Old 04-15-2004, 06:40 PM   #1
Jeremy_5
Truck addict
Jeremy_5's Avatar
ball joints
My boots in both my upper and lower ball joints are shot, how do I know if the actual ball joints are bad too? Also does any supplier just sell the protective boots?
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Jeremy_5 is offline   Reply With Quote
Old 04-15-2004, 09:24 PM   #2
jku72
If the boots are bad, that means that dirt has gotten into them. The ball joints might not be bad now, but they will be shortly.
The only way to check them is to jack up the front, and with a big bar, try to move the wheel, while a helper eyeballs the upper ball joint. If theres any play at all, its bad. The bottom one can be a bit trickier. You have to jack up the wheel using the frame, not the a-arm. Then use a second jack under the a-arm, if, when you start to jack on the a-arm, there is any movement between the a-arm and the spindle, the ball joint is bad.
I mention the second part to check the lower a-arm because many bad lower ball joints have been checked by just moving the wheel, but the front spring tension is such that it is too tight to move, even if the joint is loose, so you might miss it. By using the second jack method, you are using a lot more power and can get a much more accurate picture of the condition of the lower ball joint in particular.
By the way, most garages do not use the second method using two jacks, and twice in my life now I have had catastrophic failure of lower ball joints immediately after having them checked at inspection stations. Both were in classic vehicles, and both led to serious damage to the cars, and both times I was lucky not to be seriously injured or killed.
In my opinion, if you dont use the two jack method, you are not really checking the lower ball joint at all.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 04-16-2004, 12:00 AM   #3
Cruiser71
AKA Phillip Johnson, AKA BANNED
Correct. Jack it up and grab the tire. Ive driven several years with bad boots. Most of the time, it happens because a kid at Wal-Mart is over zellos and lubes the heck out of the zerk.
Cruiser71 is offline   Reply With Quote
Old 04-16-2004, 02:36 AM   #4
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
If you are gonna go through all the trouble of replacing a boot, why not just replace the whole balljoint? You are allready there...might as well.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 04-16-2004, 03:16 PM   #5
Jeremy_5
Truck addict
Jeremy_5's Avatar
chickenwing, good point
Thanks for the help guys.
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Thread Tools
Display Modes
