01-20-2016, 06:40 PM | #151 | |
Re: My 83' Crew Cab Dually project
I picked up some 16g steel and I've been working on the raised tunnel. Photobucket has been down all day, so I can't post any pics on here right now. They're on Instagram though...
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192 Instagram: lofab77 |
01-20-2016, 07:20 PM | #152 |
The exhaust would have been an issue for me as well. I saw some of the pics on your Instagram. Looks good
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
01-21-2016, 12:05 AM | #153 |
Trying to get pictures to post since photobucket seems to be down for now with no update on when they will have it fixed... I tried Flickr but it seems to suck for hosting. Does anyone have any suggestions? Preferably one that I can use an app vs a webpage to upload and grab tags.
01-21-2016, 12:17 AM | #154 |
01-21-2016, 12:20 AM | #155 |
This attach image thing will only let me attach one pic at a time. I need my photobucket back.
Anyway - the tunnel is for the most part, in. I can see since I dropped it back down that I'm going to have to do some additional trimming on the firewall around the bell house. I really don't want to take the dash out, but I may not have a choice with how high I need to cut.
01-21-2016, 12:28 AM | #156 |
Squarebody guy
I've used imgur for a few things in the past.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress |
01-21-2016, 12:32 AM | #157 |
Member of the longbed union.
If you can find an old wheel barrel they work perfect for firewall.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
01-21-2016, 01:19 AM | #158 |
I've got sheet metal that I can form...it just needs to go up another inch. The insulation is what's killin me. That stuff is wicked flammable! I'm also trying to keep the heater. I've got an idea for a custom plenum that will clear the tire as soon as I get some gas for the tig.
01-21-2016, 03:12 PM | #159 |
I lit my truck on fire twice with that insulation before I tore it all out.
I was able to get up on the fire wall to weld it without pulling the dash. I had the engine in at the time so I did as much as I could from the top but ultimately had to pull the engine to get some of the final welds in from the other side. Looks good. I tired to keep mine really low so I ended up using a combo of the stock metal and patches. Yours looks much smoother.
01-21-2016, 09:48 PM | #160 | |
It took the better part of the day to burn it all in. I think this was probably the least enjoyable thing I've done on here yet with all the fumes and smoke...Kind of a bucket of suck. It's seam sealed and has a couple of coats of primer/sealer on it. I think I'll call that done.
01-21-2016, 10:08 PM | #161 |
Looks good!
01-22-2016, 02:58 AM | #162 |
Squarebody guy
That is looking really good, I hope I can get mine to look half as good.
01-22-2016, 10:33 PM | #163 |
Wow.........
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
01-25-2016, 12:29 AM | #164 |
Doesn't seem too impressive, but I rebuilt the trans and carrier bearing crossmembers today to accommodate for the exhaust. The trans was fairly straightforward since I had built it to bolt in...the carrier bearing one on the other hand, was welded in place and I had to do the deed on my belly between the cab and the frame. Now I'm a contortionist as well. I got both headers modified to fit above the bottom of the frame and took measurements for the exhaust pipe that I'll pick up tomorrow. I'm getting a lot closer to being ready for paint on the frame. I feel like I've almost rounded the corner from taking apart, to putting together...
01-25-2016, 09:29 PM | #165 |
Question for anyone that has done a Z'd front end...when dropping the front horns, do most people box the frame in that area? Seems like a bad idea in case of a front end collision, but I'm wondering what the standard is. I can't seem to find any conclusive answer. All of the pics of other builds are from the outside and don't show the inner part of the rail.
01-25-2016, 10:20 PM | #166 |
Inner frame doesn't need to be boxed. Just box in behind the z to reinforce it. I have seen people box it in and run a bar between bother horns. But it's not needed.
01-25-2016, 10:40 PM | #167 |
Cool. Thanks. That's what I was thinking...just started doubting myself. Lol
01-26-2016, 12:16 AM | #168 |
01-26-2016, 01:05 AM | #169 |
I boxed mine and ran a crossmember. My would flex when I would use them to get up and I figured it couldnt hurt.
01-26-2016, 02:06 AM | #170 |
Did you run into any issues with room for the radiator? I cut it as far back as I could...hoping it fits without too much issue.
01-26-2016, 01:14 PM | #171 |
Go man!
01-26-2016, 01:28 PM | #172 |
I didn't have a problem with the radiator. My front horns ended up a bit high though. If you have the time I'd mock it up to be sure.
If you do the crossmember make sure you can still use your engine hoist as it will get in the way.
01-26-2016, 02:48 PM | #173 |
A little Easter egg for those that look close enough...
01-26-2016, 03:46 PM | #174 |
Now that's bringing a fish plate to a whole new level!
01-26-2016, 04:13 PM | #175 |
What are you guys using to get this black **** off of the firewall? I've tried lacquer thinner, mineral spirits, carb cleaner, multi solvent...wire brush, flap disc. Nothing is doing very well. I've ruined a flap disc now...wtf is this ****?
Thread Tools | |
Display Modes | |
