Old 09-29-2015, 08:15 PM   #126
Fitz
Re: "Brass Monkey".....Installing 4/6" ECE Drop Kit
Originally Posted by C10_ustacould View Post
Before and after drop comparison...
Attachment 1425325
Why not do a "before and after" handling comparison? When I used the ECE anti-roll barand 3.5/5 in drop kit and super trac bar I found the truck cornered as well as my old C4 Corvette!
Fitz is offline   Reply With Quote
Old 09-29-2015, 09:45 PM   #127
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Unfortunately he won't be able to do that... reference the post just above yours.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is online now   Reply With Quote
Old 09-30-2015, 07:52 AM   #128
Coursey
Coursey's Avatar
It did handle and corner much better. But the ride was stiff to say the least.
Coursey is offline   Reply With Quote
Old 11-12-2015, 12:42 AM   #129
Rafa72cheyenne
Rafa72cheyenne's Avatar
Originally Posted by Coursey View Post
New tires are on. Just waiting for this 12" snow to get off the roads so I can get to the alignment shop.
hey badass truck man!!
im waiting on my kit, to drop it just like yours.
cant wait!!
so what tire size do you have upfront??
and do you rub anywhere?
..I have 275 60 15 all around.
-RafaeL
Rafa72cheyenne is offline   Reply With Quote
Old 11-12-2015, 12:55 AM   #130
Rafa72cheyenne
nevermind! I re read this thread and it answered my question.
-RafaeL
Old 11-12-2015, 10:27 PM   #131
Rafa72cheyenne
does anyone know how to remove the tie rod from the spindle?
im having a hard time taking it off.. I removed castle nut already.
and im banging the bolt with a rubber hammer and im also banging the tie rod up but its not moving. any help thanks.
-RafaeL
Old 11-12-2015, 10:28 PM   #132
Rafa72cheyenne
and also does the tie rod go in the same way after I put new drop spindle on?
(wich is thru the top, the tie rod sitting on the spindle.)
-RafaeL
Old 11-13-2015, 07:20 AM   #133
Coursey
Coursey's Avatar
If you take a heavy hammer and hit the spindle where the tie rod goes in it should loosen the rod. I believe this is how ECE instructions say to do it.
You can also use a pickle fork but this will damage the rubber boot.
Old 11-13-2015, 11:20 AM   #134
Rafa72cheyenne
Got it!! Thanks!!
Old 11-15-2015, 06:22 PM   #135
Rafa72cheyenne
COURSEY the brass monkey you used to have ,,, did you ever put that 1" block in the rear?..
-RafaeL
Old 11-15-2015, 06:24 PM   #136
Rafa72cheyenne
if so, do you have any pictures of it. and did you have any clearance or rubbing issues?,,
**just a note: I plan to not carry any loads on my truck.
-RafaeL
Old 11-15-2015, 07:08 PM   #137
Coursey
Coursey's Avatar
No I never installed the 1" blocks. Didn't keep it long enough. I did not have any clearance issues. I did not c notch it. Never had any bottoming issues. If you did ever haul a heavy load you would probably need to c notch.
It is a good kit. But the ride is very stiff. I assume to keep it from bottoming.
Old 11-15-2015, 08:22 PM   #138
Rafa72cheyenne
thanks for the info!
-RafaeL
Thread Tools
Display Modes
