rear end questions?
i have checked the rear end by pulling the cover off and trying to count the gears to find out what gear ratio it is - i know it is a posi and i believe it to be a 3.42 is this possible? also it seems to have stopped the popping in the rear end with slow turns by changing the fluid and adding additive - still pops ever so often - my other question is how much fluid do i put in it? fill plug is low in differential - do i just fill it up until it comes out of the fill hole? help - thanks, Brent
![]() Join Date: May 2002
How are you going to fill it above the fill hole?
Stepsides look like real trucks! Smitty ![]() |
When empty it will take about 3 1/2 pints. You can fill it until it comes out or until you can touch the fluid.
The ring gear should be stamped with the teeth count/ratio. Jim |
rear end gear
does the gear ratio of 3.42 sound like it is correct? for a posi? again i am ignorant on this subject? thanks, Brent
It is possible to have a 3:42 posi as they are available aftermarket.
Jim |
Also available from late 70's on--until they went to 10 bolt.
I have a 69 with 3:42 posi show on the factory build sheet.
#8 | |
Formerly yellow72custom
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
i'd like to see that too...the only 3.42's i've seen were in C/20 BB trucks w/ Dana 60 rear.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
you got me I got home and looked at the build sheet and it shows positrack but I dont see where it says 3.42. I thought I saw it on there. I have had it apart and it dose have 3.42. I was told they did come with 3.42. This truck was a special orderd and built 08/18/69 so I figer its possiable. If I can get a good copy of this sheet can I post and some help me figure out waht this stuff means.
Can you post some details of your truck. You didn't really say it was a 1/2 ton or 3/4 ton and whether it is a Chevy or GMC. All of this might help.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
The Dana 60 trucks had 3.54. There is a 3.3 ratio 60 gearset that was available in the 80's, but not 67-72.
#13 |
I have question? I have newer style rear end, say a mid to late 80's 12bolt 5 lug rear end. Will the gear's ( 3rd member ) fit or interchange white a 69 chev 1/2 ton 12bolt 6 lug rear end. Before I start tearing things apart. PLEASE HELP My only means of transportation right now.
67heaven327 |
Thread Tools | |
Display Modes | |
