08-29-2011, 06:04 AM | #1851 | |
Cruzin
Re: "Rice Rocket'
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
08-29-2011, 10:18 AM | #1852 |
Grandpa in the rustmobile...
Re: "Rice Rocket'
A guy in 60-66 forums somehow managed to get sent the wrong template and hes gonna send it to me when he gets time. So im waiting on his template or making a template from the junkyard. And waiting on 4 clips that hold the bulb in.
Trim-I need the push in clips and more trim. Right now im doing fuel regulator and getting timing curve dialed in. Finished regulator last nite. Edelbrock carbs run sucky @ idle if its more than 5-6 psi. It wouldnt even idle you had to mash the gas and drive it for a few miles before it would, and even then id load up and jump around alot
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-29-2011, 06:32 PM | #1853 |
Cruzin
Re: "Rice Rocket'
finished pixs?
08-29-2011, 10:44 PM | #1854 |
Re: "Rice Rocket'
maybe tomorow lol
08-31-2011, 09:02 PM | #1855 |
Re: "Rice Rocket'
OKAY I got the ol goose runnin best its ever ran. Chirp tires from10 15 mph roll
Got fuel regulated now no running rich at idle and crummy idle. Starts right up. Total timing is 36* hooked to ported (pass side on edelbrock). For anyone with edelbrock carb. Check your fuel pressure if its more than 6 you PROBABLY have cruddy idle/starting problems. Also a good idea to re set the floats since you already spilled gas everywhere.
08-31-2011, 09:28 PM | #1856 |
VA72C10
Re: "Rice Rocket'
Cool deal!
Looking for a 67-72 swb or blazer project in or around VA. |
08-31-2011, 09:34 PM | #1857 |
Re: "Rice Rocket'
lots o pix for hubscrub who kept asking persistantly
08-31-2011, 10:19 PM | #1858 |
Re: "Rice Rocket'
Mo
08-31-2011, 10:20 PM | #1859 |
Re: "Rice Rocket'
Pix
08-31-2011, 10:24 PM | #1860 |
Re: "Rice Rocket'
4 pix
08-31-2011, 10:26 PM | #1861 |
Re: "Rice Rocket'
numba 5
08-31-2011, 10:38 PM | #1862 |
Re: "Rice Rocket'
moree
08-31-2011, 10:43 PM | #1863 |
Re: "Rice Rocket'
Give me some imput on cleaning up the engine bay (tidying up).
Maybe spinning valvecovers around so PCV is in the front of the engine, that'd make the hose shorter and less obvious. Re positioning the throttle return spring to the rear so you cant see it need to fix the oil sender leak in the rear of the motor...ugh. need to fix the rtv leak on the rear intake tuneup (plugs/wires/air filter/oil filter)
08-31-2011, 10:45 PM | #1864 |
Re: "Rice Rocket'
Run some longer spark plug wires UNDER the ram horns and outta the way
Battery cables re routed/longer (+) cable
08-31-2011, 10:48 PM | #1865 | |
Cruzin
Re: "Rice Rocket'
08-31-2011, 11:06 PM | #1866 |
Re: "Rice Rocket'
nice to finally see your truck john! it looks pretty good! i say make wires shorter more hidden hoses that run in nice lines and are routed like they have a purpose.
08-31-2011, 11:38 PM | #1867 |
Re: "Rice Rocket'
Make wires shorter is a good idea ive always tried to curl them up incase I think a better way to route them and then wish I didnt make the wire so short LOL
Hidden hoses? Whatchu mean rick? Thanks keep it commin' ricky. Seen any spare tire carriers mounted in the bed lately? Im still lookin'!
08-31-2011, 11:44 PM | #1868 |
Re: "Rice Rocket'
How can I tidy up the mess of wires @ the battery guys?
08-31-2011, 11:46 PM | #1869 |
Re: "Rice Rocket'
cut the wires or make them tuck under the fender so there hidden. also drop the inner fenders and paintem nice semi gloss black again they really help actually.
08-31-2011, 11:49 PM | #1870 |
Re: "Rice Rocket'
I need the right screws for the ashtray mount as well, just the top 2 screws..if anyone has any theyd wanna put in the mail.... or at least take a pic of so i can get some..
08-31-2011, 11:50 PM | #1871 |
Re: "Rice Rocket'
LAST BUT NOT LEAST.......
....the infamous............. BLACK HOLE! that grandpaw lost his cane thru on the side of the road stopped in traffic for me to go after it
08-31-2011, 11:52 PM | #1872 |
Re: "Rice Rocket'
09-01-2011, 01:40 AM | #1873 |
fat old dude
Re: "Rice Rocket'
dang u needa work on that cab
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
09-03-2011, 11:05 PM | #1874 |
Re: "Rice Rocket'
Started to work on the truck a little this morning was gonna take it or the green car to a cruise in. Cleaned up my gas stained intake manifold (hoping fuel regulator fixed the leak, already adj. floats prior) Intake looks alot nicer. Got about finished with routing my return spring to the rear of the motor (so you dont see it as easily) and heard my grandpa hollering and the dog barking so i went downstairs and he said hes in pain so he took ride in the abulaance this morning. Keep him in your thoughts and prayers please. I want him to go for a few more rides with me and loose some more stuff thru 'the hole'
09-03-2011, 11:08 PM | #1875 |
Re: "Rice Rocket'
a few pix that were on my phone
notice the before/after of the intake. I need to fix the oil sender leak and the rtv is leaking on the rear of the intake. Mabye some other leaks as well but thats all i know of right now
Thread Tools | |
Display Modes | |
