Old 07-01-2008, 08:26 PM   #176
69_hafton
Sleep-Deprived
69_hafton's Avatar
Re: For those waiting on Camaro caliper brackets....
Re: For those waiting for me to install my Camaro caliper brackets...
Finally got around to it and they're working great! I changed out the proportioning valve to a CPP unit and it feels balanced. I've driven for about 5 days with this setup and so far I'm happy with it. I'll have to re-adjust the parking brake, because it would hold when I first put the truck back on the road, but the cables have settled / stretched to where it doesn't stop the truck from rolling.
I had to shim the calipers with 2 washers to center them to the rotors. Also, I removed the heavy weights from the calipers and don't notice any vibration or squeal without them. I'm using a stock disk/drum master cylinder from a 71/72 FWIW. I used all used parts from the 93-97 Camaro: a pair of used calipers, pads, e-brake cable, e-brake cable "brackets", and rubber flex hose. Also, I bolted the (modified) brackets down so I could have a solid connection where the rubber flex hose and hard brake line connect. I may replace the pads here shortly when I get back into it to lock tight the caliper bolts. Curious to hear more feedback from others who have finished this conversion.
1971 K/10 Long Fleetside
350/350 - 6" Lift
1969 C/10 SWB 292 - Sold It
69_hafton is offline   Reply With Quote
Old 07-02-2008, 03:07 PM   #177
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I finished mine a few months ago. I am using a chrome disc/disc proportioning valve from The Right Stuff. I am having a problem with the e-brake cables not being long enough, though. Anyone else with this problem? I have a GMC with rear leafs.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 07-02-2008, 09:17 PM   #178
69_hafton
Sleep-Deprived
69_hafton's Avatar
I've got a coil spring setup, but the parking brake cables appeared not to be long enough either. The cables were ok, I just had to add some length to the cable that comes from the brake pedal. I used a octagonal threaded collar from a hardware store and cut the head off a hardened bolt to lengthen the cable about an inch or so. I just shortened it a 1/4 inch tonight and have the parking brake working again... for now.
When I was ordering the prop valve from cpp, I thought I saw a spacer for the brake cable, but I couldn't tell if it would be the right length?
350/350 - 6" Lift
Old 07-08-2008, 06:08 PM   #179
Hart_Rod
Hart_Rod's Avatar
OK, after messing around with NAPA for 5 months, I need to find a place that sells the complete caliper with ALL the brackets. It wasn't really the stores fault, it had more to do with their distribution/manufacturing center. Apparently, the new calipers don't come complete and you need to remove pieces off of the old calipers (????). I was told all A-1 Cardone calipears were like this. Soooooo, any help with new ones that are complete would be great. Thanks in advance.
R/
Hart_Rod is offline   Reply With Quote
Old 07-08-2008, 09:33 PM   #180
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Yep, I had to get one from NAPA too, but went thru 4 of them before I found 1 with all the correct hardware. The guys working the counter were just as amazed as I was.
Old 07-09-2008, 10:59 AM   #181
gregfull
gregfull's Avatar
Well, add me to the list, my left caliper was complete, but I'm about to order my 3rd right side, hopefully it will be complete!
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 07-09-2008, 11:24 PM   #182
N2GMTrux
N2GMTrux's Avatar
Thumbs up Re: For those waiting on Camaro caliper brackets....
I received my setup today.... Looks good!!! Thank You
N2GMTrux is offline   Reply With Quote
Old 08-05-2008, 09:13 PM   #183
uncle
Bump for a Bud.
uncle is offline   Reply With Quote
Old 08-19-2008, 07:53 PM   #184
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
OK, I will try the threaded collar thing in order to lengthen my e-brake cable. Is that a 1/4-20 thread? How long is the collar?
Old 08-19-2008, 08:00 PM   #185
Hart_Rod
Hart_Rod's Avatar
You could always build a new cable with the correct lenght for you. That's what I did, all the parts are available at the hardware store. I'm still looking for a complete right caliper, .
Old 11-29-2008, 07:22 PM   #186
powerbench
powerbench's Avatar
hey glock do you still make /have a set of camaro brackets?
powerbench is offline   Reply With Quote
Old 12-01-2008, 10:38 AM   #187
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Sorry, I am no longer making them.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 12-01-2008, 11:25 AM   #188
70cst
70cst's Avatar
Ok...now its safe as I did not want to hijack this thread. I bought a set and I decided to stay with the factory set up. If interested post here first. I want to find the kit and make sure its complete. It's quality parts...I just decided to stay factory.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-01-2008, 12:03 PM   #189
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I'll take them. Let me know the cost and PayPal info. Thanks.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-01-2008, 01:22 PM   #190
70cst
70cst's Avatar
Looks as if they are sold...
Old 12-06-2008, 01:13 PM   #191
swappy
glock is their a reason you are no longer making them?
swappy is offline   Reply With Quote
Old 12-06-2008, 01:30 PM   #192
glock35ipsc
I sold my CNC machine, that, and I don't really have the time to do them anymore.
Bob
Old 12-06-2008, 02:56 PM   #193
harlyworkr
harlyworkr's Avatar
With prints, I have the capability to make them.
harlyworkr is offline   Reply With Quote
Old 12-06-2008, 04:20 PM   #194
swappy
Glock I can make than also. I would just nee a dxf or just about any cad file I can convert I can laser them or plasma then. If you want to put kits togeter I can supply the laser cut let me Know
Old 12-08-2008, 02:26 PM   #195
swappy
did anyone figure out the spacing problem. Just wondering why different people needed differant spacing
Old 12-08-2008, 04:12 PM   #196
chevy_mike
chevy_mike's Avatar
Different tolerances. Even the factory had shims of different thicknesses. My '92 Camaro Z28 (which uses the same brakes) had factory shims on one side but not the other.
Old 12-08-2008, 10:41 PM   #197
70cst
70cst's Avatar
My set is sold to chevy_mike
Old 01-05-2009, 02:09 PM   #198
lks dcvn
lks dcvn's Avatar
is anybody making these anymore?
lks dcvn is offline   Reply With Quote
Old 01-05-2009, 02:51 PM   #199
Coalson01
I also would also be interested in these if anyone is still making them.
Coalson01 is offline   Reply With Quote
Old 01-06-2009, 01:43 PM   #200
Ford Assassin
Ford Assassin's Avatar
I would like to be on the waiting list too.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Thread Tools
Display Modes
