Old 03-22-2016, 11:13 PM   #101
Devillusion
Devillusion's Avatar
Re: Project: ____________________________
Originally Posted by Dieselwrencher View Post
Great work on the cab! That fat mat looks great, but the new rockers have to be a great feeling!
ya, I'm glad that is all done. Hoping to get the cab into primer tomorrow or early next week for sure. I'd like to start putting some stuff back together so feels like I'm making some progress haha. Then start putting my drivetrain together into the frame. Have to go pick up my South Bend clutch/flywheel assembly soon too. That was a $1000 touch in itself.
As for the fat mat, it was left over from the dually crew, and the price is rediculous...so not sure I am going to continue. I bought a 2gal pail of lizard skin that will go in and out firewall and see how far it goes. I might just buy another pail or two of that instead as it seems to be more cost effective than the matting.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 04-01-2016, 03:04 PM   #102
aggie91
I'm just glad to be here!
aggie91's Avatar
Was looking back thru this one. Which Cummins swap brackets to mount the engine to the stock clam shell mounts on the frame (I know you upgraded to poly over the OE rubber)?
Thanks!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-01-2016, 09:52 PM   #103
Devillusion
Ones on Ebay for $222 per set. Make sure you use the prothane clam shell mounts, only ones I know so far that are proven not to self destruct.
1970 Chevelle
Old 04-25-2016, 12:00 AM   #104
Devillusion
Had this done for a few weeks now but just haven't had a chance to get stuff posted up. Been busy finishing the build on my new car hauler, dragged home a few flippers and keepers as well. Managed to find myself a 66 cadillac coupe de ville 2dr ht (no motor) but in decent shape. Always wanted one...love the 66's. So it will be home this week once I finish up the trailer beaver tail modification and mount my winch. Also dragged home a 49 merc that I'm gonna flip later on for some funds...hahaha.
Also finally ordered and recieved my southbend clutch assembly. Just sitting there waiting to be installed.
Anyways, on with the build. Finally got the lizard skin shot onto the inner floor/firewall and outter firewall. Honest opinion....won't waste my money on it again I don't think. Messy as ****, takes forever to spray it, dries on the gun tip fairly quickly, and really can't notice near as much difference as you can with the fat mat. But after that I got 3 good solid coats of Raptor liner on the cab inside and out after 2 coats of epoxy, and 3 coats of high build/sealer. Blocked it out and shot the bed liner. Decided not to use a paint code...rather just used straight silver toner. Long story....lol. So now cab is pushed to the side to cure and hoping to roll the frame in so i can start assembling stuff.
1970 Chevelle
Old 04-25-2016, 02:19 AM   #105
Chevy_mud_truck
Chevy_mud_truck's Avatar
I was kinda wounding about the lizard skin if it was worth messing with I was going to use the same bed liner on my floor top and bottom which lizard skin did you get the sound or the heat or did you use both
Chevy_mud_truck is offline   Reply With Quote
Old 04-25-2016, 10:04 AM   #106
Devillusion
Sound....
1970 Chevelle
Old 04-25-2016, 01:21 PM   #107
Chevy_mud_truck
thanks I'm not going to put anything on the floor of mine if other the just heavy coat of Bedliner I wish mine was as far along as yours looks good hopefully one day I'll get there
Old 05-16-2016, 12:59 AM   #108
Devillusion
Engine/trans/tcase in their new home, cab is bolted down, starting to assemble a few things on the cab/frame. Cut and welded up my cross over steering, XJ steering shaft swap complete, twin sticks extended and moved a bit for placement, 1" body lift in, wiper assembly installed, south bend clutch kit installed, ford steel rims blasted and ready for prime/paint, and a few other odds and ends.
1970 Chevelle
Old 05-16-2016, 02:28 AM   #109
MTCK
MTCK's Avatar
Very nice progress. That clutch is all that is man!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 05-16-2016, 02:03 PM   #110
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work! I'm really thinking about swapping over to a NV4500 in my 76.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-18-2016, 06:49 PM   #111
y5mgisi
Second Chance Program
y5mgisi's Avatar
Nice!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 05-22-2016, 08:09 AM   #112
brimc
brimc's Avatar
Very nice. I like the direction you have gone with The finishing on the cab.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 05-22-2016, 11:54 AM   #113
RUN GMC
RUN GMC's Avatar
Project LongHauler............very nice and unique specimen.......
RUN GMC is offline   Reply With Quote
Old 09-08-2016, 02:16 AM   #114
Devillusion
Well I've been MIA at the cabin/lake for most of the summer and haven't done much of anything really. Progress has been minimal at best.
I have the rear seats more a less mounted (2005 ram seats), fronts are mocked but not finished, front bumper is close to done (including winch mount), rims primed and painted, tires mounted (temporary ones), cross over steering in....bout it really. Hoping to get back on it in the next week or two and make some sort of bloody progress.
1970 Chevelle
Old 09-08-2016, 12:41 PM   #115
daddyjeep
daddyjeep's Avatar
I like the bumper. It follows the lines of the truck nicely.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 09-12-2016, 07:45 PM   #116
Dieselwrencher
Progress is progress. It is looking great. Lake time will sound great in January too. Haha
Ryan
Old 09-29-2016, 01:16 AM   #117
Devillusion
Well............no other way to say this but to tear off the band aid with one quick swipe.
This build can be added to my gracious list of unfinished/sold projects.
In my defence, with all the projects I wanted to complete there just wasn't enough time in the days anymore, and funds just can't support this many projects so something had to give. And in some ways unfortunately the crew cab had enough interest from some people it made sense to part it all out. Though there is some good news with this decision as well believe it or not.
The thing is, I didn't wan to sell my 68 suburban, or my 68 short box.....so I figured the best avenue at this point was to combine the cummins build with my 68 Suburban. I kept all the driveline and goodies from the crew cab and sold off darn near every single other piece of it here and there in a matter of a couple of weeks. Believe it or not I didn't lose any cash investment when all was said and done, in fact I came out ahead quite well. Not going to get my time back but some is salvaged in the burb build.
I have built square bodies for so darn long it the old "doing things over and over again expecting different result" is definition of insanity. I have owned/parted/built well over 50+ square body trucks. It was time for a change of pace and this was my chance to do so after finding my burb before there was not going to be a financial way out without losing cash invested.
That being said it all went to good homes and very minimal waste.
And as for the burb "the mullet" it has already been gutted of it's natural 2wd status, converted to tons, and sitting on 285s as we speak all in a matter of a couple days.
I will understand the disapointment...but it was a decision I had to mull over and make. The final decision for me involved the fact that there has been quite a few CC diesel swap trucks around and this definitely played a part in the decision. Around here locally I know of one 68 burb worth looking at and it is a more a less stock 2wd....so this burb build will at least stand out in the crowd locally and makes more sense to haul the family, dog and boat back and forth to the lake.
...anyway, is what it is. Thanks for the support and input in the project. Lots will be carried over to the new platform, yet taking a whole different direction on it in comparison.
1970 Chevelle
Old 09-29-2016, 01:23 AM   #118
Devillusion
Hopefully this softens the blow a bit.......
1970 Chevelle
Old 09-29-2016, 04:18 AM   #119
MTCK
MTCK's Avatar
Bummer. Glad you got what you needed out of it. Cool suburban.
-Marcus
Project Plow Truck
Old 09-29-2016, 07:55 AM   #120
y5mgisi
y5mgisi's Avatar
Dangit! That was my fear for this project but it was coming along so good! Oh well. There is always next time.
Old 09-29-2016, 08:41 AM   #121
68Timber
I know the pieces fit
68Timber's Avatar
Looking forward to seeing what you do with the Suburban.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-29-2016, 11:05 AM   #122
aggie91
aggie91's Avatar
So, where is the build thread on the 'Burb?
Karl
The LST Challenge:
Old 09-29-2016, 08:56 PM   #123
Dieselwrencher
No complaints here. I feel your pain and know all too well what several projects can do to your wallet and clock. I love 4x4 burbs, so this is a great choice IMO. I'm in to watch too. I've kicked the idea around several times here lately to part out my 76 and just build my crew 70-72. I just don't think the square stuff would bring enough for me to justify parting it in this area. Anyway, the burb is looking great. Can't wait to see the thread on it!
Ryan
Thread Tools
Display Modes
