Old 03-07-2014, 10:06 AM   #126
Smoothride
Re: Today was a good day
Looks good
Smoothride is offline   Reply With Quote
Old 03-07-2014, 03:56 PM   #127
Vova
Thanks- It's getting there. C-notches are going in this weekend.
Vova is offline   Reply With Quote
Old 03-07-2014, 04:16 PM   #128
Low Elco
This is cool. Love it.
Low Elco is offline   Reply With Quote
Old 03-09-2014, 03:06 AM   #129
Vova
I went with the Mustang tank. Both braces removed.
Had to cut about 1.5 inches of each frame rails to get it to fit.
Old 03-09-2014, 03:08 AM   #130
Vova
My helper.
Old 03-10-2014, 12:12 AM   #131
Vova
Got the tank fitted. Is the rear crossmember supposed to be at that angle or is it bent?
I'm liking how this tank is going to fit!
Old 03-10-2014, 01:39 AM   #132
swamp rat
swamp rat's Avatar
I've seen a number of the cross members here on the forum that are offset from side to side.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-10-2014, 12:28 PM   #133
mgkgmc
mgkgmc's Avatar
Its normal they are all like that.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 03-10-2014, 03:09 PM   #134
Vova
Good to know... Thanks-
Old 03-11-2014, 12:31 AM   #135
mattfranklin
mattfranklin's Avatar
Yes, they look great.
Originally Posted by Vova View Post
Did you get the axles OK?
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 04-16-2014, 07:59 AM   #136
Vova
Just a little closer…
Old 04-18-2014, 03:06 PM   #137
tinydb84
tinydb84's Avatar
I like that mustang tank. Does it have a sending unit? Where are the outlets for the fuel?
David
Instagram: myfabguy
Old 04-18-2014, 03:58 PM   #138
SCHRUMGMC
SCHRUMGMC's Avatar
I wouldn't put a damn bit of Ford on my Chevy.. JMO
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-18-2014, 10:44 PM   #139
Boog
laying low
Boog's Avatar
If you don't tell no one will know.
What is that about a 16 gallon tank? I like that it doesn't hang down much below the frame rails.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-19-2014, 12:48 PM   #140
Vova
Yes 16 gallons. Yes I didn't want it to hang down either.
Old 04-20-2014, 02:04 AM   #141
Vova
Top
Old 04-20-2014, 03:12 PM   #142
hfd410
hfd410's Avatar
I used the exact same tank in my 71. I used the Ford pickup tube and brazed a penny over the return. Then put a universal 90 ohm sending unit in the top of the tank and added a vent to the filler neck. The tank fits and works great. Best thing is that it doesnt hang down so low like the blazer tanks or some others. Dont let anyone discourage you from using parts that work. There are tons of '32 Ford coupes with LS engines. It works both ways....
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438
hfd410 is offline   Reply With Quote
Old 04-20-2014, 03:22 PM   #143
Vova
I welded my chevy unit to the end of the sending unit that came with the tank. Will know if it works soon.
I use whatever parts work best. I have an 85 Toyota rock crawler with chevy engine and dodge 1 ton running gear. Has a ford tank in it too.
They're just parts...
Old 04-28-2014, 08:12 PM   #144
Vova
Getting closer.
Old 04-29-2014, 03:26 PM   #145
Vova
Since the fuel fill on the tank is 2.25 I found this filler to mount in my bed.
will add a cover to keep just from collecting inside.
Old 05-10-2014, 05:36 PM   #146
Vova
After messing with the fuel sender with no success i ended up installing this. It work perfect with the new tank and is a goo
Amazon.com: Equus 7361 Chrome Fuel Level Gauge... Amazon.com: Equus 7361 Chrome Fuel Level Gauge...
Old 02-06-2015, 03:55 AM   #147
Vova
She's almost done. Just need to finish up welding the bed, bodywork, and touch up paint.
Old 02-06-2015, 09:40 AM   #148
67swb72klb
67swb72klb's Avatar
like the build but didn't see what year mustang tank is it
keep up the good work
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 02-06-2015, 11:54 AM   #149
Vova
http://67-72chevytrucks.com/vboard/s...d.php?t=602869
Old 02-13-2015, 09:55 PM   #150
Vova
Buffed half the truck. Not bad for 45 year old paint.
Thread Tools
Display Modes
