#126 |
Re: 1963 C10 SWB Big Window Build
Sorry I meant the bed.
Which engine you going with? LS..ZZ? Your project is swaying to buy A 60-66!!!!! |
#127 |
Jesse
No, probably just a GM 350/290hp and then dress it up a bit. I would just like a clean new daily driver motor. I will go with a TH350 trans also.
I'm going to wait on the bed till i route the brakes lines. Thanks |
#128 |
Hey man your build is lookin awesome! I think a lot of people will agree that you have some awesome work and great progress going into this thing! I just wanted to throw my .02 in on the engine.
I got one of the same engines you are looking at getting for my dad's 71 K10 about 4 years ago. It ran alright for the first year and a half, didn't put a whole lot of miles on it. Maybe 10k at the most. Then it started to run a little sluggishly, and come to find out it had sunk a couple of exhaust valves! So after having the heads redone at around 20k we switched from an Edelbrock to a Holley carb and it opened up a little more power (now it could kinda roast the tires again). Then I put the last 10k miles on it and it just ran like a pig, had no power at all and got the $hittie$t gas mileage. I was working at a machine shop at the time(little over a year ago) building race engines, so I figured, what better time to tear this thing down and see what the hell was wrong!!! Anyway, I tore it down and to no surprise, the cam had gone FLAT and the crankshaft had more scratches and wear than the bearings did!! So I don't know if I just got a bad one or what, but I after seeing what this engine did, I am warning people about the lower level crate engines. We came to the conclusion that they must be using some sort of cheap castings in their components now. The block was just fine, a good 4 bolt block, but the components were garbage. It was unfortunate too that I was just beyond their 30k/3 year warranty.. If you would like to, PM me and I can hook you up with my shop in Elk Grove, not sure which part of Norther Cal you are in, but they can build you a great engine for close to the same price, and this way you have someone's shop to go back and talk to rather than being on hold on another 1-800 number lol. Joe
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) Last edited by skoffice; 09-02-2010 at 11:08 PM. |
#129 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
That last engine issue sounds to me like not running oil with proper amounts of ZDDP for a flat tappet cam. That's a sure way to wipe out a flat tappet cam and lifters. Then the resulting ground up cam lobes got pumped into the bearings, eating up the bearings and chewing up the crank.
#130 |
I always used race oil in it, SWEPCO. That stuff's like $9 a quart. I dunno that's just my experience with that engine, like I said, it could have just been a bad combination of things because the bearings looked like they they had 30k, but the crank, more like 150k lol. I just recommend building an engine that way you know what you have and somewhere to go to if you run into a problem.
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
#131 |
Jesse
Thanks for the input. I have herd things both ways on these engines. Some say the GM 350/260hp and below are made with less quality parts and the 350/290 and bigger engines are of a better quality. I like GM so i might just go with a new crate engine from them.
Here is the 350 i pulled from the truck when i bought it. It had a bad oil leak, The P.O. did not have the bolts in the fuel pump install holes in the front and i think he ran it low on oil 1 too many times. It had a slight quiet knock in the rear of the engine when it would warm up, but it ran great and solid with no smoke. I'm in the Lodi area and have herd good and bad about some of the machine shops also. I have herd Poorboy machine in Sac is a good place. I haven't ruled out rebuilding it yet. I like keeping my money with the local American working man. http://poorboysperformanceengines.com/index.html So at this point i'm still up in the air on which way to go. Thanks for the advice ![]() ![]() ![]() Last edited by DRTYRAT30; 09-07-2010 at 07:57 PM. |
#132 |
Jesse
#133 |
I was in the same dilema.
I ended up remachining and cleaning up my original motor. New paint New carb All new Accessory drive system All new pumps and alternator New Distributor. |
#134 |
I like your style...good work and awesome truck!
#135 |
Jesse
I got the low hump out.
#136 |
Jesse-
It looks to me that you just removed the "high hump". I could be mistaken (it's been a long day in the sun) but that looks to be the high hump for the 60-66. The front section is spot welded to the floor/firewall and then half of it is a bolt-in cover.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#137 |
60-66 Nut
No it is a low hump, if you look a little closer at the rear of the cover you will see is lower than the front and then it steps back up. Some of the low hump trans covers were a bolt in and some were just a part of the floor and not removeable. With the removeable low hump trans cover, you shouldn't need to change the front section that is spot welded to the firewall. That should match up with the high hump cover.
#138 |
Jesse
My truck was a low hump as you can see in this picture. Some of the 60-66 floors cam with a bolt in low hump and some had a solid formed floor.
Captnfab: In my application the spot welded front section of the low hump has to be changed, it is a different shape than the weld in high hump front section. see pics below. My Low Hump that i took out ![]() The comparison of the High hump section and my Low hump section on the right. ![]() And two pics of a Bolt in Low hump (1st pic) and a Solid floor Low hump (2nd) ![]() ![]() Last edited by DRTYRAT30; 09-07-2010 at 08:11 PM. |
#139 |
Jesse-
No need to edit the post! We are all big boys here. I can handle the humor and not take offense! Just had not yet seen the bolt-in low hump... yet! I should have known better... like I mentioned, I turned off my brain this weekend and sat in the sun for too long. ![]()
#140 |
Jesse
Ahh you seen that
#141 |
Oh and those Gas Adjust Hood Hinges are sick man..
What is this? something new? |
#142 |
Jesse
#143 |
60-66 Nut
Hmmm I could have swore the high hump cover bolted in place of the removeable low hump. I can see that it will not.....been a long time since I've dealt with that.
Your build is looking excellent ![]()
#144 |
Oh you aren't far from Elk Grove at all. I was just down through Lodi to day actually. Went to Cherokee Truck Parts to get a bumper for my friend's Peterbuilt.
Ya that picture of the two pieces is deceiving haha I thought it was the high hump too! Well if you ever have any questions on rebuilding what you have let me know I can hook you up with the place I use, Crackaway Engine Machine. They are up here in EG and they do AWESOME work. Are you going to be going to Kingdon this weekend??
#145 |
Learning As I Go
damn you are literally layin frame this is the sickest slammed truck ive seen so far
1972 Chevy C-20 Longbed 2wd Granny Low with a Crate 350: Air Gap Manifold, Edelbrock 600cfm, HEI, Headers to a 40 series flow (soon to be dual again) |
#146 | |
Registered Loser
I don't know how you people can completely dismantle and rebuild a truck and still keep your garage clean and organized ![]()
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#147 |
Did you decide which way you where going on the motor? New or rebuild the one you have? Did you get that high hump installed?
Tony from Norcal |
#148 |
Jesse
Yes, i went with a new GM crate 350 3yr/100k warranty at my local chevy dealer. And i will run break in oil with ZDDP and after for the flat tappet cam.
![]() I just took the high hump to work today to clean it in the blast cabinet and then i will fill/weld in the shifter hole and install this weekend. ![]() ![]() I found a new seat out of a 95' silverado for $45.00 on CL and it fits great, so i will take it to a local guy to have it recoverd like the red one in the 2nd pic below. All the dark grey will be burgundy viynl and the light grey will be the light red cloth. ![]() ![]() I sealed up my rearend and put some fresh Lucas oil in also. ![]() Thanks for the comments everyone... |
#149 |
Looks great man. Ive never seen anyone put a breather on a diff like that tho.
USMC Former SGT 2002-2006 Oshkosh Truck Corporation- FSR, The worlds largest manufacturer of Severe Duty Trucks. The Money Pit. http://67-72chevytrucks.com/vboard/s...d.php?t=406891 2009 2500HD R.I.P. http://67-72chevytrucks.com/vboard/s...12#post4025612 |
#150 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice job! That breather beats the heck out of an open hose like you see a lot of times.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Thread Tools | |
Display Modes | |
