
My Dloe valves just showed up. Building a really trick false cubby behind the factory ash tray for the valves and gauges. I've never seen anyone do it. |
#124 |
Ahh ok, sorry must have mis read it. You have any info on those wheels?
#125 |
They're factory 22x9 GM wheels.
Built a false ashtray to house my manual valves (Dloe's), and it will have an angled gauge in the corner. Best part is that it will look completely factory when the door is closed. ![]() |
Thread Tools | |
Display Modes | |
