Old 04-23-2013, 04:48 PM   #126
Painter D
Painter D's Avatar
Re: Locomotive Lugnut
Made a little more headway. I got the cab back on along with some fresh body mount bushings, in the process I ended up shimming the cab (body) up an 1/8" to give the trans a little more breathing room. The wiring harness has been laced on the motor and the gas pedal, TAC module , OBDII port, and fuse block have been permanently mounted. The inner fenders have been trimmed to fit around the IFS and are waiting to go to the powdercoaters ,while I was at it I threw some of the sheetmetal back on to start lining everything back up.
I've run into some issues with the exhaust, I've tried several different sets of headers and several sets of manifolds. None of them will fit. So I've been in touch with Delmo and he says he has a solution. I'll keep you guys informed on what we come up with. In the meantime here's some pics.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 04-23-2013, 04:50 PM   #127
Painter D
Painter D's Avatar
Some more
Old 04-23-2013, 04:53 PM   #128
Painter D
Painter D's Avatar
BTW ignore my messy shop it's in desperate need of a good cleaning. Ignore the two different colors of Dynamat too, I got all of it for dirt cheap.
Old 04-23-2013, 05:01 PM   #129
lolife99
67-72 parts collector,…
lolife99's Avatar
Man,... that looks sooo good!
Keith
Convert to disc brakes.
Old 04-23-2013, 05:10 PM   #130
hotrod1
56 - autocross
hotrod1's Avatar
Your truck is hot and your shop is far from messy. Wish I had a shop the size of yours.
hotrod1 is offline   Reply With Quote
Old 04-23-2013, 08:23 PM   #131
Kim57
Kim57's Avatar
That looks real sweet.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-23-2013, 08:49 PM   #132
Bomp
Bomp's Avatar
That is One Sweet Truck in the making
Bomp is offline   Reply With Quote
Old 04-23-2013, 09:12 PM   #133
Bennett68C10
Bennett68C10's Avatar
Looks great
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-23-2013, 09:29 PM   #134
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Freaking love it... Nice work D!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-23-2013, 09:30 PM   #135
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Btw... How's the little one?
-Nate
Old 04-23-2013, 10:56 PM   #136
Painter D
Painter D's Avatar
Thanks for all the compliments.
The little one is fine ,she's 14 mos. old now ,walking and getting into everything.
Old 04-24-2013, 01:16 AM   #137
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Well then it's time to get a paint gun in her hands.
-Nate
Old 04-24-2013, 12:41 PM   #138
_Ogre
_Ogre's Avatar
nice pic
shop air compressor timer
Old 04-24-2013, 10:11 PM   #139
Painter D
Painter D's Avatar
Yeah I like that pic too
Old 04-25-2013, 01:14 PM   #140
thump16
thump16's Avatar
Painter D: any word on the LS header solution?
thump16 is offline   Reply With Quote
Old 04-25-2013, 01:28 PM   #141
_Ogre
_Ogre's Avatar
needs to be lower, cut 4'' out of the doors
Old 04-25-2013, 04:16 PM   #142
Painter D
Painter D's Avatar
Not yet Im stumped when I get it figured out Ill post up some info
Old 05-11-2013, 11:05 PM   #143
Painter D
Painter D's Avatar
Here's the solution to the LS header issue.
I flew Delmo out here to solve the problem for me, he gave my truck the same treatment that Heisenburg received, some modified Corvette exhaust manifolds. Heres some pics
Old 05-11-2013, 11:08 PM   #144
Painter D
Painter D's Avatar
A couple more
Old 05-11-2013, 11:22 PM   #145
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Killer work.
There's always a way...
-Nate
Old 05-12-2013, 01:07 AM   #146
lolife99
lolife99's Avatar
Beautiful work on the headers!
Keith
Old 05-12-2013, 01:15 AM   #147
Kim57
Kim57's Avatar
Nice.
Kim
My build thread
Old 05-12-2013, 10:51 AM   #148
Bomp
Bomp's Avatar
Manifold miracle magic done right then and there!!
Old 05-12-2013, 11:30 AM   #149
SCOTI
SCOTI's Avatar
D.... Just got caught up. Where was the actual fit-up issue? Was it the collector position/placement of header that were available?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-12-2013, 12:47 PM   #150
Painter D
Painter D's Avatar
The frame rails are narrow with this PB front kit which limited the use of every set of manifolds and headers that I tried. The collector location was also in a bad spot on everything I tried as well. Modifying these Corvette manifolds was the most economical way to get the exhaust done. Along with collector exit locations, the steering on the driver side had to be accounted for as well, its really tight to get all of the variables between the frame rails.
Like I said flying Delmo out here was the easiest solution for me ,since he is the only other person that has built a truck that utilizes both an LS motor and the PB 55-59 kit.
Thread Tools
Display Modes
