Old 04-16-2004, 04:33 PM   #1
68jimmy
68jimmy's Avatar
Need to remove crossmember?
Hello All,
My 68 gmc has the original 351 V6/manual 3-speed, which will be replaced shortly by a 350V8/TH350 setup. Right now there is a cross-member that supports the rear of the motor since the 3-speed just hangs in the air from the engine.
I do have the correct cross-member for the auto ready to install. My question is, do I need to remove this other cross-member prior to installing my V8/auto-trans setup?
Thanks!
68jimmy is offline   Reply With Quote
Old 04-16-2004, 04:47 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
yes, and that 351 V6 is a rare engine in a light duty pickup. Most had 305 V6's. If it runs and is complete someone may want it.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-16-2004, 04:51 PM   #3
68jimmy
68jimmy's Avatar
The truck is a 3/4 ton camper special LWB, with really low rear end gears, probably 4.11's... The motor runs fine, no smoke and the only oil it uses is from leaks. Just a bit to much vibration and the gas mileage is terrible!
Old 04-16-2004, 04:56 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
There is a website dedicated to that engine and it's cousins. PM boardmember Erl, as he has the URL for it if you're interested. Someone may want it if you have the space to store it.
Anyway, good luck with the conversion
Old 04-16-2004, 05:04 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
Found it!
Thread Tools
Display Modes
