Old 03-02-2005, 10:43 PM   #151
Gee_Emm
Basically have been doing little things like interior pieces and then boxing them up. Got one bed side just about perfect, don't have much to do on the other bedside, just a patch behind the rear wheel and then I will have all of the body work done.
I don't really have much to show for my progress this time, most of the stuff I did has cleaning up and detailing various nuts and bolts and switches and I don't think anyone wants to see pictures of that. Good part about it is basically everything is ready to install once the body is painted.
Before
After some SEM plastic paint
Cleaning up radios and dashes is fun
Gee_Emm is offline   Reply With Quote
Old 03-02-2005, 10:46 PM   #152
Gee_Emm
Some more befores and after, about 40% of this bedside was cut out and replaced with better metal.
Old 03-02-2005, 11:04 PM   #153
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
lookin good
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 03-03-2005, 12:16 AM   #154
HuggerCST
HuggerCST's Avatar
What kind of patch panels do you need for the bed? I may have some.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 03-03-2005, 10:03 AM   #155
Gee_Emm
I finally found some, thanks anyways
Old 04-04-2005, 05:08 AM   #156
modmach1
modmach1's Avatar
Man what a progress!! I have just bought a 72 Jimmy myself and i wonder if the rear fenders are removeable with screws or have you cut them of?
Im waiting on my car...getting it tommorow maybe so havent seen so much on it
http://www.moldestuket.com
1971 Mustang Mach-1 429 CJ-R
1973 Mustang Mach-1 289
1975/71 Pontiac Firebird Formula 400
1978 Chevrolet C-10 Fleetside Longbed Scottsdale
1980 Pontiac Phoenix
modmach1 is offline   Reply With Quote
Old 04-04-2005, 08:45 AM   #157
jamis
F.A.S.T. president
jamis's Avatar
you should change you name to Dr. Gee_Emm with the major surgery that you have accomplished....ever count how many pounds of wire and bottles of argon you have gone thru. I'm hopefully about have way thru the welding and have used up 15 pounds of wire.....
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 04-04-2005, 09:16 AM   #158
Gee_Emm
Kinda both, they are bolted on in a few places and tack welded in a few spots.
Actually I havent gone thru all that much wire at all, probably not even 2 lbs, cutting wheels on the other hand..........
Old 04-04-2005, 09:56 AM   #159
modmach1
modmach1's Avatar
Originally Posted by Gee_Emm
Kinda both, they are bolted on in a few places and tack welded in a few spots..
That sounds good ! Did you use much time on each fender to get it off ?
Old 04-04-2005, 06:33 PM   #160
Gee_Emm
I didnt really take it off properly, I threw away the enitre body so I pretty much torched everything off.
Old 04-04-2005, 08:11 PM   #161
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
great work keep the progress pics coming
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 04-04-2005, 08:17 PM   #162
72MARIO
72MARIO's Avatar
Gee Emm,
Thats awesome work
I can totally relate with the amount of work involed getting all the missing metal back to where it should have been on the truck (Blazer) . I removed the entire floor from my 72 all along the firewall and along the back wall. I bought a parts truck and took the floor out of that cab and plug welded it into what was left of my cab. I also patched the box sides the same way only, I used a front fender it worked out perfect. A little filler on the inside and nobody can tell I patched it. It's a good feeling getting to bolt on all the parts onto the freshly painted body. I also got all the small parts boxed up or bubble wraped while I was finishing up the body. My bedroom was full of parts I am just getting it back now. Be sure to use the green 3M tape around the entire area you working it. It will save you lot's of chips. I also found that wrapping the ratchet handle with tape prevent's chips if you become careless and smack the body tighting bolt's.
When do you think you will start blocking it out ? I can't wait to see progress pics.
Later'
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-23-2005, 07:58 PM   #163
1972K5
gee_em - thx for pointing me in this thread's direction... What an amazing job you've done on that K-5!
As has been said, keep the posts/pics comin'!!!
1972K5 is offline   Reply With Quote
Old 04-24-2005, 01:59 AM   #164
dtlilly
dtlilly's Avatar
Originally Posted by 72MARIO
... I also found that wrapping the ratchet handle with tape prevent's chips if you become careless and smack the body tighting bolt's...
That's excellent advice. Thanks!
dtlilly is offline   Reply With Quote
Old 05-18-2005, 12:48 AM   #165
smbrouss70
smbrouss70's Avatar
Gee_Emm, I just discovered this thread and WOW!
I have just purchased my first Blazer and I finally understand how everything fits together from your pictures, Thanks for that Man! I see that you waited a while to get some good patch panels, where did you eventually get them from? What brand are they or did you cut them from another truck? Keep up the good work, and keep me inspired because I have a feeling that I will be using this thread to keep me going and teach me some things.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-18-2005, 09:13 AM   #166
Gee_Emm
All of my patch panels came from Christians Classics, he sells Tri-plus brand which are very good quality. They only patches that I have found that they make poorly are the patches for behind the rear wheels. I had to get those cut off an exsiting LWB pickup.
Old 07-02-2005, 12:18 AM   #167
smbrouss70
smbrouss70's Avatar
Gee, Any new progress to show us?
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 07-02-2005, 12:55 AM   #168
Gee_Emm
Nope, I am kinda sitting around doing nothing until I get a garage built that I can work on this thing in. Pretty much all of the little parts are done, I just have to put all the sheet metal on and get it painted then assembled. I don't have a place to do that or a place to keep it once it is finished.
Old 07-02-2005, 09:09 AM   #169
nitor
Too many projects
nitor's Avatar
Great job!!
Jim
'55 Chevrolet Pickup
'56 Chevrolet Belair
'04 Chevrolet Astro
'95 Chevrolet Blazer
nitor is offline   Reply With Quote
Old 07-02-2005, 09:15 AM   #170
krue
Designated A-hole!
krue's Avatar
Nope, I am kinda sitting around doing nothing until I get a garage built that I can work on this thing in....I don't have a place to do that or a place to keep it once it is finished.
I feel your pain! It sucks not having anywhere to work.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-02-2005, 09:50 AM   #171
Shane
Shane's Avatar
Here's another hint a body-friend gave me about wrench/ratchet handles dinging up fresh paint and panels ... use an old piece of heater hose over the handle.
Lookin' Good Gee_Emm!
Shane is offline   Reply With Quote
Thread Tools
Display Modes
