04-21-2004, 11:46 PM | #1 |
Pic of lower hose
1980 305 lower hose
04-21-2004, 11:49 PM | #2 |
pictures
Not sure what i did but igot this posting pictures figured out used ifanview.
04-21-2004, 11:51 PM | #3 |
you dont need to web host
you dont need to webhost pics to post at a decent size to see them clearly.
04-22-2004, 12:50 AM | #4 |
its all about the +6 inches
Don't forget to put hose clamps on that one.
04-22-2004, 11:36 AM | #5 |
is your engine a 350, what waterpump do you have on long or short? and what model of vehicle is the 1980 305 bottom radiator hose for? looks like a good replacement hose for are tight fitting factory hoses. thanks
71 C10 SWB BLACK AND WHITE 350 CRATE TH350 ENJOY LIFE |
04-22-2004, 01:24 PM | #6 |
ttt
04-22-2004, 01:36 PM | #7 |
Fabricate till you "puke"
Roadking, i have the same style hoses on my 69. The water pump in my app is a 73-up truck item,(long pump) as are all the belts, pullies & accessories. You will also notice a difference on the lower rad neck(straight vs the curved neck on the older trucks).......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-22-2004, 01:52 PM | #8 |
just wondering what model and make i tell the autuparts store to get that lower hose? i have a long waterpump with a staight lower neck on rad.
04-22-2004, 02:09 PM | #9 |
Its a truck hose.....I shoot for a mid 70's (75 c-10) for a replacement hose. My 78 K20 also has the same hose. I think it would be a pretty safe bet, that 73-early 80's pu with sb will cover the same bottom hose. Good luck,crazyL
04-22-2004, 06:05 PM | #10 |
HOSE
1980 gmc 305 , everything crossmember on up is from 1980 gmc.
04-22-2004, 09:11 PM | #11 |
Fuel Line
Is that a flexible braided fuel line?
Mine is a hard line bent around and up - its not where I would have run it as the flanged edge of my metal in line fuel filter hits my valve cover. Gets a bit warm. Flex line looks like a better way to go. How do you like yours?
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
04-22-2004, 09:48 PM | #12 |
braided fueline from autozone $19.99 . It just pushes on tightens up with hose clamps and covers. cut to length with hack saw. wrap hose with tape at before cutting helps keep ends from fraying when you cut it.
04-22-2004, 09:52 PM | #13 |
04-22-2004, 09:53 PM | #14 |
fuel line
works great
Thread Tools | |
Display Modes | |
